Treadstone stage 4 install!
Old Feb 18, 2012 | 08:06 PM
  #151
Powell Race Parts's Avatar
When do I ever act like I'm on some high horse? Please, enlighten me.
Im with Blazin on this one. A regular stand up guy is Blazin. Happy to know him, and always a pleasure to meet with him. Same goes for the ZZP guys, stand up and good to meet and hang with as they grind out the 1320....
Another thing, I am on another site where bad language is not allowed. It makes for a pleasant change. Here it sure is tiresome to pay to be a vendor here and read db's swearing, and peeps acting out like grade schoolers.
maybe they are...
Old Feb 18, 2012 | 08:15 PM
  #152
MTE looking at your first posts I am wondering was the stud missing where the leak was? Sure would look like it. With the shop you are dealing with and Italian Joe tuning I would say your problems will be over soon....enjoy your ride!
Old Feb 18, 2012 | 08:27 PM
  #153
MTE's Avatar
MTE
No it was there, but some of the studs where really loose.
  #154
LE5_AJ's Avatar
maybe they are...
Sorry if you meant me thought a little bad boys 2 humor would divert the **** measuring. I'm tired of seeing the same thing happen in every thread.
Old Feb 18, 2012 | 08:37 PM
  #155
nope not you,in fact I agree with you...but the language thing in print is different from cussing around at the shop. its getting tiresome like you say. Good for MTE to get his car rockin' not a fan of cheap intercoolers, but thats the path he has chosen, Italian Joe will tune it right.
Old Feb 18, 2012 | 08:39 PM
  #156
torque wrench and loctite into the studs. some folks tend to wind in the studs with the nuts on if they come out that way, and thats not good. Gotta take the nuts off the studs, loctite the studs and torque them in off the torx head and then torque the nuts etc in a pattern 89 inch lbs- its in the manual but basically a spiral star from middle out...
  #157
MTE's Avatar
MTE
I have a cheap intercooler?
Old Feb 18, 2012 | 08:44 PM
  #158
seems to me, correct me if I am wrong, you said the price was low or words to that effect.
I am a fan of garret cores. Your choice is made, but read this, it is a good research piece and good info.
ARE Cooling (Aluminium Radiators & Engineering P/L)
Old Feb 18, 2012 | 08:49 PM
  #159
oops sorry it was Derek on price: "check out teadstones TR8 intercooler.. thats what im running now.. great price and good fitment "
Old Feb 18, 2012 | 08:52 PM
  #160
MTE's Avatar
MTE
I personally like ARC intercoolers (takes me back wen I had my Evo) and yes I have been debating on upgrading my intercooler to another pcs. That link is very interesting.
Old Feb 18, 2012 | 08:58 PM
  #161
donkeyballs's Avatar
My treadstone IC seems to do a good job
Old Feb 18, 2012 | 09:17 PM
  #162
at the end of the day its what ever you have , you have to be comfortable with. The only folks who really do r&d here (other than me) is ZZP. And ZZP got everyone covered here as far as real current stuff on engines. Period.
And as far as IC are concerned, the only current research I did on IC for LNF was on an ETS. Looked at it, measured it, looked at again, kicked it around the shop with the fabbie, and researched ( see link for part of that) and then called werkes in Chicago and said "ship one of your garret cores danno!" or words to that effect.
Old Feb 18, 2012 | 10:20 PM
  #163
Zooomer's Avatar
Supporting Vendor
Originally Posted by Chevycobaltss3
Using just a boost controller actually does cause drivability issues .. you calling for a.commanded dal and mal and also using proprtional, integral, and deriative gains and a wgdc. So therefore the ecm willl act as if its failing somewhere .... I've tuned.plenty enough of Tq based ecms to know what im talking about. The drivability issues may not be badly affected.but the cars power may or may not surge in areas or the car will shutter, stutter ect..
Yes you can disable all the codes, woopdy doo. But it still doesn't matter.. the car will act differently to just a manual boost controller then to the cars actual controller with a possible online manual controller.
Originally Posted by Matt M
We've set up several LNF turbo swap cars with boost controllers and they drive completely normal. It's not that difficult. I would say it is easier than making the required adjustments to the boost control tables for a larger compressor and completely different wastegate type and spring pressure.
Differences meaning some. wont care some will, some won't notice some will. i notice.
Of course there are differences, but that isn't what you first said. You originally said that it should not be done because there will be driveability issues.
Matt all you do is talk ****.. shut your mouth. troll. I stated it causes drivability issues so it shouldn't be done yes.. did i say it'll be bad bad no I didn't. I never went back to somthing else.
Rod, cuz I'm bsing because in reality and in fact I can do somthing. Hmmm really... You both just need to get out of the thread with Ure useless posting.... My posts have reasoning.
It's not trolling, it's correcting false information YOU are posting. You stated that a manual boost controller causes drivability issues. The truth is that it does not when done properly. It's pretty clear that you did it but didn't do it properly and we're assuming that it causes issues so you wanted to share that info. The info is incorrect and instead of bitching about it, you may want to ask a REAL expert how to do it properly.
Old Feb 18, 2012 | 10:26 PM
  #164
Chevycobaltss3's Avatar
I swear you guys have issues...... Did I ever say I had issues . No ..... I have tuned plenty enough cars with just a boost controller... Lnf wise meaning.... And didn't have issues. But the fact is which was bluntley stated by one of your own. It will have drivability differences.... So get the hell off my back .. ..
Old Feb 18, 2012 | 10:31 PM
  #165
So putting words in my mouth. Hmm seems like a zzp thing to do.. I never said not to use a boost controller.. i said it will have drivability issues meaning differences...
Of course I felt obligated to make a comment. You were trying to teach the LNF community that they can't use manual boost controllers on turbo swaps. Any time someone insists upon something that I know to be false, I will comment.(As long as it is reasonably important information relating to the community.)
Old Feb 18, 2012 | 11:00 PM
  #166
Matt M's Avatar
Words in your mouth? We quoted you and then commented. I never said "driveability differences." I said "differences" without any other words connected. The differences are that you can get full boost at lower throttle if the ecm is not able to back off the boost control duty cycle as well. It's not a big deal because you can get used to pushing the throttle less or you can set the dals to target a little less airload through the middle of the chart.
Old Feb 18, 2012 | 11:03 PM
  #167
Boosted4's Avatar
Basic summary of the direction of this thread:
Old Feb 18, 2012 | 11:08 PM
  #168
Matt M's Avatar
When someone tries to spread false information, that will sometimes happen. We don't let that stuff become the new "truth" out in the community. It's tough to un-do false information later if you let it go now.
Aside from that, I was far from bragging about anything.
Old Feb 18, 2012 | 11:15 PM
  #169
Look I'm not trying to argue. In fact I'm tired of it.... I know the differences. Some people like them some don't. And the post was you saying I was trying to teach the lnf community they couldn't use a boost controller. Why would I say that when in fact I use one . I was saying there will be drivability differences.
Old Feb 18, 2012 | 11:18 PM
  #170
jonathan923's Avatar
heres the new thread, so no moar arguing etc.
https://www.cobaltss.net/forums/2-0l...4-dyno-272110/
  #171
Matt M's Avatar
Ok, you have revised your statement to replace the word "issues" with "differences." I will accept your correction and there is no need to argue about it any further.
Old Feb 18, 2012 | 11:23 PM
  #172
Matt since I have you hear.. I have three customers wanting a new build. I told them not to sleeve since I did and I had.issues so I had to redo it my self.. they want the Gurdled block. It's a good setup. So my question is how long will it take to get one out .
Old Feb 18, 2012 | 11:32 PM
  #173
Matt M's Avatar
Honestly, Todd is backed up pretty bad right now. He is trying to keep up, but it is our busiest time of year and there are several on back-order.
Old Feb 18, 2012 | 11:35 PM
  #174
Alright ill still have him order it through you.. lol. i like your products so don't think I don't. I have a **** ton of people who i recommend.to get your parts..
Old Feb 19, 2012 | 09:02 PM
  #175
ding ding
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
