Where is the GM stage kit?
Old Apr 18, 2009 | 07:34 PM
  #1051
metroplex's Avatar
Originally Posted by emiller
Its really no different than what other companies do.
Toyota did the same thing with the TRD supercharger for the Scion tC with the promise of it will be ready in 3-4 months. When it did come out almost 1.5 years later people were breaking them almost as fast as they could install them. It was obvious they cut many many corners. They ended up redesigning it 2 more times over the next 2ish years before getting something to stay together for more than 20k miles.
I'd rather they take the time to do it right then release junk several times. Having to get it fixed repeatedly with the promise of the "redesign" fixed the issue just pisses people off worse.
Take their time to do what? The LNF Turbo Upgrade kit has been out for other LNF applications. Nothing has changed with the SS/TC.
Old Apr 18, 2009 | 07:54 PM
  #1052
buellfooll's Avatar
You're not following the thread. There IS a difference with the Cobalt SS. There is a problem in the air inlet tract. Nobody knows for sure exactly what the exact problem is but several people on here have verified this. Plus. The Cobalt is unique in that we already have NLS and LC. The others have that added with their new ECU OC. And I'm sure there atre other differences. Each application had their own calibration so there must be something different.
Old Apr 18, 2009 | 09:59 PM
  #1053
Stamina's Avatar
I just noticed today that if you look into "building" a Pontiac GXP online for instance, that the "Power Upgrade Option" is now present if you want the kit installed straight from the factory.
Seems GM made a good marketing/business decision there.
Old Apr 19, 2009 | 07:05 AM
  #1054
metroplex's Avatar
Software is easy to program. I am not sure what is holding up the Cobalt SS LNF TUK but if it is the air intake, why not just release the PCM calibration? Why bother with an air intake?
Old Apr 19, 2009 | 09:04 AM
  #1055
Smallywood's Avatar
Cool
My understanding is that is a cold air tube modification, not necessarily a full cold air intake replacement. I guess we'll know in a couple months for sure...
Old Apr 19, 2009 | 12:21 PM
  #1056
JINNER44's Avatar
i feel like are car NEEDS a full cai and new intercooler piping cuz its ****** plastic. it looks cheap and is cheap. with those two and the software, i feel like we could get some serious hp.
Old Apr 19, 2009 | 02:02 PM
  #1057
Chandler's Avatar
plastic tubing is fine, doesnt hold heat like alum does, that is not the problem. Guys, the intake is the most important factor in dealing with a turbo car. It contains the MAF and it is very particular about every aspect of the air that goes past it. Anyone that has had MAF problems with other cars can tell you , that if your MAF is bad , your not going anywhere. I am pretty sure that the change in diameter of the tubing behind the MAF is causing certain turbulence as the air being drawn in.
After they change the intake diameter or distance , they are going to have to go back in and set target goals for the calibration. THEN find out the limit to the system. How far they can push it. Idle, closed loop, open loop, new voltage , etc .
All in all , there is just alot more that goes into just changing the intake out.
More realistically , any car with an intercooler does not need a COLD AIR INTAKE system. Velocity is more important , let the IC take care of how cold the air is , that is its job. Most of the time the temps that the MAF reads is not going to be exactly to what is actually being introduced into the cylinder, so tuning the CAI is going to be a more of a pain than anything.
Old Apr 19, 2009 | 05:13 PM
  #1058
metroplex's Avatar
The new intake would also raise the price. If there's a new airbox, MAF, filter, and tubing involved, I expect nothing short of $1000 for the SS/TC LNF upgrade kit.
Old Apr 19, 2009 | 06:27 PM
  #1059
JINNER44's Avatar
well that would blow.. all that for like 50 or 60 hp
Old Apr 19, 2009 | 06:44 PM
  #1060
krispy's Avatar
50hp for $1000 is a bargain when its comes to car modding
Old Apr 19, 2009 | 06:49 PM
  #1061
buellfooll's Avatar
Thank you for a great explanation of the complexities of the LNF calibration. But I'm still a little fuzzy on one thing. GM refers to the sensors as "T/MAP" Temp/Manifold Air Press. Probably does the same thing but with a different name.
Old Apr 19, 2009 | 08:02 PM
  #1062
Chandler's Avatar
Yes, I just have to brush up on the DI /GM lingo
Old Apr 19, 2009 | 08:12 PM
  #1063
Black08SSTC's Avatar
I have come to the realization that this kit will never be released. I think the stage kit for the new camaro is already out lol.
Old Apr 19, 2009 | 09:20 PM
  #1064
swazzees's Avatar
some ppl in CDN dollars pay 570 to have a hahn cai shipped to there house
for a grand which i was already ready to pay.....get 50 ponies, 80 torque new t maps and a cai
that sounds great to me
Old Apr 19, 2009 | 10:28 PM
  #1065
Buzz65's Avatar
I'll just continue to check each day until I hear one way or the other...
Hoping it comes out...
Old Apr 19, 2009 | 11:55 PM
  #1066
thats what i keep doing, calling my dealer every 2 weeks and have them check by VIN #
Old Apr 20, 2009 | 12:29 PM
  #1067
kazinova's Avatar
The wait till July begins...sigh...
Old Apr 20, 2009 | 12:49 PM
  #1068
Sweetsandman's Avatar
And then when July comes they will say "should be done by Thanksgiving time." Wouldn't that just be awesome?!
Old Apr 20, 2009 | 03:42 PM
  #1069
revhigh18's Avatar
haha waiting on this is like waiting on barack obama to do something positive haha
Old Apr 20, 2009 | 03:44 PM
  #1070
Terminator2's Avatar
. you get your KO4+ yet?. I want to see your numbers if so. I am debating on whether to get it.
Old Apr 20, 2009 | 03:47 PM
  #1071
PimpLay2's Avatar
Originally Posted by Terminator2
Stock OS will not work with the upgraded sensors. . That is why they reflash the computer not just for power gains but so the ECM will work with the expanded range sensors.
do they have new OS in the Gm kit?
Old Apr 20, 2009 | 03:49 PM
  #1072
buellfooll's Avatar
Yes!
Old Apr 20, 2009 | 03:50 PM
  #1073
Yes!
X2.
You beat me to it.
Old Apr 20, 2009 | 05:22 PM
  #1074
Donny Brasco's Avatar
Forget about the tune, I am still waiting for the 5pm Friday update from AlphaJaguar!
Guys seriously, I would be flooding GMTunerSource with comments about how pissed off and frustrated we are getting about waiting for this tune. I posted one that was pretty much a vent, but I KNOW it got to the right people. I was told it did. I was also told that posts like mine are shown to the "powers" inside as well.
I think we should deluge GMTunerSource with comments, posts, and pleas for this damn tune.
Old Apr 20, 2009 | 05:35 PM
  #1075
swazzees's Avatar
what the hell is a k04 + ??????
