ZZP and BNR build
that is exactly why i have pink calipers.
hopefully matt can chime in for this question, did zzp install the motor and throw the car on the dyno? I just did a build on my car was thinking about just breaking it in and tuning it on a dyno
Yessir it technically kinda is lol
they said they started it let it sit a couple minutes, revved it to redline let it decelerate then strapped it on the dyno.
ok cool i have let my car start and just sit there and run while checking for leaks and seeing how everything was working, since its been down for so low i'm trying to be able to hit some sort of boost as soon as i can lol
lol, not quite like that, but we do break it in on the dyno. At light throttle, bringing it up to 4500rpm, then coast down to idle, then 5000, then 5500, then 6000, and 6500 each time letting it coast down to idle. It helps seat the rings. Then after a couple heat cycles I start running it under power.
Damn, and where is this place located? I'm down, especially since thats $3.07 a gallon....I'll go there and buy like 3 or 4 drums, I have a truck...
