574's TVS mini build
Glad you're happy man.
Good luck getting rid of the grin you'll have.
Btw as far as no wot on the new clutch.
No need to be that easy on it. I broke my Gmpp like this :
A few 2-4k rpm drive through town for a bit, gradually going higher. Heat cycles are moth important. Just don't bang gears. Rpm doesn't play as huge of part as many think.
Mixing up where you drive is best. But a couple days worth of different drives is perfect. Some people wait way to long. It's much like when you get new pads, of course you don't want to go out jamming on your brakes, due to glazing, but a few good stops and heat cycles, they work great.
no I didnt break it, I meant I didnt break it in, I just went and enjoyed it. I am at 450 miles on my gmpp and fresh forged motor and did nothing to break it in. Just drove it to work, drove it to the dyno, dyno'd it, ran it down the highway to 160mph. Just drove it. I dont feel there was really any need to do a break in cycle.
Mini road block. Seems I have mixed up the cams lol. I kept the cam caps in order though. If anyone can tell me looking at it from the intake side, should cap #10 be in the bottom right? If so then I have them in the right spots.
hey nick, check out what made my car die. might be something to keep an eye out on your build... just so you know the symptoms were missfiring and the car was stumbling...
I got all the studs back on, rockers, cam and cam caps. I put the CPS back on and lined it up best I could, but it was hard to judge. I guess I'll find out if I did it right lol. Also got the stud holes cleaned out, made a MESS. I know I sound like a noob but what do you mean by "pre time"?
lay the cam gears on each cam with the head off and get the exhaust cam timing mark to 10 o clockish and the intake at 2 o clockish
that way you dont have to rotate the cams too much and risk a valve contacting the piston
