574's TVS mini build
Old Mar 7, 2013 | 08:56 PM
  #701
TStone's Avatar
Originally Posted by lsjion
I have no idea what you're talking about.
What is an lsj? ecotec?
That thing you eat, sleep & breathe!!
Originally Posted by 574
I would have had the head on tonight if I had someone to hold the timing chain. I think I'll have to wait till saturday morning to get the head on and timed
Too bad you don't have one of them "lsjion's" near you..... They can time an LSJ in under 2 minutes, by themselves... eye's closed, one hand tied behind their back, on one foot...... okay I got carried away, but you get my point.
  #702
lsjion's Avatar
hold the chain how?
Old Mar 7, 2013 | 08:58 PM
  #703
574's Avatar
574
Well I just need someone to hold the chain so it doesn't fall to the bottom end while I'm putting the head on. And yeah I wish I had an lsjion near me too because it'll probably take me a few hours haha
  #704
Tjolley's Avatar
Sounds. Like ur all set then. U should have it running in a hour or 2 if u have done this before lol. The first time is always a pain and a learning experience. After that its easy and a couple hour job as long beer isn't involved. Lol
Old Mar 7, 2013 | 09:00 PM
  #705
TStone's Avatar
Few hours? Psssh. It's crazy what that man can do in such a little amount of time. Get him & MrB on an engine together, and magic happens, PURE MAGIC.
But you don't have to hold the chain. There are little nubs in the head that will hold it for you.
  #706
lsjion's Avatar
the chain wont fall, it will get caught on the nub in the block, after you put the head on, use a magnet of a coap hanger to fish it up
  #707
574's Avatar
574
This is my first time/learning experience haha
Here is my timing question: put engine at TDC, when I take the crank pulley off how do I keep the engine from turning over and going off TDC?
  #708
Tjolley's Avatar
Need a magnet works good. Lol
Old Mar 7, 2013 | 09:01 PM
  #709
lsjion's Avatar
damn, you do listen when I speak dont you!
I'm proud
Old Mar 7, 2013 | 09:03 PM
  #710
TStone's Avatar
I'm proud
Very few things that go in one ear, don't come out the other. The stuff you teach me, I keep inside!
That kinda sounded gay.
Old Mar 7, 2013 | 09:04 PM
  #711
lsjion's Avatar
the ring tension with help from going off tdc, but the crank gear has dot that matches the color link on the chain
Too bad you're not closer, I'd save you from pulling the timing cover.
Old Mar 7, 2013 | 09:07 PM
  #712
574's Avatar
574
I know there is a dot on the sprocket down low that I line up with the colored link. You said to take the crank pulley off with an impact, but just tonight I tried to turn the pulley with my hand just to check the resistance and it turned pretty easy
Old Mar 7, 2013 | 09:08 PM
  #713
lsjion's Avatar
was the head off? another thing you COULD do if it makes you feel better is put the plugs in it, then your're fighting compression.
Old Mar 7, 2013 | 09:11 PM
  #714
lsjion's Avatar
it can move a little, as long as the intake side of your chain is "taught" and the colored links line up, youre good. then put the gear on the chain where it belongs, lined with the last colored link and rotate the cam clockwise, should only rotate 45* or so iirc before the gear will fall into the cam
Old Mar 7, 2013 | 09:12 PM
  #715
574's Avatar
574
...............Yes the head was off haha I feel dumb now. That would probably help a lot lol
Old Mar 7, 2013 | 09:13 PM
  #716
574's Avatar
574
So I shouldn't have torqued my exhaust cam sprocket with loctite yet...? lol
Old Mar 7, 2013 | 09:14 PM
  #717
lsjion's Avatar
lol no need to feel dumb, once cylinders have some miles on them, it usually doesn't take much to turn an engine by hand with the head off.
  #718
TStone's Avatar
I have directions from all data that I can send you if you want thjem
ahahaha no.
Old Mar 7, 2013 | 09:16 PM
  #719
574's Avatar
574
Well sheeeit, Lol that cam gear is gonna be a bitch to get off!
  #720
lsjion's Avatar
putting the ex cam bolt in, is the last thing you do, when the chain has tension on it, is when i usually put the loctite on
nah, its not bad, just use a 15/16 wrench on the cam and a big breaker bar.
Old Mar 7, 2013 | 09:17 PM
  #721
c130aviator's Avatar
i made this to take on the pulley and to torque it to spec.
  #722
TStone's Avatar
Reason #241 for why having an "lsjion" is good.
He has lots of big boy tools.
Old Mar 7, 2013 | 09:19 PM
  #723
lsjion's Avatar
oh, and don't worry, you can reuse the bolt. I've only ever replaced them once.....3 swaps ago
65 ft lbs and loctite is all you need
  #724
574's Avatar
574
Don't tell me I just wasted a torque to yeild bolt.......
Edit: sounds good lol
Old Mar 7, 2013 | 09:20 PM
  #725
TStone's Avatar
No, you didn't. Everyone re uses them.
