574's TVS mini build
Old Mar 25, 2013 | 04:24 PM
  #951
JapEatr's Avatar
South Central *********
push pins out of the 60s harness, undo existing pin from the wire, crimp on new pin to wires, push in the connector, put on the *******
Old Mar 25, 2013 | 04:28 PM
  #952
574's Avatar
574
I didn't know if I could just cut the connectors off then strip the wire and crimp
Old Mar 25, 2013 | 04:34 PM
  #953
JapEatr's Avatar
it will be shorter then, just do like i said, after you get the old connector off youll see what im getting at
Old Mar 25, 2013 | 04:43 PM
  #954
advise's Avatar
They give you plenty of wire on the aftermarket harness
Old Mar 25, 2013 | 04:47 PM
  #955
JapEatr's Avatar
clip and go, do one at a time tho
Old Mar 26, 2013 | 08:32 PM
  #956
574's Avatar
574
Got my harness made, waiting on HPT from a local friend...
on a side note what can cause a un-clean shut off? I turn the key off and and it still trys to run for a few seconds
Old Mar 26, 2013 | 08:51 PM
  #957
Powell Race Parts's Avatar
SOP. ig. sw. dont worry about it.
Old Mar 26, 2013 | 08:55 PM
  #958
574's Avatar
574
Either your drunk again or I'm not understanding what your saying...
Old Mar 27, 2013 | 12:58 AM
  #959
ThexGovenor's Avatar
nick you are drunk.
Old Mar 29, 2013 | 09:29 PM
  #960
574's Avatar
574
Not much of anything has been going on, finally my friend had time tonight to get a log done and his computer was asking for his activation code thats at work so we should do a log tomorrow.
ANYHOW I found out when my car starts running bad and won't idle the afr's are at ~16-17
Old Apr 5, 2013 | 10:10 AM
  #961
574's Avatar
574
Since I don't know a lot about tuning how does this sound? Is this mild?
Mid start at 11- aggressive to 16 by 4200
22 by 5500 and 25 by 6k
Old Apr 5, 2013 | 10:22 AM
  #962
mrbelvedere's Avatar
I would flash a stock timing table on till you get your afr dialed in
Old Apr 5, 2013 | 10:24 AM
  #963
574's Avatar
574
I think that is just what it will be when we are finished.
Old Apr 5, 2013 | 10:53 AM
  #964
JapEatr's Avatar
are you talking about timing or what?
i have some tables from my street tune if you need.
Old Apr 5, 2013 | 11:00 AM
  #965
574's Avatar
574
Yes timing. An I'm not tuning I am just asking what opinions are if this is low mild or aggressive
Old Apr 5, 2013 | 10:08 PM
  #966
574's Avatar
574
Bump for tune opinions
Old Apr 5, 2013 | 10:44 PM
  #967
sundevil07's Avatar
Are you looking for power or reliability? On E those are conservative numbers especially mid range, at peak torque I would cram in all the timing I could
Old Apr 5, 2013 | 10:49 PM
  #968
574's Avatar
574
I told him I want some power but its also my dd so I need the tune mild
Old Apr 7, 2013 | 09:17 PM
  #969
574's Avatar
574
ID1000- in
DW300- in
Base file- on
Car starts?- yes fist data log should be tomorrow night
Old Apr 7, 2013 | 11:23 PM
  #970
Tjolley's Avatar
24* up top will be mild depending on boost
Old Apr 8, 2013 | 12:18 AM
  #971
Vander Nars's Avatar
My understand of E was that u could run as much timing as u wanted(26ish i think is what most stop at) and it wouldnt stress the motor. This may be wrong but its aomething I had read somewhere on here.
Old Apr 8, 2013 | 12:28 AM
  #972
stress is stress no matter what fuel your running the fuel just makes it easier to deal with
Old Apr 8, 2013 | 12:40 AM
  #973
sundevil07's Avatar
Please explain. No preignition no worries, rod bearings dgaf
Old Apr 8, 2013 | 06:42 AM
  #974
Tjolley's Avatar
Its not just preignition u need to worrie about. E85 has enough octain to make it extremely hard to preignight. By running a ton of timing (34*) up top like i did u run the risk of beating the **** out of the bottom end. Cuz with that much timing there is a point were the piston is trying to shove the rod out the bottom of the engin cuz its still brealy in the compression stroke.
I made a ton of power. But i and most members will agree that its not worth the added stress for the power u gain running it that hard.
Old Apr 8, 2013 | 06:51 AM
  #975
574's Avatar
574
With ported head full boost should be about 25psi
