574's TVS mini build
You need to get that Wideband running asap. You could be washing down your cylinder with fuel. At least that was where I was before I got a tune. Your car uses stft and VE under certain RPM's could be stumbling over the table and after coming out of closed loop or dropping off MAF to VE. You should be able to idle on 80's at 800 rpm. YOur idel could be high though if your car doesnt go back into open loop. This was something I was seeing as well in my tune after having a few people trying to help me tune the car.
Drove the car for the third time today, idles better. I don't understand, it runs fine when I start it up. As soon as I get about five miles from home it starts misfiring and running like ****. Oh well, got the clutch broke in enough for tuning and it's gonna stay parked until I can get tuned.
Agreed, driveability differences will hardly be noticeable from the head alone. Did you used to have a 2.5" Maf houing in your old intake and a 3" housing now? I know the cobalts are different than the redlines in that aspect.
I'm sure the head added with the new intake is the culprit. How did you tune before without a wide band?
If idle is becoming a problem, you could just unplug the o2 sensor for time being.
Force it into open loop
I have a wideband, when I put my new dp on I forgot to put the sensor in so I just screwed a cap in I had from before I got the wb. I was planning on putting it in when I get my copper gasket.
the new intake is the sole culprit changing the maf tube diameter will change the airflow 10to1 over a ported head that's my guess
