Bad iAT2's
Old Apr 4, 2012 | 07:33 PM
duffman11's Avatar
Bad iAT2's
I was cruzing today down the freeway going 70-75. I noticed my Interceptor was registeriing my IAT2 at 159 degrees. Lately it's been getting hotter. I'm pretty sure the intercool pump failed. 85K Miles IDK if it was ever replaced. Anyother input. I have stock pully w/ S3 H/E
Old Apr 4, 2012 | 07:34 PM
574's Avatar
574
I'd vote yes.
Old Apr 4, 2012 | 07:35 PM
rekameohs_nire's Avatar
sounds like a pump to me. im at about 74k and just replaced mine
Old Apr 4, 2012 | 07:37 PM
duffman11's Avatar
Figured that much. Danm I was going to put on the 2.9 and injectors. Glad it went out now rather then later.
Old Apr 4, 2012 | 07:38 PM
reduf99's Avatar
sjc0013 Licks windows
Pop the hood and turn the key on you should hear and see the pump working ior not
Old Apr 4, 2012 | 07:44 PM
its a fairly easy thing to replace. its 2 bolts and 2 hoses. the hoses are a pita to get off tho
Old Apr 4, 2012 | 07:45 PM
duffman11's Avatar
Well I'll use the opprotunity to install Duel pass and Option B haha
Old Apr 4, 2012 | 07:53 PM
574's Avatar
574
Well if your doing those you might as well put on S3 heat exchanger.... You only wanna do the plumbing once. And the dual pass sucks just sayin.(putting it on)
Old Apr 4, 2012 | 07:55 PM
duffman11's Avatar
S3 is already on. Just Duel pass and Opt B sitting in the box waiting for some love.
Old Apr 4, 2012 | 08:10 PM
duffman11's Avatar
Also Does anyone have the map for Duel pass + opt B?
Old Apr 4, 2012 | 08:32 PM
willdrew's Avatar
Take a look at this
https://www.cobaltss.net/forums/how-...rnator-274630/
Old Apr 5, 2012 | 11:39 AM
1AJeremyD's Avatar
Dual pass isn't bad as long as you take your time. I helped rekameohs_nire put his pump on but taking the intake manifold off would have made the job ten thousand times easier.
Old Apr 5, 2012 | 11:41 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by willdrew
Thanks for posting this
Old Apr 5, 2012 | 06:14 PM
willdrew's Avatar
No problem. Its a good how to with great info
Old Apr 5, 2012 | 07:38 PM
duffman11's Avatar
After reading that guide...not point to do the pully seperate from the duel pass, you gotta take the danm S/C off anyways....
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
Iceberg
Sep 28, 2015 01:31 PM
