can u say pauls turbo 2.0
Old Oct 5, 2007 | 06:22 PM
  #426
06blackg85ss's Avatar
I have no idea man, I haven't done it yet, still on the stock fuel system. But you'll need a regulator, fuel pump, lines, modify the fuel rail, and probably a few other things, I haven't really dug to deep into this car yet, so I don't know
Old Oct 5, 2007 | 06:23 PM
  #427
intense_SS's Avatar
ok cool, do you know anyone that has done a return line on these cars?
Old Oct 5, 2007 | 06:26 PM
  #428
talk to witt or dan
Old Oct 5, 2007 | 06:27 PM
  #429
intense_SS's Avatar
ok will do thanks again man
Old Oct 5, 2007 | 08:40 PM
  #430
Doc's Avatar
Doc
you guys took this thread on a HUGE circle..
glad its back on track...
Old Oct 6, 2007 | 12:39 AM
  #431
Cobalt_Supercharged's Avatar
Originally Posted by 06blackg85ss
I'm changing around my build plans now though,
probably going to swap over to the msd standalone pcm in a month or so,
then new motor:
8.5:1 pistons,
ARP head/main studs
some rods (whoever comes out with a set beside JBP)nuetral balance shafts, full head work.
272 grind cams, new springs, retainers.
should have a nice 9krpm beast. now I just gotta figure out what to do with the transmission, still rockin the stock clutch at almost 25,000 miles now (original clutch and tranny, DSS II axles) we shall see what time brings upon this car.
Have you bought the pistons already? If not you can order any of the 2.2 rods, but you have to get pistons with a 21mm wrist pin intead of the LSJ's 23mm pins. All the other dimensions are the same. You might be able to use the 2.2 pistons as well, but I read some where that the 2.2's are actually an 86.5mm bore not the 86mm like is claimed and like the LSJ. That could be completely wrong though, so I would ask. Don't worry about the smaller wrist pin. GM Sport Compact told me the 21mm pin is good to 700hp. After that they use 22mm wrist pins.
Old Oct 6, 2007 | 01:04 AM
  #432
mezzanno's Avatar
update on pauls turbo. I ran him a couple times today with my z06. Races were real close, I pulled him maybe a couple cars from 70-130. Also his car is not finished yet and is only on 18psi. A rematch with vid will be in order once he is fully tuned on meth and running 23psi.
Old Oct 6, 2007 | 01:07 AM
  #433
stealthy1ss's Avatar
Holy ****! Paul is going to make the big boys **** their pants when he gets tuned and works everything out.
Old Oct 6, 2007 | 01:15 AM
  #434
Are we talking a stock Z06 or modded? C5 or C6?
Old Oct 6, 2007 | 06:49 AM
  #435
skymynx's Avatar
this would make a big difference in my opioion. im guessing a C5
Old Oct 6, 2007 | 06:59 AM
  #436
racinthor's Avatar
I know that you said that you got the manifold from ebay, but I can not find a turn down manifold anywhere. If you don't mind what kind of manifold did you get because i want to build my on kit but i need a manifold. If some wants to build just a manifold i am sure alot of people would be interested
Old Oct 6, 2007 | 07:54 AM
  #437
His Z06 is an 03 with ported LS6 heads, some big ass cam, full exhaust (headers, no cats, etc) and a full tune from vette doctors, it's making 440whp at the moment. and he only had a car on me and that was becuase I have to shift really slow or the car dumps fuel because of the BOV being after the MAf.
Just to let you guys know, last time we went from a 40 roll. I got up to @150 mph and he was so far ahead of me I couldn't even see his car anymore. From a 40 roll we were dead even til I shifted, then I start catching back up again. Same with the 60 roll, I fell back on the shift due to the car boggin and having to let off the throttle, but 4th gear I started catching up again. This thing is definitely a monster. (mind you still can't go WOT, but at least now I can get 85% throttle out of the thing and it holds and afr)
As for rods, I thought the 2.2 had a longer stroke which is why we couldn't use em. But they are fairly easy to get my hands on a set of stock ones, so I can mock em up and see what happens. If that's the case, in 2 weeks I'll order a set of rods and 2.2 low compression pistons and finally get my motor together so I can really start getting on it.
Old Oct 6, 2007 | 01:41 PM
  #438
intense_SS's Avatar
bump for more pics of the wastegate, intercooler, turbo, piping, bov, and boost controller!!!!! and o yea what is that gauge located by your fuel rail? regulator?
Old Oct 6, 2007 | 03:30 PM
  #439
fuel pressure gauge, just wanted to see what actual base pressure was, I have an electric unit I"m gonna run in it's place when it's done.
Old Oct 6, 2007 | 03:44 PM
  #440
jimbos'ss's Avatar
x10 on this one, i'm having trouble finding one myself. right now, i'm setting up my whole build, and i can't find a damn down turn manifold
Old Oct 6, 2007 | 06:50 PM
  #441
intense_SS's Avatar
yes, i am also having this problem, i was looking at cast manifold that are made for a b16 motor, they look like they will work out, but i dunno?
Old Oct 6, 2007 | 08:58 PM
  #442
nah has to be an ecotec cavi one, they just need a little modification to fit correctly
Old Oct 6, 2007 | 09:00 PM
  #443
jimbos'ss's Avatar
what has to be modified?
Old Oct 6, 2007 | 09:14 PM
  #444
mosty you have to have the head flange planed since they usually come a little warped, and I had to drill out the bolt holes cause they didn't line up perfectly
Old Oct 6, 2007 | 09:29 PM
  #445
jimbos'ss's Avatar
thats not too bad.
Old Oct 6, 2007 | 10:23 PM
  #446
it really wasn't just figuring out how to mount the turbo for proper exhaust routing and whatnot took a few tried and some grinding, but all was good, took about 4 hours total including removing the old exhaust setup
Old Oct 7, 2007 | 11:13 AM
  #447
skymynx's Avatar
any updates paul. also any news on wether or not CA is plannin on releasing this kit?
Old Oct 7, 2007 | 11:18 AM
  #448
Darksun's Avatar
I personally don't see CA releasing this kit. Maybe like 3 total if that. I don't think he wants any more headachs right now..
Old Oct 7, 2007 | 12:01 PM
  #449
It's hit or miss right now. Im going there next friday, so I"ll see what he says. Last time I talked to him when we were finishing my car he said he wanted to release it after I finished working the bugs out and the tuning.
Old Oct 7, 2007 | 12:27 PM
  #450
WSFrazier's Avatar
I would like to see CA release it with a GT2871/76R with a nice flowing custom exhaust manifold.
Hopefully they would use an external gate with a straight dump and blow through MAF as well.
