can u say pauls turbo 2.0
Old Oct 11, 2007 | 09:02 PM
  #551
intense_SS's Avatar
do you think kenny and CA will let me purchase seperate parts to finish my kit? piping and such?
Old Oct 11, 2007 | 09:04 PM
  #552
06blackg85ss's Avatar
I dunno. I think he only wants to do these as kits as there is a decent amount of fabwork involved. Better off just buying the kit man, better then mixing and matching ****, plus you know everything will fit. Also the base tune will be a decently safe one from my car once it's dialed in on the dyno
Old Oct 11, 2007 | 09:13 PM
  #553
Asphalt Assault's Avatar
Originally Posted by 06blackg85ss
it's running ok, plugs are shot from when it was dumping fuel, pretty much tuned that issue out now, new plugs go in tomorrow and along with the new 3" ic-tb piping, all should be good. If I have the time, I"ll re-install the meth, I'm picking up a few gallons of race gas, and bumping up the boost and the timing to get a good high boost tune for the dyno. Only issue I still forsee is my stock clutch giving up on life, but so far so good
METH?? dont do meth? Ya I'll add water and wishield washer fluid to my already low intake temp of 90 degrees and confuse the ECM and my tune.
man I am not saying never but just concentrate on a solid tune at first. you should crush any other cobalt now with out meth or NOS. just get it done and show GM how they should have built this car "TURBO".
Please build this sucker up on turbo only for now. and thank you. later.
Old Oct 11, 2007 | 09:19 PM
  #554
well the meth is there to help out with some things. 1st thing being octane so I can bump up the timing a little more and don't have to worry really about detonation, plus if you saw my exhaust parts when they came off the car or my exhaust ports on the head.... No carbon what so ever. My plugs have always stayed clean and everything else, so it's definitely going back in. I'll dyno the car in 3 pulls, of course on 3 different tunes. one on 16 psi and decent timing, one on 18 psi and more timing and the 3rd on meth and 21 psi
On a side note, I would not recommend running over 17-18 psi on the stock fuel system I've been seeing some iffy things in my logs at higher rpms. I'm waiting to dial it in more tomorrow first.
Old Oct 11, 2007 | 10:24 PM
  #555
Kennyspec's Avatar
thinking of going to a return style setup?
Old Oct 11, 2007 | 10:46 PM
  #556
that I am
Old Oct 11, 2007 | 11:21 PM
  #557
victory_red_SS's Avatar
LSX RWD S/C conversion
that I am
Good plan.
I eagerly await updates.
Old Oct 12, 2007 | 12:26 AM
  #558
Kennyspec's Avatar
Are you also gonna use a 1:1 increasing rate regulator so that fuel press will be a constant value above manifold pressure? To simplify things what about using the EVAP line as a return lol?
Old Oct 12, 2007 | 07:19 AM
  #559
nah gonna replace the lines with some nice -6 an lines and fittings. Just trying to figure out how the computer will react, and what to do with the evap setup
Old Oct 12, 2007 | 08:21 AM
  #560
skymynx's Avatar
? for you paul. saw you got a fuel pressure guage on the car so im curious what the fuel pressure is on our cars. trying to figure out what jet to get for my nitrous setup. what are you planning to do with evap setup?
Old Oct 12, 2007 | 08:27 AM
  #561
base fuel pressure on my car is @63psi. But I've been seeing it start to drop and the car lean out a bit up top. Gonna work on that today to see if it's just something in the tune or not. I'll post up results either tonight or tomorrow depending on when I get home
Old Oct 12, 2007 | 08:31 AM
  #562
skymynx's Avatar
thanks man. yea i figured it was pretty high. good luck tuning. cant waiit to see ur dyno results. any updates from CA about releasing this kit?
Old Oct 12, 2007 | 08:32 AM
  #563
in a few more weeks it will be released. Just waiting on me to finish the base tuning maps, and after I dyno on the 21st it shouldn't be long after that
Old Oct 12, 2007 | 08:46 AM
  #564
skymynx's Avatar
glad to here that. cant wait to see what there gonna end up offering. good luck on the 21st. hoping to see some big numbers
Old Oct 12, 2007 | 08:53 AM
  #565
Edubs's Avatar
Yeah, can't wait to hear the results...
Old Oct 12, 2007 | 09:05 AM
  #566
I'm hoping for at least 375 whp and 350 wtq. But we shall see.
Old Oct 12, 2007 | 09:07 AM
  #567
Edubs's Avatar
You doing this on Matt's dyno?
Cause if you are, you'd only have to hit 326/304 on his...
Old Oct 12, 2007 | 09:09 AM
  #568
SSdan's Avatar
I belive he's using Kennys dyno. Dynojet
Old Oct 12, 2007 | 09:11 AM
  #569
Edubs's Avatar
Oh, neat-o...
Blow it out ur pooper Mr. Smartypants!
Old Oct 12, 2007 | 09:43 AM
  #570
SSdan's Avatar
That reminded me of the Ludacris song Blow It Out Your Ass
Old Oct 12, 2007 | 11:44 AM
  #571
lol no going out to NRG TEC in LI, not sure which dyno they have though
Old Oct 12, 2007 | 11:47 AM
  #572
Edubs's Avatar
NRG Whaaaaaaaaaaaaaaa???
Eh, who cares anyways. As long as you have M62 equipped graphs from the same dyno, you can make comparisons no prob...
Old Oct 12, 2007 | 11:58 AM
  #573
iLLmaTic3s's Avatar
nrg..ah the honda guys, rite?
Old Oct 12, 2007 | 01:35 PM
  #574
yeah can';t pass up pulls with afr for 50
Old Oct 12, 2007 | 01:37 PM
  #575
iLLmaTic3s's Avatar
god damn..thats amazing..wish i knew bout this..wud of dynoed...mad cheap
