engine finally gave
Old Dec 12, 2011 | 09:02 PM
  #51
Chevycobaltss3's Avatar
Lol fun times
Old Dec 12, 2011 | 09:54 PM
  #52
MyOtherSS's Avatar
That sucks about your motor. Hopefully it's less serious than it appears. Off topic quiestion... do you have the g85 package? I wanna run a tvs but have an open diff so idk if its worth it.
Old Dec 13, 2011 | 12:39 AM
  #53
carstedt's Avatar
nope no lsd...i spun alot but i was on street tires i didnt have a radial or nething but its def worth it
Old Dec 13, 2011 | 09:19 AM
  #54
Blowncavy's Avatar
Originally Posted by Chevycobaltss3
Lol fun times
Haha,
Calm your ass down. Seen he was tuned by you so I had to say it.
Old Dec 13, 2011 | 11:29 AM
  #55
So your just trollin? Well that must be fun.. and when I see disrespect which is all you show I have to say somthing. He sidnt pop from the tune. He flowed 57maf lbs and ve was somewhere around that area if i remember correctly. So it was prob to much.... [QUOTE=Blowncavy;6203242]Haha,
Calm you ass down. Seen he was tuned by you so I had to say it.[/QU
Old Dec 13, 2011 | 12:05 PM
  #56
Blowncavy's Avatar
Don't confuse disrespect with being an honest person. That's what I have shown you
Anyways, sorry to hear about your engine. Atleast you'll be building it now..
Old Dec 13, 2011 | 12:10 PM
  #57
N1ckateen's Avatar
if it was all in the tune as to what popped his engine then why haven't i popped yet? My tune is based on Carsteds tune and I drive over 100 miles a day and my car runs perfectly fine.
Old Dec 13, 2011 | 12:36 PM
  #58
Actually all you have done is disrespect. Coming into threads and trolling my guys or myself so what you said is pure idiotic and disrespectful. I know what im doing and ive been around for quite a while in the tuning/ custom builds. So yes Ure pure disrespectful. You dont know me, nor my tuning, and ops engine is somthing that happens when your pushing the stock engine lol.....
Old Dec 13, 2011 | 01:00 PM
  #59
Mobile Chassis Dyno's Avatar
I feel your pain. It is always the tuners fault regardless of how much power the car makes and/or how inadequate the fuel system is.
Old Dec 13, 2011 | 01:04 PM
  #60
Lol ops not blaming me.this kid is lol.
Old Dec 13, 2011 | 01:40 PM
  #61
I know this.
Old Dec 13, 2011 | 05:51 PM
  #62
Ok lol...
Old Dec 13, 2011 | 05:59 PM
  #63
InfraRedline's Avatar
You say flowing 57lb/min. I assume the stoich was left at 14.7, am I correct? Not that I think its right or wrong, just getting some numbers down.
Old Dec 13, 2011 | 06:00 PM
  #64
turbocharged717's Avatar
**** happens sometimes.
Old Dec 13, 2011 | 06:19 PM
  #65
brian.olsson's Avatar
I was thinking the rings at first, but now Chevycobaltss3 and a few other posts, and what his car is doing, I"m thinking its just carstedt's head gasket, the engine has no knock, I read one post talking about the dipstick poping out cause of a bad batch of head gaskets causing it under boost, and it smokes really bad out the exhaust, oh and 25lbs of boost with no head studs, and it could have spiked over that. the more I'm thinking now, the more a blown head gasket makes sense, hmm, could it be up and running by the weekend,
Old Dec 13, 2011 | 08:11 PM
  #66
No.. from the logs I seen back when I last tuned him I remember seeing. 47 maf lbs and I couldn't get his afr down do the fuel system. The log showed 13.2 ion the top of fourth. His duty cycle was 159% so I asked him to get. A referenced fuel system so we can get it down. He's on e85 and Meth which is why I was able to get where I had it. I was just waiting on the text or call saying it was installed so we can tune... I assumed he popped because he never did the reference fuel system so we can get his idcs down and if need be use. 1000 cc injectors. It never got far enough as you can see.
BTW I meant 47 but apparently my phone thine its cool to **** on my finger.. I mean he might have pushed 50+ but I don't remember on top my head. Since we've tuned it a couple times for differenct setups.
Old Dec 13, 2011 | 08:16 PM
  #67
carstedt's Avatar
wot it starved for fuel but if i didnt get on it more than a shade ovr 1/2...ik fuel wasnt the issue on the runs my interceptors read fine and my afr was straight
Old Dec 13, 2011 | 08:19 PM
  #68
If no kr the only thin I'm shooting at is do a comp test along with a leakdown test if compression test is good. You'll find the cylinder
Old Dec 13, 2011 | 08:23 PM
  #69
carstedt's Avatar
ya i will were taking it over to the garage tonight where well start taking it apart and doin tests
Old Dec 13, 2011 | 08:28 PM
  #70
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
samething happen to me,motor still running strong.I replaced the intake manifold gasket with the updated one,problem solved!!
this is the PIP from GM. yes I'm a GM tech!
#PIP3983: Oil Leak From Top Of Dipstick - Replace Intake Manifold Gasket - keywords accel acceleration CEL crank crankcase dip engine excessive hard high MIL P0171 pressure repeat SES stick WOT - (Nov 16, 2006)
Subject: Oil Leak from Top of Dipstick
Models: 2005-2006 Chevrolet Cobalt SS
2004-2006 Saturn Ion Redline
with 2.0L Engine (VIN P - RPO LSJ)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
On rare occasions, the engine oil dipstick may become unseated on hard acceleration, resulting in an engine oil leak. If the engine is operated long enough like this, a P0171 DTC could set due to the engine ingesting unmetered air.
This concern is the result of excessive crankcase pressure on hard acceleration. This crankcase pressure may be the result of an intake manifold gasket concern that allows supercharger boost pressure to bypass the intake manifold gasket where it seals around the PCV orifice, which is between the #2 and #3 intake runners.
Recommendation/Instructions:
If the SI diagnostics do not isolate a cause for this concern, replace the intake manifold gasket using part number 12597855, which contains an updated sealing surface around the PCV orifice. This part number, or any future part number, is designed to address this concern.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Old Dec 13, 2011 | 09:28 PM
  #71
I don't think its the intake gasket, I checked the oil today and it has gone up a little now, and has a faint smell of dexcool, but we will know more once we get it to the garage. We should know what happened to it for sure tomorrow night. I"m hoping its only the head gasket.
Old Dec 13, 2011 | 09:30 PM
  #72
Area47's Avatar
Rent me! per hour
you can crank over 30psi on the stock head gasket. i hit 32psi at 8100 rpms on a 2.5 pulley with stock head bolts. didn't lift the head or pop anything.
there is an underlying issue somewhere else that needs addressed.
Old Dec 13, 2011 | 09:42 PM
  #73
I'm not saying that it is for sure just the head gasket, I can't say anything untill its tore down, I'm just saying all the signs of a blown head gasket are their, coolant in the oil, runs rough, and blows a nice big whit cloud of smoke out the exhaust. yes, their could be more wrong, but those are the thoughts right now, and if more is found wrong, they will be fixed, or whatever carstedt wants to do with it.
Old Dec 13, 2011 | 09:58 PM
  #74
Needs moar crankcase ventilation/evacuation?
Old Dec 13, 2011 | 10:04 PM
  #75
Do a comp test and let me know.. Id like to be informed.. Sounds like sleeve or headgasket if theres coolant in the oil!!
