engine finally gave
Old Dec 13, 2011 | 10:15 PM
  #76
LS6Rally's Avatar
ami reading this correctly? the OP saying you were racing at half throttle? please tell me i read that wrong. i wont flame you for blowing up your motor cause your not making up excuses, but im sure you'll be better about running the car hard when you know it cant handle. good luck with your new build
Old Dec 14, 2011 | 02:54 PM
  #77
carstedt's Avatar
no i usually run it wot open but this particular race i didnt give it all the way cuz the evo was slow to begin with and i knew i didnt have enough fuel up top so i just gave it a little more than half and still had enough to run away from him
Old Dec 14, 2011 | 11:30 PM
  #78
brian.olsson's Avatar
These are the four codes that I pulled off the computer,
I pulled the plugs to do a compression test, and yeah number one isn't looking so hot, and the compression test confirmed it, cylinder 1, 0psi, cylinders 2-4, all around 180psi
pulled the couple from the intake to the Throttle body, and it had a little oil inside it, than pulled the supercharger, all clean on the inside, and still looks new
Looked down in the intake manifold, and their is some oil sitting down their, tomorrow I'll get his intake and head off and see just how bad number one really is, I looked down their a bit and from what I could see it has some oil built up inside it, and the other three are a little drier, but we will see tomorrow.
Old Dec 14, 2011 | 11:40 PM
  #79
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
DTC P0135 HO2S Heater Performance Sensor 1
DTC P0141 HO2S Heater Performance Sensor 2
DTC P1182 Supercharger Inlet Pressure (SCIP) Sensor Performance
  #80
Chevycobaltss3's Avatar
What plugs are they? If u have coolant in oil it sounds like blown sleeve.. usually tips of the plug blow when it gets to lean or they are weak..... Or somthing hit it of course lol. Keep me posted ..
Old Dec 14, 2011 | 11:43 PM
  #81
Dude why are you using autolite iridiums? Bad bad idea 3294 autolite xp... This prob caused Ure issue. there.grounding straps are weak as Hell. Ecspecially with boost. And I've seen the grounding straps break mulitple times.includinga ship car that came to me from Ohio...
Old Dec 15, 2011 | 12:20 AM
  #82
They were autolite xp 3923, so yeah, it could be the sleeve, we'll know tomorrow when I get the head off, he's already got a nice built engine he's talking to a guy about, so he is really just waiting on me to figure out the route he's gonna go
Old Dec 15, 2011 | 12:58 AM
  #83
Lol well next time tell him not to do autolite bull ****. I've seen the issue with these autolites in a lot of tore up engines.
Old Dec 15, 2011 | 12:41 PM
  #84
freakta's Avatar
good luck keep us informed.
Old Dec 15, 2011 | 01:08 PM
  #85
mrbelvedere's Avatar
plug the pcv port in the head then run 2 -10 an bungs over to a catch can from the valve cover then youll never have to worry about oil in the intake tract what so ever
Old Dec 15, 2011 | 10:47 PM
  #86
Got the head off, carstedt was able to get off work early and helped finish the job, all in all, the sleeve looks fixable, but gonna take it to the machine shop and have them check it out, their dont seem like their is a hole, the water jacket is still holding the water back, just looks like when the piston melted it got all over the sleeve
Old Dec 16, 2011 | 12:52 AM
  #87
Leafydialupking's Avatar
I believe you're missing part of your piston, lol.
Old Dec 16, 2011 | 01:15 AM
  #88
InfraRedline's Avatar
I believe that statement to be correct lol
Old Dec 16, 2011 | 01:35 AM
  #89
06_SIC_SS's Avatar
if u decide to go built motor i have a good one for sale. goodluck with ur build and decision
Old Dec 16, 2011 | 08:22 AM
  #90
Sir that be part of the plug that exploded... I'm tell u guys it was the fact you used autolites lol that's not detonation and afr was good.. but wow.
Old Dec 16, 2011 | 08:59 AM
  #91
selfinfliction's Avatar
take off that POS tvs and put a turbo on it now
and make sure they look at the sleeve closely, it doesn't need a hole in it to be fucked up
Old Dec 16, 2011 | 09:07 AM
  #92
Yeah, I'm also thinking their was a little fueling issue too, and it did blow the seal on the head gasket a little too, so head studs, New fuel pump, and a rewire is going in too as well as what he does to the internals, gonna work on pulling the block this weekend and maybe get the block to the machine shop for him while he's on vacation. So we should be looking at a nice little monster when she's all back together
Old Dec 16, 2011 | 09:39 AM
  #93
dam you melted that one if you bore the engine just remember the sleeves are only .060 thick
Old Dec 16, 2011 | 09:57 AM
  #94
BLAZIN07SS's Avatar
I'm too JDM for you
[IMG]http://i779.photobucket.com/albums/yy78/mrbelvederphoto/myvcover.jpg[/MG]
i wanted to weld mine on like this but the wastegate would have been in the way of the lines. there is a ton of plastic in the valve cover as well underneath that little shield from the cam
Old Dec 16, 2011 | 10:10 AM
  #95
Well we know fueling was a issue lol since the stuff was added without being tuned.. but the was caused by the plug mainly.... Fueling helped it
Old Dec 16, 2011 | 10:35 AM
  #96
you can put one in the front and one in the back i set a v cover up like that for a friend
if you think the plug caused that then you are way off that piston is melted fuel got past the top ring then it was ignited fractured the piston when the piston fractures it starts melting because you expose the part of the piston that isent hardend so each time the fuel ignites a little more melts away all the shiney rough spots is from the strap of the plug being beat around inside of the cylnder
Old Dec 16, 2011 | 10:40 AM
  #97
Lol ^: u seriosuly are taking what I'm saying wrong... I said fuel played a major part but as did the plug...... I know what I'm talking about lol no need to chant somthing ...... Autolites don't Sparta correctly which is a known issue with themso there for cylinder wash. Which then causes issue above lol.....
Cylinder wash with spark= boom....
Last edited by Chevycobaltss3; Dec 16, 2011 at 10:40 AM. Reason: Automerged Doublepost
Old Dec 16, 2011 | 10:52 AM
  #98
excatly what I was thinking,
Old Dec 16, 2011 | 10:53 AM
  #99
BLAZIN07SS's Avatar
I'm too JDM for you
i'm sure you have seen my valve cover. one on the back of the valve cover and one coming off the oil cap. all -10AN
Old Dec 16, 2011 | 11:05 AM
  #100
if you think the plug caused that then you are way off that piston is melted fuel got past the top ring then it was ignited fractured the piston when the piston fractures it starts melting because you expose the part of the piston that isent hardend so each time the fuel ignites a little more melts away all the shiney rough spots is from the strap of the plug being beat around inside of the cylnder[/B][/B]
so, your aggreeing with what chevycobaltss3 just said, just don't want to admit it is all,
