engine finally gave
Ecotec 4340 Connecting Rods
Forged and Coated Piston's
Darton Sleeves
zzp Stage 2 cams and Springs
Netrual Balance Shafts
Aeromotive Stealth Fuel Pump
Possibably the dual pass intercooler end plate kit
euthanasia
Ported head and intake, and new valves
The block machine work will be done by a shop out here, gonna have them deck it and check it all out, haven't decided if were gonna have the shop final assemble it yet or not, And than of course clean up under his hood once she's sitting back inside, gonna reroute the valve cover breather to a catch can, and rerun some wireing to hide it a little better
ZZP
Darton Sleeves
euthanasia
Darton Sleeves
euthanasia
actually a video on facebook under smokeys dyno.. scroll down a couple pages and itll be there. black car. made 362 on that dyno on only 14 degrees of timing and a big air restriction.. first time i had the kit together. had to adjust a couple things. ran it on the dyno a few weeks later at a different place and ran a 50 shot through it once. had no problem picking up bigger power turning 8000 plus RPMs and making 460
hmmm i wonder wut itd make on a tvs 2.6, e85 and meth...damn this is tempting now id jus hate to have a second engine and i have brand new cams and springs sitting in the garage lol
can always return or resell. and i have confidence it could be in the 380 range if not higher spnning it hard
honestly anything ud ever wanna do to ur motor for an SC build is in the motor.
add a return system and id1k injectors with a modded 255 pump you can hit 400whp with what is listed. add a port matched intake manifold to that list.
hitting 380whp on stock cams is possible, just have to lean on the motor really really hard
it wouldnt be on stock cams the engine he has for sale is stage 2 and i also have stage 2 cams ready to go in the head i have already...id like to hit 400 i have 1000cc injectors and a aeromotive fuel pump with the zzp boost refrence fuel system as well
ya i like being different cuz the sc's are under estimated but i still lean towards throwing a turbo on it once in awhile lol..hopefully i can get it to break 400
didnt realize u had that kind of fuel system. u r right on the cusp of 400. lemme know what u wanna do. the price in my thread is shipped. then uu can resell ur cams and make some back even. motors already broken in. drop in and go. or blast in this case lol
and itll be cheaper than going any other route too at that price
lol ya i was getting ready to start making sum good power on the old set up but i just might take u up on urs...im still pricing sum things out on mine deciding which way to go..400whp would be pretty nasty i think in a sc
or gettin rid of it
