Installing Euthanasia Ported & Built Head. TONS OF PICS
Old Mar 18, 2013 | 02:24 PM
Hockeyman's Avatar
After 3-4 years of running the typical 2.8/60's setup, I wanted more reliable power. Power with this setup dyno'd 270whp and 250wtq. ZZP LTH, 2.8/60s/cooling mods, 3" intake, 2.5" exhaust, area47 tune, gmpp clutch w/fidanza flywheel.
After months and months of sourcing/collecting parts, I sent a bare head to Euthanasia to have the exhaust side ported/gasket matched. Sent him COMP/ZZP S2 Cams, Supertech 75# Valve Springs, stock valves, and he also hot tanked, decked, and assembled everything for me. I picked up a ported LSJ IM while I was at it from zrated which was also installed.
Finally got everything installed over the weekend as well as 80# injectors. Converted to e85 too.
Parts pile
Blower was the first to come out, all 4 SC bolts decided to strip as well which was fun.
Removed IM and valve cover next
First time the valve cover has been off the car, it was very clean for 76k miles.
Off with the timing cover
And off with the stock head. We got lucky and were able to wiggle the ZZP LTH off without having to remove it.
More to come next post
Old Mar 18, 2013 | 02:26 PM
Hockeyman's Avatar
Cylinders looked great!
Euthanasia's port job, came out beautifully
Old head to compare
Old Mar 18, 2013 | 02:30 PM
Hockeyman's Avatar
Cleaned the block:
ARP Head studs:
Nea head installed:
Time to time it!
MANPOWER! Thanks to Vaughn (Japeatr) for all the help.
We are still working on the tune, and dyno will come shortly thereafter.
Old Mar 18, 2013 | 02:33 PM
Hockeyman's Avatar
Total time spent - about 16hrs + tuning. Install went smooth with no issues whatsoever
Old Mar 18, 2013 | 02:36 PM
Staged07SS's Avatar
Administrator
Administrator
Awesome stuff man!!
Old Mar 18, 2013 | 02:44 PM
EXsoccer1921's Avatar
that'll be a nice increase in power. especially with the ethanol.
Old Mar 18, 2013 | 02:50 PM
thedubsack85's Avatar
Sweet! In for more vids and numbers!
Old Mar 18, 2013 | 02:55 PM
yellowsupercharged06's Avatar
sick, in for numbers
Old Mar 18, 2013 | 03:32 PM
jonathan923's Avatar
subd looks great!in for results
Old Mar 18, 2013 | 03:41 PM
Hockeyman's Avatar
I hope so, trying to see what I can push out of the girly m62 before I upgrade. May pulley down to a 2.6 or 2.7 depending on what numbers I hit.
Old Mar 18, 2013 | 03:50 PM
Bluelightning's Avatar
Got Bewst?
With the head and cam choice you won't be on the M62 for long.
Old Mar 18, 2013 | 04:08 PM
Hockeyman's Avatar
If I can be in the low 300whp range, I will be perfectly content with that for the time being. Upgraded blower will come soon, but balancing the cobalt with my other project car took away all my funds.
Old Mar 18, 2013 | 04:12 PM
Got Bewst?
What do u plan to spin the motor to?
Old Mar 18, 2013 | 04:13 PM
Hockeyman's Avatar
7800 is the plan.
Old Mar 18, 2013 | 04:16 PM
JapEatr's Avatar
South Central *********
those pics turned out well
glad to see my manpower shirt made the cameo!
Old Mar 18, 2013 | 04:19 PM
Hockeyman's Avatar
No doubt! It definitely made the cut. I have 75 pictures total.
Old Mar 18, 2013 | 04:22 PM
JapEatr's Avatar
getting the timing nailed with the new cams was fun, no snags and just need some time on the tune and it will be rockin
Old Mar 18, 2013 | 04:25 PM
Hockeyman's Avatar
You are the cobalt ninja
Old Mar 18, 2013 | 04:26 PM
DarkChild's Avatar
In for some numbers. I'm currently working on getting my head back together after my pnp. I'm debating on camming it or not.
Old Mar 18, 2013 | 04:33 PM
JapEatr's Avatar
I cant believe those are from your phone! Pics turned out pretty good
Old Mar 18, 2013 | 04:37 PM
DarkChild's Avatar
He must own the S3. Lol
Old Mar 18, 2013 | 04:40 PM
Tjolley's Avatar
All the pics in my thread r from my phone..
Area47's Avatar
Rent me! per hour
i forgot to send you monkey's some tuning goodies this weekend
whoops, sorry bout that.
nice to see you finally get bored with what you had and actually do something!
Old Mar 18, 2013 | 04:51 PM
Hockeyman's Avatar
pics from iPhone 4S
Old Mar 18, 2013 | 04:52 PM
574's Avatar
574
in for numbers
