Le Riceburners OFFICIAL Build Thread
Old Mar 29, 2014 | 11:22 AM
  #851
I
Turns out we did that the throttle and ign plugs switched i should have noticed since we had to lengthen the wires to make the tb plug fit
Old Mar 29, 2014 | 11:59 AM
  #852
TStone's Avatar
You're welcome
Old Mar 29, 2014 | 12:25 PM
  #853
Im not getting spark it still wont start... no codes now but it just keeps cranking even spraying ether through the TB
Old Mar 29, 2014 | 12:37 PM
  #854
BlackielawlessSS's Avatar
That is usually a sign of epic boom awaiting.
Old Mar 29, 2014 | 01:12 PM
  #855
So im thinking it could be that we blew the ignition relay.
Lsjion said could also be a fuel injector fuse too
And i should have done the timing thing this way
First try pulling the cps sensor plug see if it starts. If not...
Pull cyl 4 spark plug
Compression tester in
Rotate crank till it starts to build pressure
Pull tester fitting, put in socket extension
Rotate crank to TDC
line up hex mark on sensor to the housing mark
Reinstall
Old Mar 29, 2014 | 01:19 PM
  #856
TStone's Avatar
Yes that's the best way to time the cam sensor
Old Mar 29, 2014 | 05:33 PM
  #857
lsjion's Avatar
Fixed!
Old Mar 29, 2014 | 05:55 PM
  #858
mrbelvedere's Avatar
Old Mar 29, 2014 | 07:20 PM
  #859
Aaand it runs! Muhauahuahahahah!!
Uploading vid now...
So yeah we did the cps thing just like i said above, and it fired right up
Runs great, holy ****!
Filled the fluids, etc, plumbed the intercooling system, found out that my pump is out (iat2 got to 150+ )
Held revs at 2k for a minute, never revved over 4k, then around 10-15 mins after running it i took it around the block with no headlights
Drives sweet! Went through all the gears no problem. Pulls really hard to the right so i gotta reprimend that...
Oh and vacuum was setting around -10 at idle. Is that bad??
Old Mar 29, 2014 | 07:48 PM
  #860
i am a happy camper
This is with open downpipe... exhaust vac is not hooked up yet either
Cobalt ss/sc first start up w cams:
Old Mar 29, 2014 | 07:58 PM
  #861
Piston3's Avatar
Glad to hear you got it running! That lope!
Finished my install today and everything is good. No boom boom haha.
Old Mar 29, 2014 | 08:04 PM
  #862
Sounds good!
Old Mar 29, 2014 | 08:09 PM
  #863
Good deal!
Old Mar 29, 2014 | 08:27 PM
  #864
Boostin15's Avatar
Nice!
Old Mar 29, 2014 | 08:36 PM
  #865
lsjion's Avatar
Sounds great!
Old Mar 29, 2014 | 09:23 PM
  #866
Dat lope! Awesome work Adam!
Old Mar 29, 2014 | 10:22 PM
  #867
Bluelightning's Avatar
Got Bewst?
That's where my vaccum sat at idle with those cams. Normal. Glad to hear it runs!
Old Mar 29, 2014 | 10:39 PM
  #868
vacuum should set around 15inhg my customs set at 12.8inhg 10inhg is low for those cams
Old Mar 29, 2014 | 10:48 PM
  #869
where is the use the search button mr b? You are slacking on me...
Old Mar 29, 2014 | 10:49 PM
  #870
574's Avatar
574
Nice sounds great
Old Mar 29, 2014 | 11:11 PM
  #871
06cobaltncng's Avatar
sounds sick as hell
Old Mar 30, 2014 | 12:38 AM
  #872
Hes never told me to search
Thanks guys! Im so excite!
Old Mar 30, 2014 | 01:31 AM
  #873
Got Bewst?
I thought the same also when I started mine for the first time. Went through the whole set up several times, even when I changed motors it never changed. Talked to quite a few others who were at the same so I let er eat.
Old Mar 30, 2014 | 09:55 AM
  #874
it is what it is mine held 16in on zzp stg2 cams
Old Mar 30, 2014 | 09:59 AM
  #875
What are the typical gains in hp/tq on a build such as riceburners mr b?
