Official Turbo LSJ thread!!!
Old Mar 1, 2013 | 11:32 PM
  #4376
mrbelvedere's Avatar
its not a half attempt there is nothing wrong with using the stock manifold
Old Mar 1, 2013 | 11:40 PM
  #4377
c130aviator's Avatar
well i cant speak for what I havent done but I think a tidier package would be a tvs on the stock laminova setup. pick your pulley and fuel and live long and happy with the TVS.
Old Mar 1, 2013 | 11:42 PM
  #4378
mahfouzman's Avatar
That's what I was originally planning on doing, but I've driven a few supercharged cars and never a turbo car, something new I guess haha. And yes I agree, I think it's actually pretty convenient to use the stock manifold, at least for someone who isn't planning on making 400+hp, and even then I don't think the stock mani would be a restriction.
Old Mar 1, 2013 | 11:45 PM
  #4379
you know man, you could be pioneering a new way, the forum is full of new ideas, build and see what comes of it. worst that could happen is you need to get some more piping and an intercooler later on.
Old Mar 1, 2013 | 11:50 PM
  #4380
mahfouzman's Avatar
Haha that's exactly what I was thinking man, I want to see what this kind of build would be capable of and if it'll run efficiently. If all goes well then this could be the best solution for the money. And definitely, if I see my IAT2's way over what they should be I could get an ic later.
Old Mar 2, 2013 | 12:02 AM
  #4381
zrated89's Avatar
its not pioneering the fitst turbo setups ran this. iirc paul was one of the first to do it
Old Mar 2, 2013 | 12:17 AM
  #4382
mahfouzman's Avatar
Well how did it work out for him? Btw, would the ZZP Ecotec Turbo Downpipe work on a T04e turbo with a vband?
Old Mar 2, 2013 | 08:56 AM
  #4383
it worked well enough for him to make over 400hp
Old Mar 2, 2013 | 06:32 PM
  #4384
nwss's Avatar
What's the trick to getting the turbo tight af on the mani? I thought it was good but I guess not and it's a tight area haha
Old Mar 2, 2013 | 06:48 PM
  #4385
slide the hot side up first since its smaller than the compressor than wiggle the compressor around until it leaps over the rack and pinion, rotate anyway neccessary to get it to kind of CURVE over steering and sway bar in that area. Took me a minute but it will fit.
Oh I have a different turbo than you though. Still big though.
Old Mar 2, 2013 | 08:36 PM
  #4386
SylverSS/SC's Avatar
Where does the oil feed line connect to the block?
Old Mar 2, 2013 | 09:55 PM
  #4387
USMCFieldMP's Avatar
Rattlesnake Race Shop
The best source to use is one of the Oil Galley plugs on the back of the block behind the Coolant pipe... notice the missing plug/hole.
Old Mar 2, 2013 | 11:03 PM
  #4388
ah okay. I was thinking that was a good place but was unsure. Thanks man!
Old Mar 2, 2013 | 11:34 PM
  #4389
i used the one directly under the compressor side of the turbo.
Old Mar 2, 2013 | 11:37 PM
  #4390
and you went under and around the compressor housing to get the line to the oil inlet
Old Mar 2, 2013 | 11:38 PM
  #4391
yup and made sure it was routed away from exhaust/turbine/chra.
Old Mar 2, 2013 | 11:48 PM
  #4392
makes sense. no sharp bends
Old Mar 3, 2013 | 12:01 AM
  #4393
nwss's Avatar
Old Mar 3, 2013 | 12:16 AM
  #4394
zrated89's Avatar
some pics had to modify the dump tube and tig weld the 46mm flange on it for the waste gate. Pays to have fabrication buddies will start going on this week.
need to get another map sensor since i broke my tab to use on the tvs, also need to get the male end fitting to connect the feed line to the turbo housing. bung for oil pan will be here monday from treadstone, and ill be in business (haha after looking at this pic i realized the fitting is attached to the turbo in the baggy lmao)
Old Mar 3, 2013 | 12:22 AM
  #4395
thats the 6262 right? Man that thing is going to be awesome.
Old Mar 3, 2013 | 12:24 AM
  #4396
I also used a 45 degree -an elbow off the block to aim the oil feed line away from the turbo
Old Mar 3, 2013 | 12:31 AM
  #4397
zrated89's Avatar
yea man shes gonna rip
Old Mar 3, 2013 | 12:32 AM
  #4398
zrated89's Avatar
sidenote just turned 30 im old -_-
Old Mar 3, 2013 | 12:34 AM
  #4399
what kind of power are you looking to make daily driving? I made 420 but daily between 19-20 psi (400 whp) depending on ambient temps.
  #4400
mahfouzman's Avatar
About how much psi would I need to be running to achieve a power/torque goal in the low 300s? 16? 18?
