Official Turbo LSJ thread!!!
Old Mar 3, 2013 | 10:47 PM
  #4426
SylverSS/SC's Avatar
Guess ill have to modify my crankcase venting system as well
Old Mar 4, 2013 | 05:58 AM
  #4427
USMCFieldMP's Avatar
Rattlesnake Race Shop
thats a good point, I havent had any crank case issues with my new setup (case under vacuum with an oil catch can) but I want to put a pressure gauge in there to see if my case is always under vacuum or if I need to do more to vent. right now I dont have any issues at 20 psi daily.
[IMG]http://i111.photobucket.com/albums/n147/c130aviator/cobalt%202012/44328202-74df-4a81-a841-2b504684fb13_zps3b82630d.jpg[IMG]
I do want to move up to a larger opening but this ebay setup cost me 15 bucks plus 6 dollars at oreillys for the brass 3/8 npt fittings for the intake and VC.
Definitely bump up the size. I'm going to go either -10an or -12an.
It's a must really. I'm very much against VTA, as well. That doesn't fix anything.
Old Mar 4, 2013 | 08:33 AM
  #4428
c130aviator's Avatar
un-metered air aka VTA can mess with your AFR.
Old Mar 4, 2013 | 08:44 AM
  #4429
I'm guessing just adding a catch can wont do much right?
Old Mar 4, 2013 | 10:22 AM
  #4430
mrbelvedere's Avatar
nope
Old Mar 4, 2013 | 05:30 PM
  #4431
ok guys think i have a bad WG..
I cant seem to boost over 10 psi today. Went to the tuner and had him fix a couple hiccups I was having at part throttle. But we could not get the car over 12 psi this morning. Today I pulled the MBC and hooked the lines directly, I have a 15lb spring, It wont boost over 10-12 psi. Pulled the lines completely off the turbo and wg to vent to atmosphere. Creaped up on boost cause I know it was uncontrolled, still 10 psi.
Secondly I pulled the bumper off, and checked every hose clam and every tube, every corner of the intercooler. Gonna do a pressure/smoke test to be sure but there is no leaks later this week. The car feels great, makes power all the way to 10 psi then struggles. However revs to 7500 like a beast. Still feels fast but wont boost over 10. What gives gurus?
Think its the wg spring or diaphram crapping out on me?
See klutch, everyone has problems from time to time. I am just glad this time its not my block. Oh pulled the plugs, they looked awesome, (firing end is browned/tanned ceramic) proper ignition.
500 miles on the new block turbo build. Going to change the oil soon.
Old Mar 4, 2013 | 05:44 PM
  #4432
According to a local guy up here, turbos will only hit certain boost levels due to altitude. Hahahahaha funniest thing I ever heard.
Sounds like it would be a spring or diaphragm but I'm not an expert
Old Mar 4, 2013 | 06:08 PM
  #4433
zrated89's Avatar
started putting her together today. Got the front mount on and crash bar modified, cold side all done and ran. Manifold bolted up, hot side ran, retimed my motor and installed my stock cams back in the car. Also removed all the oem idler components to do the lnf alternator and tensioner assembly with belt. Would have got alot further but timing her up took a little bit and its ******* freezing out lol. Tomorrow she should be all done. Although i got a -10an weld in bung from treadstone for my oil pan that came today and the return line ryan was running is smaller. Ill have to get another bung and need a new map sensor since i had to break my mounting tab off when running the tvs
Old Mar 4, 2013 | 06:17 PM
  #4434
sick man, hahns piping is by far the best look for our cars, keeps it so sleeper. LOVE!
Now someone answer my question about my wg issue lol
Old Mar 4, 2013 | 06:31 PM
  #4435
zrated89's Avatar
yea man clean oem look. Do a pressure test first if that checks out ok replace waste gate
Old Mar 4, 2013 | 08:16 PM
  #4436
looks good kenny
Old Mar 4, 2013 | 08:42 PM
  #4437
zrated89's Avatar
thanks brother
Old Mar 4, 2013 | 09:04 PM
  #4438
klutch814's Avatar
looks good man!
Old Mar 4, 2013 | 09:28 PM
  #4439
zrated89's Avatar
thanks man if i source this AN fitting tom locally and grab three more 3in tbolt clamps shell be running tomorrow
Old Mar 4, 2013 | 10:29 PM
  #4440
mahfouzman's Avatar
Where did you guys put the MAF sensor? Can I just keep it in my stock intake and just extend the intake to reach the turbo? Or does it need to be near the throttle body?
Old Mar 4, 2013 | 10:34 PM
  #4441
i have the hahn turbo pipes, MAF is behind driver light before TB after intercooler. need a pic? look at the last pic of zrated's car.
Old Mar 4, 2013 | 10:44 PM
  #4442
mahfouzman's Avatar
Oh okay so then it would probably be fine where it is now right? Unless once the turbo spools the reading on the intake is different than the actual airflow going to the TB?
Old Mar 4, 2013 | 11:32 PM
  #4443
zrated89's Avatar
dude dont take this the wrong way but you have a lot of reasearching to do. Some of your questions i almost think your trolling or being smart.
Old Mar 4, 2013 | 11:47 PM
  #4444
BLAZIN07SS's Avatar
I'm too JDM for you
good, so i wasn't the only one thinking that
Old Mar 4, 2013 | 11:53 PM
  #4445
zrated89's Avatar
lol I mean really
Old Mar 5, 2013 | 01:19 AM
  #4446
EXsoccer1921's Avatar
needs to be post-bov. if you're using the stock lsj intake manifold and the stock sc air intake, which will now be your cold side coming up to the manifold after the intercooler. you can keep the maf in the same location.
come on guys. we all started somewhere..
Old Mar 5, 2013 | 09:51 AM
  #4447
dktgarlick's Avatar
Hey Blazin all your videos are from inside the car or just sitting in the driveway. you should post a video of you driving by so we can all hear what that exhaust sounds like. Im looking for a new sound... mine sounds too much like a honda with a knockoff flowmaster (Damn you funds)
Old Mar 5, 2013 | 10:08 AM
  #4448
hahn 3 inch man, I know its spendy but oh man it sounds so nice. no cat and no rasp for a 3 inch can be hard to achieve. Hahn got this one spot on.
Old Mar 5, 2013 | 11:17 AM
  #4449
mahfouzman's Avatar
Lol thank you man, I appreciate it...I'm really not trolling or anything haha, it's just this is my first time working with a turbo system and it gets a little confusing at some points, the little things mostly. But thank you again man
Old Mar 5, 2013 | 12:10 PM
  #4450
MP Cobalt's Avatar
Straight pipe it like i did mine
