Official Turbo LSJ thread!!!
Old Apr 25, 2013 | 05:12 PM
  #5176
jonathan923's Avatar
Originally Posted by zrated89
i have a 255 already. Modded as in increase the voltage? think it will flow enough without a return or increased line size?
when u gonna get down the track?
more like when are you posting pics or vids of your new setup!?
Old Apr 25, 2013 | 05:19 PM
  #5177
Area47's Avatar
Rent me! per hour
modded as in this
Modyfying a Walbro..... - evolutionm.net
Old Apr 25, 2013 | 05:59 PM
  #5178
armcclure's Avatar
Bryan why no love for the dw300?
Old Apr 25, 2013 | 06:03 PM
  #5179
Area47's Avatar
Rent me! per hour
i prefer to go with what i know and have used in the past with zero issues.
Old Apr 25, 2013 | 06:11 PM
  #5180
EXsoccer1921's Avatar
i apply the same logic to those allowed to tune my car.
Old Apr 25, 2013 | 07:00 PM
  #5181
c130aviator's Avatar
i have read those fail in a daily driven or non race weekend car. If I go with anything but my stock pump it would be the walb
Old Apr 25, 2013 | 07:03 PM
  #5182
Originally Posted by Area47
nice find.
Old Apr 26, 2013 | 07:44 AM
  #5183
armcclure's Avatar
Thats odd. Ive never heard that. I have over 30,000 mi on mine. Afik it's the only pump available to us warrantied on e85.
Old Apr 26, 2013 | 08:32 AM
  #5184
mrbelvedere's Avatar
yea that is odd
Old Apr 26, 2013 | 08:48 AM
  #5185
i can find it now, dont have time but there is a thread where like 4 people in a row said dw300 failed on them, one of them said it failed on prime. fwiw anyway
Old Apr 26, 2013 | 08:56 AM
  #5186
Gelladuga69's Avatar
It was one of ThexGovernor's threads. He had a dw300 that failed on him after a short time. Switched to something else from ZZP.
Old Apr 26, 2013 | 09:21 AM
  #5187
574's Avatar
574
Yep in the govs build thread. I have it and hope it doesn't fail ha
Old Apr 26, 2013 | 09:27 AM
  #5188
you can buy any electric part and have a failure ive seen were the wally 255 has failed plenty of people im sure the dw pumps have failed plenty also. they are mass produced so failures are going to happen
Old Apr 26, 2013 | 09:34 AM
  #5189
zrated89's Avatar
i actually talked to a buddy last night. He said do not run the walbro 400 on E because theyre failing on local people left and right. I suppose thats why walbro put that clause in there. Oh well thanks for the link bryan ill just use the 255 modded
Old Apr 26, 2013 | 09:53 AM
  #5190
MP Cobalt's Avatar
Has anyone changed valve springs with the head on the car please inform me how much of a bitch its going to be.
Old Apr 26, 2013 | 10:03 AM
  #5191
Bad-A-SS's Avatar
What was that baffle yall are talking about removing whenever I take the oil pan off? Which I am about to do
Old Apr 26, 2013 | 10:09 AM
  #5192
zrated89's Avatar
its the baffle that covers the oil pick up. the reason i told u to take it off, is if youre tapping the pan like u said, youll want to remove it to be able to clean everything really good. IIRC its like 5 torx bolts size 30 remove them and the metal baffle will come right out
if you have the kent moore cam gear holder, and the valve spring compressor its gravy
Old Apr 26, 2013 | 10:15 AM
  #5193
Bad-A-SS's Avatar
Oh ok thanks Kenny btw is there anything I should put on the fitting for my return line? On the end that goes into the oil pan
Old Apr 26, 2013 | 10:32 AM
  #5194
zrated89's Avatar
no it should be AN fittings so nothing is needed (if the fitting going into the pan that u tapped is npt, which it should be you can put a light layer of liquid teflon or pipe tape) only on the side that threads into the pan
Old Apr 26, 2013 | 10:36 AM
  #5195
Bad-A-SS's Avatar
Ok and I will need to do the same for the fitting that went into the galley correct? Also Kenny what kind of coupler do you have for your massive 4in ported s cover? Trying to find something
Old Apr 26, 2013 | 12:41 PM
  #5196
zrated89's Avatar
I have plenty of pics and vids on my fb im lazy to load them here lol. Find me Kenny graham
Old Apr 26, 2013 | 12:43 PM
  #5197
zrated89's Avatar
u said u have a crush washer on the galley fitting so nothing on those threads.
Right now im running just a screen over my inlet housing. Gonna build an intake. U will need a 4in to 3.5 in reducing coupler and run a 3.5 inch intake. A 4in wont fit and will rub. U can email zzp they said they would make one plug and play for a price, but i can do it cheaper
Old Apr 26, 2013 | 12:47 PM
  #5198
added you
Old Apr 26, 2013 | 01:38 PM
  #5199
zrated89's Avatar
yea buddy seen it accepted.
Old Apr 26, 2013 | 06:35 PM
  #5200
its a pain! I took it to a shop that had a pneumatic vavle compressor, had the head springs changed in 10 minutes. Used zzp 82 lb ers and titanium retainers.
