Official Turbo LSJ thread!!!
Old Aug 14, 2012 | 03:03 PM
  #2676
cobalttransplant's Avatar
i want to put the cobalt ss engine in my aveo does anyone know what i need?
Old Aug 14, 2012 | 03:07 PM
  #2677
SuperChargedMA's Avatar
Uhhh... I don't think you're in the right thread man... lol... but no, I personally have no idea.
Old Aug 14, 2012 | 03:25 PM
  #2678
BLAZIN07SS's Avatar
I'm too JDM for you
let me guess, this is your daily driver and you want it to work perfectly without a flaw?
Old Aug 14, 2012 | 04:33 PM
  #2679
jonathan923's Avatar
lol am speechless
Old Aug 14, 2012 | 04:36 PM
  #2680
Facepalm_IRL's Avatar
we already have an lsj in our cars so we never bother putting it into anything else. lol
Old Aug 14, 2012 | 06:38 PM
  #2681
BlkWdoSS's Avatar
It is possible, it has been done. Contact Jason Whitfield of Whitfield Racing, he done it so Im sure he would be able to tell you what all will and wont work and how to do all of it.
Old Aug 14, 2012 | 06:47 PM
  #2682
c130aviator's Avatar
My car has been on Jack stands for 3 weeks now. Really miss it. Its my DD but I am lucky enough to have two.
Old Aug 14, 2012 | 10:17 PM
  #2683
mexi_loco's Avatar
and I want to transplant a 17 year-old's vagina into my wife....it's good to want things....
Old Aug 14, 2012 | 11:54 PM
  #2684
wow...
Old Aug 16, 2012 | 02:26 AM
  #2685
I want a turbo'd LSJ cable of 400 whp (in time with fueling mods). Oh wait here it is. Got my parts in the mail today and worked on it from 9pm to 1am after work.
The intake filter is a dry AEM type, its beat but the inside is pristine. Going to replace this as soon as possible and detail the entire engine. It needs it bad.
The intake required me to remove my ingalls dampener, going to need rotated mounts. The boost controller is a turboxs with adjustable bleed valve, came with the kit. Its set for 20 psi. Will take it back to 15 before I get on it to check my wideband and hp tune.
Top of my turbo with the ceramic powdercoat, looks much cleaner than the rusted piece that came in the mail.
Finally everything was in tonight including the down pipe but I could not get pics, my phone died. I also need a bolt for my vband tube that houses the sensors. I will run out and get that in the morning.
Should fire the car up for the first time tomorrow morning. I will take a vid just for fun. I still have to put oil and coolant in it. Dont let me forget. HAHA
Old Aug 16, 2012 | 01:19 PM
  #2686
SCcobaltSS's Avatar
What are you doing about crank case pressure? I see your PCV is vented to atmosphere.
Old Aug 16, 2012 | 01:57 PM
  #2687
Its not adressed in the hahn kit, i dont believe.
Old Aug 16, 2012 | 06:20 PM
  #2688
Well i didnt get the car running, I am at the hospital waiting for my little girl to arrive! Cigars for everyone.
Old Aug 16, 2012 | 09:22 PM
  #2689
mexi_loco's Avatar
you will need to address that. and more than just slapping on a pcv breather filter. PCV system for lsj's suck. Check out blazin's or exsoccer's systems to get ideas for what needs to happen.
Old Aug 17, 2012 | 12:25 AM
  #2690
Just fired the car up for the first time. Couple things, I forgot to plug in my first 02 sensor so I know there is a code for that. I also have no readout for my coolant temp on my Dash or on my aeroforce. Where is the coolant temp taken from? There is some smoke coming from behind the engine at idle but not sure if that is the crap load of antiseize i used on exhaust componets and or the sticky copper gasket spray I used on everything as well.
I am a novice and a little gitty forgive the retarded sounds I make. Just very excited. Btw my wife is not in labor quite yet. We had a false alarm but I think she will be tomorrow.
Here is the funny vid of me starting my car for the first time.
Old Aug 17, 2012 | 01:07 AM
  #2691
rivaladore's Avatar
I got rtv crap all over the downpipe when I installed the turbo kit, got a little smoking when I started it up and eventually went away
Old Aug 17, 2012 | 01:11 AM
  #2692
I only had a second to play with it. Its not coming from the turbo itself, gonna have to inspect it in day light. I think the giant cloud of crap I got from punching it was my blow off valve releasing against the dirt in the driveway and blew dust all over the place. Scared the crap out of me the BOV is really freaking loud. Its a Turboxs H-RFL (really f'in loud acronym)
Old Aug 17, 2012 | 08:30 AM
  #2693
zrated89's Avatar
oh hai turbo dudes
Old Aug 17, 2012 | 08:56 AM
  #2694
Shhinneyyy
Old Aug 17, 2012 | 09:19 AM
  #2695
Originally Posted by zrated89
oh hai turbo dudes
only because your the fastest TVS lsj you wont get flamed too much on here
looking good man, BUT eventually you'll want a snail in there
Old Aug 17, 2012 | 12:34 PM
  #2696
Talked to Blazin, great guy got some good info from him. ZZP only uses a filter on their VC and so does Hahn. Not convinced that vacuum vs vent to atmosphere is a concern at 400hp and under (or under 24 psi).
I read your thread about your engine smoking and you ran your engine half empty oil. Did it end up being the PCV?
Old Aug 17, 2012 | 01:20 PM
  #2697
zrated89's Avatar
i already has plans for teh psssshhhh
gonna push the tvs as far as shell go, should be low 11s. Maybe throw a 50 shot on her to put her into the tens, then when im bored probably go with a 256et setup
Old Aug 17, 2012 | 01:22 PM
  #2698
zrated89's Avatar
i vent mine to the atmosphere with the zzp breather for the oil cap, and i even tested the theory that it causes u to run lean. The only time it would is under idle when under vacuum and even that didnt cause the afr to change. The time u need it is when the crank case in under positive pressure. (boost)
Old Aug 17, 2012 | 03:40 PM
  #2699
Perfect.disguise's Avatar
oh hai turbo dudes
Why, hello sir.
Old Aug 17, 2012 | 04:12 PM
  #2700
Thanks, going to keep an eye on it for now.
