Official Turbo LSJ thread!!!
Old Jul 18, 2012 | 04:54 PM
  #2426
c130aviator's Avatar
well i may need some help so I will start joining in on the thread conversation.
Subscribed
First question is where can i tap the block to get rid of Hahns oil solution.
Old Jul 18, 2012 | 06:30 PM
  #2427
jhaddock21's Avatar
picked up my car this morning and all i got to say is holy **** i love e85.
What's your fuel setup?
  #2428
EXsoccer1921's Avatar
theres three galleys in the back of the block.
Old Jul 18, 2012 | 07:34 PM
  #2429
BLAZIN07SS's Avatar
I'm too JDM for you
Injector dynamics id1000cc's
Return style fuel system with aeromotive pressure regulator. 43psi base pressure, 68psi WOT pressure.
Walbro 255lph fuel pump
Old Jul 18, 2012 | 08:58 PM
  #2430
Facepalm_IRL's Avatar
Got a question. Recently swapped over to turbo. Using the k04, (i'll explain why in a minute dont bash just yet) I ran my PCV line to my intake and the brake booster line to the cold side after my MAF. Brakes are stiff as hell. Did i run the lines wrong or what is the issue?
Reasoning for k04: Ii didnt choose this turbo for the power it makes, i chose this turbo for the manifold. I will be running the k04 to work out possible kinks and bumps in the road i may have until i can save of for the ZZP EFR. Why should the LNF's have all the fun with that beauty?
Old Jul 18, 2012 | 10:17 PM
  #2431
slvr 04 rl's Avatar
Are there people running full E85 with 80lbs, return style fuel system and I have the aero motive 340 pump. I have fully built motor and ported head with cams.
I haven't tried E85 yet with this set up cause I see everyone switching to 1000 cc injectors so I'm not sure if my fuel will support 24 psi
Or anyone know??
Old Jul 18, 2012 | 10:18 PM
  #2432
ItalianJoe1's Avatar
That's a sneaky way of putting your boost level in there
Old Jul 18, 2012 | 10:19 PM
  #2433
Or anyone know??
Yeah the 80's will be fine at moderate boost with a return line.
His setup is not even at 80% IDC right now, on 25psi and still being slightly rich. Leaned out properly and revving to 7400 it's probably still under 75%.
Old Jul 18, 2012 | 10:33 PM
  #2434
startingline05's Avatar
Or anyone know??
I'm on 80's and rsfs on e85. With the s256et on 27psi and my AFR floating around 12.1 @ wot my idc's were in the low 90's
So yes you should be able to.
Old Jul 18, 2012 | 11:02 PM
  #2435
slvr 04 rl's Avatar
Thanks for the replies. I didn't want to put e85 in and it not flow enough. I'll give it a try once I fix my suspension.
Old Jul 18, 2012 | 11:05 PM
  #2436
Matt M's Avatar
The brake booster line has to be connected to vacuum, meaning that it has to be after the throttle plate.
  #2437
mexi_loco's Avatar
i was starting to think you fell off the face of the earth miles
it's getting interesting how our builds are becoming strikingly similar.
Old Jul 19, 2012 | 02:10 AM
  #2438
BlkWdoSS's Avatar
Subscribed
are your referring to feed or return? feed comes from a galley plug that runs along the block just above the water pipe. return can be in various places. I suggest looking at ZZP install instructions. It outlines a few places that would be great for a tap and install.
Old Jul 19, 2012 | 03:18 AM
  #2439
Can u use it for the return, i yhink one is used by hahns already for oil pressure to the turbo.
Old Jul 19, 2012 | 03:20 AM
  #2440
Yes, for the return, zzp welds a bung into the oilpan, what does the lnf do with oil return?
Old Jul 19, 2012 | 09:56 AM
  #2441
Matt M's Avatar
LNF already has a return port in the lower section of the block.
Old Jul 19, 2012 | 01:45 PM
  #2442
So its only on the Gen 2 block. That is what i figured. Thanks Matt.
Old Jul 19, 2012 | 02:50 PM
  #2443
Matt M's Avatar
The boss is there on all of the blocks. It is just machined on the Saab turbos and LNFs.
Old Jul 19, 2012 | 02:57 PM
  #2444
does zzp have a solution for this other than the oil pan you sell with your swapped lsj kits?
Old Jul 19, 2012 | 09:51 PM
  #2445
Matt M's Avatar
If we are building a motor we can machine the hole in the block or drill and tap it. Otherwise, we just swap the pan.
Old Jul 19, 2012 | 09:56 PM
  #2446
Need to get your pan down the road or drill /tap my stock pan
Old Jul 19, 2012 | 10:39 PM
  #2447
slvr 04 rl's Avatar
Nope. It took me a while with my car. It's running good but someone hit me a few weeks back and did some damage to my strut and knuckle. And I've Been so busy with work.
If you need help with it, let me know! I heard about your issue, that sucks.
Old Jul 20, 2012 | 02:52 AM
  #2448
BlkWdoSS's Avatar
drill and tap, not difficult and better than a core charge
Old Jul 20, 2012 | 03:27 AM
  #2449
I like zzp stuff, but you are right. I have tap and die sets for small electronics but nothing big. Going to have to look into this. Gonna just get the kit on first though. I am already 1800 bucks into this...
Old Jul 20, 2012 | 08:13 AM
  #2450
mexi_loco's Avatar
gotta pay to play bro. This is not a cheap motor to turbo.
