Official Turbo LSJ thread!!!
Old Apr 14, 2013 | 09:39 PM
  #4926
rivaladore's Avatar
Originally Posted by dktgarlick
I am also on a stock clutch motor and trans. Pushing about 370hp and I just broke 154k miles
Good to see I'm not the only one with the stock clutch still holding. I feel like people think I'm lying when I tell them.
Old Apr 14, 2013 | 09:44 PM
  #4927
CCrunner84's Avatar
Originally Posted by mexi_loco
I was holding down vacuum just fine as well as boost when I had a crap load of leakage in my whip. The biggest way I could tell is that my car's AFR's were leaning out intermittently at idle. Not too mention my rpm's were jumping when it leaned out as well. Just saying...
Yea, vacuum wouldn't tell you anything, sensor is in the manifold behind the throttle body.
Old Apr 14, 2013 | 10:05 PM
  #4928
mahfouzman's Avatar
Oh wow lol...and I thought my car had higher mileage, I just broke 116k. So our engines are excellent at making large amounts of power stock then, on a turbo anyway.
Old Apr 14, 2013 | 10:10 PM
  #4929
EXsoccer1921's Avatar
for a while... and then rings will start to go. compression will fall. power will drop.. blowby will get worse. valves will get nasty..
Old Apr 14, 2013 | 10:16 PM
  #4930
mahfouzman's Avatar
Damn it, what if I were to keep the power around a cozy 320-340? :P
Old Apr 14, 2013 | 10:31 PM
  #4931
rivaladore's Avatar
As with anytime you mod a car and pushing 100+ more whp then stock. So far ive been impressed with what the stock components can handle. I do my oil changes when the oil life counter is around 30-35% and don't go into boost until the car is warmed up. it's only a matter of time, but the fact of the matter is if you treat your car right and go for a reasonable amount of power you don't need a stage 4+ clutch or a built engine with all the bells and whistles.
Old Apr 14, 2013 | 10:33 PM
  #4932
rivaladore's Avatar
You'll be fine, if you're not then you probably drive like a dick and deserve whatever happens.
Old Apr 14, 2013 | 11:16 PM
  #4933
mahfouzman's Avatar
Lol that's the last word I would use to describe my driving, my buddies describe me as the granny of the group :P I only push my car when I need to really, and even then I'm careful lol. And I'm also all about that meticulous maintenance, Royal Purple every time the counter gets down to around 40%, about every 3 months.
Old Apr 14, 2013 | 11:18 PM
  #4934
mahfouzman's Avatar
I can honestly say that I'm the only person I know that uses turn signals even :P Just a fun little tidbit :P
Old Apr 14, 2013 | 11:27 PM
  #4935
yeah if you stay in the lower 400s. upper 400s the parts can handle it. but for a much shorter amount of time before something fails. like matt showed with the lnf. it could be a small a window as 50whp whether that engine will last for 80000 miles or 8000 miles.
but i get what you're saying. gm definitely did it right with this engine. to be able to mod a car with a nice turbo setup and push 425whp on a stock trans without even opening the engine is pretty remarkable for a 4cyl.
clutch i would say is hit or miss. sure the driver plays a factor, but not as big of one as people think. torque and powerband are what's going to bring down it's life. the stock lnf clutch isn't bad.. but the fact people are hitting 420ftlbs by 4k rpms is just retarded for its life. same with the lsj. for the m62 it's fine. people don't make more than 270-280ftlbs even on the tvs. but when you go turbo if you're hitting 350-360 torque like that down low it will definitely shorten the life.
but a clutch is an item that there's a fine line to. longevity or holding capabilities. even on a stock car, in it's lifetime the clutch will need to be replaced. so the manufacturer has to put a clutch in that will have both as much holding force and longevity as possible.
Old Apr 14, 2013 | 11:31 PM
  #4936
c130aviator's Avatar
lol, if you are running a stock gauge, nothing on my car is stock. but it is still behind the trottle body or it wouldnt read vacuum properly as the tb shuts. Now I can tell you when I had a 2psi leak at the bov that it was showing up as 2 inches of mercury so your theory of not being in the equation is dead wrong but so goes the way of this forum.
Old Apr 15, 2013 | 12:22 PM
  #4937
MP Cobalt's Avatar
Well I got from ZZP and found out while I was there that I had water in my intercooler pipe right by the MAF sensor. Any ideas how the F water got in besides the car sitting all winter and condensation? So basically I didn't get numbers I wanted up there and they were in a rush because other people were there also. The car also is rich at idle and at WOT my afr gauge shows like 12.2 to 12.5 which i lean and not good I need to tweak it to be at about a 11.8. One nice thing is the car feels like it got more pep all around normal driving and turbo seems to start to spool a little earlier.
Old Apr 15, 2013 | 09:58 PM
  #4938
CCrunner84's Avatar
Good for you, now what's the gauge have to do with anything? My bov flirts with being almost open at idle, no difference. I've blown a coupler and noticed no issues in idle quality at all. I don't know what type of boost leak test your doing but going off of vacuum is not the way to do it.
Old Apr 15, 2013 | 11:31 PM
  #4939
If I stick my finger in the "horn" of my bov and force it open (turboxs H-RFL) the car starts to stumble. I threw a washer in there to make sure the spring was keeping it shut. But you are not the first to say that the vacuum doesnt matter. My BOV is before my MAF but the MAF is behind the driver side fog lamp about a ft after the intercooler. SO I am at a loss.
So I went looking around the car today but didnt go as far as pulling the turbo to find leaks and noticed there is a good amount of oil spraying out of my BOV onto the inner fender well behind the the passenger light. So looking around I found light oil coating on my MAP sensor and other parts. I think my turbo is leaking oil and could be the cause of my boosting issues. I am going to order a Mitsubishi Heavy Industries (MHI) rebuild kit (not ebay knockoffs) for just over 100 bucks and try my hand at a rebuild. My local turbo builder said that after an engine build the oil can allow a lot of things into the turbo and mess up the seals, mark up the soft brass bearings and clogging the high pressure line. So its the only thing I have not done as of yet to have the car back to its former 22 psi glory. It wont need rebalanced if I mark the components in their place before dis-assembly.
Old Apr 16, 2013 | 12:32 AM
  #4940
armcclure's Avatar
I just want to see you on the rollers. That is all.
Old Apr 16, 2013 | 09:15 AM
  #4941
nwss's Avatar
Who in here lives in Michigan ? I'm moving back
Old Apr 16, 2013 | 10:29 AM
  #4942
Killa SS's Avatar
Id be one of the few! Where you moving too
Old Apr 16, 2013 | 10:55 AM
  #4943
nwss's Avatar
Grand blanc or Davison
Old Apr 16, 2013 | 10:56 AM
  #4944
mahfouzman's Avatar
I live in Michigan too, Dearborn to be specific.
Old Apr 16, 2013 | 04:38 PM
  #4945
jhaddock21's Avatar
What did you end up putting down?
Old Apr 16, 2013 | 06:34 PM
  #4946
my guess is low 300's on pump gas.
Old Apr 16, 2013 | 09:29 PM
  #4947
rivaladore's Avatar
He was at like 380whp iirc before he went up there
Old Apr 16, 2013 | 09:59 PM
  #4948
mahfouzman's Avatar
So until I get a proper PCV system set up, besides the oil cap PCV breather, should I put a filter on the stock PCV fitting? Or should I plug it up?
Old Apr 16, 2013 | 10:16 PM
  #4949
mahfouzman's Avatar
Oh and did any of you guys need the ZZP MAF extension?
Old Apr 16, 2013 | 10:17 PM
  #4950
mexi_loco's Avatar
I would run a line from a known good vacuum source (like your intake) to your valve cover and put a catch can in the middle of the line.
and yes. I'm running ZZP's 3.5" MAF tubing with my MAF.
