Official Turbo LSJ thread!!!
Old Jul 20, 2012 | 08:50 AM
  #2451
jonathan923's Avatar
turbo lsj to be soon again cant freaking wait. this time going with the zzp s256. if funds allow and go as planned ill be shooting for the built block with the ported head. If NY has E85 then ill like my goal to be around 500whp since the car will be paid off this year!
Old Jul 20, 2012 | 09:18 AM
  #2452
Axelthered05's Avatar
I drilled and taped the block for my oil return its taped at 3/8 npt got the tap at a local ace hardware and special ordered the drill bit works like a badass
Old Jul 20, 2012 | 03:39 PM
  #2453
c130aviator's Avatar
prefect thanks, what size was the drill bit? and how did you get a drill in there from top down without ovaling the hole?
Old Jul 20, 2012 | 05:45 PM
  #2454
i think everything is just a matter of knowing what ur doing and having everything ready. in my case we pretty much did it in a day, except that it was a weekend and i didnt have anything ready for my water lines haha. everything else went great.
oh and on top if that when i was mountingthe turbo i fucked up one of the bolts hahaha. so just to take it off took us aload of time since we had to take the manifold and turbo off again lolz and fails haha
what does he mean here anyone? Water lines? The 20g uses only oil lines.
Old Jul 20, 2012 | 05:48 PM
  #2455
07LSJ's Avatar
my 20g has water lines but i never connected them. i just tapped them. it was his turbo
Old Jul 20, 2012 | 05:52 PM
  #2456
i wont have the turbo in my hands until monday, i cant see what you are saying. Hahn said the turbo was oil only. I do have a water pump cover that is already tapped though standing by.
Old Jul 20, 2012 | 05:53 PM
  #2457
07LSJ's Avatar
i never bothered with the water lines... idk how your turbo can be any different. it will be fine oil cooled.
Old Jul 20, 2012 | 05:59 PM
  #2458
does anyone have the install book or instructions from hahn lying around? I dont think its going to be all that difficult but just wanted to study up to save time on install.
Old Jul 20, 2012 | 06:10 PM
  #2459
Killa SS's Avatar
the Install book wasnt all that helpful man. trust me. lol i was one of the first ones to buy the kit. idk if hahn we did the install instructions, if he didnt, then they are very poorly detaild. Beware of the passenger side charge piping. you gotta get it just right or when you turn left, tire will rub, or your crank pulley will rub. at least i had these problems. One tip for install of charge piping, spray any type of hair spray on the inside of the coupler then clamp it down. its like an adhesive and helps keep the charge piping from popping out of the couplers
Old Jul 20, 2012 | 06:21 PM
  #2460
thanks, will definately do that. im sure my wife has some laying around somewhere.
Old Jul 20, 2012 | 06:27 PM
  #2461
Killa SS's Avatar
Not a problem. i had to learn the hard way. haha. the passenger side was the only side that gave me the most problems. always blew off. so id have to pull over, take the wheel off, fix and throw it back together. was annoying as fu**
Old Jul 20, 2012 | 07:01 PM
  #2462
it was a 9/16 drill bit
I took the exhaust off to make room for the drill there is actauly plenty of room once you do that then I just took my time drilling the hole I tried to make it perpendicular to the gallie. also once you tap the hole make sure to use pipe tape on the fitting threads just to make sure you dont leak
make sure you thoroughly clean out all the shavings before installing the fitting I sprayed wd-40 over the threads and wiped them down good to make sure there were no problems
as for ovaling the hole I got under the car put the drill in place and started drilling just be steady with your hand, you have to drill about 1.5 inches so even if you start out ovaly you should have a good hole by the time you make it through
also if youre like me and ended up a little off from your drilling point you might nick the bolt hole directly below the galie, I had to go back and inject silicone in the hole then install a bolt in order to seal that one up
here is the bolt and such and the second pic is is looking down the bolt hole the little spec of light is the breach. if you do breach it just inject silicone install a bolt in the hole and then wipe away any silicone that was pushed through the breach to the oil return path from the bolt
Old Jul 20, 2012 | 07:14 PM
  #2463
ok, i see now, took me a minute to figure out what I was looking at, lol
what made you decide on tapping that location?
Last edited by c130aviator; Jul 20, 2012 at 07:14 PM. Reason: Automerged Doublepost
Old Jul 20, 2012 | 10:15 PM
  #2464
well I wanted to use the complete LNF setup, so originaly I just wanted to use the push in fitting but it leaked so I taped it and put in a threaded fitting insted of the pushin fitting no problems since plus its a direct path from the turbo to the oil pan so less restriction for the oil return since you dont have to go around the axle
Old Jul 20, 2012 | 10:36 PM
  #2465
Is your tap for oil send or return?
Old Jul 20, 2012 | 10:44 PM
  #2466
caileighpaige's Avatar
so looking to do a swapppppp where do i start haha?
Old Jul 20, 2012 | 10:48 PM
  #2467
mexi_loco's Avatar
you start on page 1
Old Jul 20, 2012 | 11:06 PM
  #2468
^^ lol this.
Old Jul 20, 2012 | 11:27 PM
  #2469
facepalm its return
Old Jul 21, 2012 | 01:00 AM
  #2470
facepalm its return
Lol, do u have pics of the send? Instead of using the drill and tap why didnt you just use that bolt u nicked with a threaded fitting for the return?
Old Jul 21, 2012 | 02:10 AM
  #2471
BlkWdoSS's Avatar
I like zzp stuff, but you are right. I have tap and die sets for small electronics but nothing big. Going to have to look into this. Gonna just get the kit on first though. I am already 1800 bucks into this...
1800 isnt a lot, my car as it sits has $13k invested, and Im currently doing a motor build. Add up everything Ive invested/bought/sold/etc. final total >$25k.
congrats ready to see the build and have you back in a turbo lsj
Old Jul 21, 2012 | 10:16 AM
  #2472
because the bole hole would have emptied into the crank case insted of the oil pan and the axel would have goten in the way of the fitting, also it is parallel wihth the ground. I wanted somthing that was direct out of the turbo into the oil pan and that was as direct as you can get
as for oil feed im using the oil gallie on the back of the engine, the one closest to the thermostat I will try to get a pic of it later today when I tinker with my charge pipes
Old Jul 21, 2012 | 01:03 PM
  #2473
SuperChargedMA's Avatar
[QUOTE=BlkWdoSS;6590241]1800 isnt a lot, my car as it sits has $13k invested, and Im currently doing a motor build. Add up everything Ive invested/bought/sold/etc. final total >$25k.
^This. In the past month I've bought new Rims, someone damaged my hood so I bought a new CF Hood, and thought **** it, new Tjin CF Trunk as well, along with Turbo swap kit from ZZP along with their 3" exhaust, and I'm on the list for Powells new YYZ Springs. I'm forgetting a few things, but all of that alone is about $8,600. And that's in the past two months.
You got to pay to play. Good luck with everything.
Old Jul 21, 2012 | 01:07 PM
  #2474
Off topic for a sec, but I go to UMass Dartmouth and I swear I saw your car there and you went and parked next to me. Lol.
Old Jul 21, 2012 | 05:19 PM
  #2475
That was not what I was getting at. I will be clearer (my fault). I have spent probably 20-30K in axle swapping trucks and building jeeps. ITS A SICKNESS. I moved onto something smaller and economical. I am not trying to spend a lot on this car, that is why I have bought just about everything used. Or new unused parts. I am 32 years old and my priorities are saving and building a home. I had bought land this year and I am broke. The air force then decided it was time I move and now I have land I cant build on. Sorry for the off topic rant. But cars and trucks and mods are a huge waste of money. I see dozens of cars on ebay selling like this "30 thousand invested" then I laugh cause they are selling it for 15K. How is that investing. I teach dave ramsey and well I guess he brain washed me. I get it costs but this car is going to be fast and CHEAP. LOL, Thanks for the good luck, I am going to need it.
you sir are my hero. This will be the first thing I do when I get the exhaust manifold off. is "axelthered05 oil return system" a mod? it is now!
SO i need to make a short list for the local autoparts store.
3/8 npt
9/16 or 37/64 drill bit
rtv silicon
gasket maker for oil pan
copper gasket spray for manifolds
can of hairspray to act as adherent on the couplings for charge pipes
can of engine degreaser (just need it to help get gunk off while I am in there)
new oil
new coolant dex
anything I am missing?
