Official Turbo LSJ thread!!!
it won't decrease IAT's but it will severely lower your cylinder temperatures. e85 burns much cooler and considering you have to use so much, were talking several hundred degrees at WOT
You also have realistic expectations, and know that the idle may not be perfect with firehose injectors, etc. Car will make rape-tastic power though, that I can guarantee
Hopefully I don't pop another axle logging
Leaned out on E85, after my third engine build, pull after pull and never had the searing heat issues I did with gas. Its just safer if you plan on tinkering and testing.
E85 does not cause an iat different that we can measure unless you put a thermocouple by a valve.
However, ethanol does vaporize in a similar manner to meth, so post injection, It DOES cool iat's.
there's guys on the bullet, and my dyno shop guy has seen in person, blow through carb guys on e85 that the manifold is below ambient temp after a pull on the rollers.
The biggest thing here, though, is that combustion and eg temps are what do the damage. E burns so much cooler that you can "get away with" much higher inlet temps than on gas.
Johnson motorsports is running a non intercooled pump e85 procharged drag car that runs 40+psi and inlet temps approaching 300*F. Been torn down each season with no abnormal wear.
Many many turbo guys are ditching their front mounts on e in favor of greatly reduced spool time, with less than a 1% loss in whp. Picking up both trap and mph.
There's SOOOO much more to it than most of you realize.
We aren't making anyone run this fuel, just have an open mind about it. I spend too much time on cruise night pleading my case convincing the older local car guys about it because they say "that **** will dry out your engine, yep your just ruining your motor". Now I just drive by and smile and pat my car on the door when I see them. 4+ years on E85 and 3+ years on a small pulley TVS not being easy on her.
On another Black Friday related note, I made some purchases from ZZP for my Red car
F40 6-speed setup and s259et will be on its way! Snagged an oversized radiator as well.
I am not saying its cooling the IAT like a shot of Meth would. Its hard to state something so simple on this site cause everyone over complicates things. I am just stating that I wouldnt waste money and time researching intakes and for the 5 degree drop I might get from an intake spacer, mod, etc. Simply put the extra cooling and octane from e85 takes care of many worries that scare guys from turbo builds.
I mean, people are here arguing that it cools better because it evaporates. Gasoline evaporates, that's not a difference you will notice in the real world. The much cooler EGT temps you will notice, in the form of the ability to run a **** load more timing and such. Two realities of it are you need more because it's not as efficient at storing energy, and it runs cooler. Yes there are more differences, but not relevant ones to this discussion.
