Official Turbo LSJ thread!!!
Old Feb 17, 2014 | 05:23 PM
  #7651
sl0wlsj's Avatar
Iirc 340 at 19# on pump 93.
That's good. That's really good for a snail that size and pump. Makes me even more excited.
Yes the 6262 will get over 600 easy, but it may be more than you need, and have unnecessary lag. I think the 5862 would suit your goals perfectly.
Yeah my 5531 was awesome and the spool time was amazing, just want more power now. I'm selling my 5531 too.
I really want the 6262 because of future goals and power but I wonder how the spool time is compared between the 2.
Old Feb 18, 2014 | 04:07 PM
  #7652
i944scania's Avatar
You do not need to buy zzp pipe for the Saab intake Mani... but it will save you some time. I made mine custom using a kit of 2.5" pipe and various bends. Not the easiest route but cheaper.
On the subject of putting a turbo kit together yourself, its rough. Since I'm still in school, its taken me a good 6 months to finally put down some good power. Was a 2 week build and a few months of adjusting and tinkering. Turns out, used parts are junk!
Old Feb 18, 2014 | 04:10 PM
  #7653
i944scania's Avatar
I installed a boost gauge a few weeks ago. Seemed to work fine. After turbo rebuild, new custom downpipe with resonator delete, the gauge wouldn't read over 15 psi.
So I was running 30+, maxing my maf and map sensors :x
I thought it felt way too fast for 15 psi...
But now its all tuned and ready to go at about 19 psi. Finally... still loses some traction in 3rd! None in 2nd
Old Feb 18, 2014 | 09:34 PM
  #7654
BlkWdoSS's Avatar
Yep my install took a full month with all the adjustments that had to be made since nothing fit together
Gonna have to get you up to breaking those tires loose in 4th
Old Feb 18, 2014 | 10:06 PM
  #7655
i944scania's Avatar
They break well in second and a little in 3rd if I really hammer it
And this is only 18-19 psi range.
When I was boosting too much on accident due to glow shift not reading right, tires would break free at 80 in 3rd.
But much safer for my engine now
Couldn't go too fast with all the traffic
Old Feb 19, 2014 | 06:56 AM
  #7656
i944scania's Avatar
I am still having an annoying problem..
Car will go rich sometimes, around 12.8-13 idling. Then it will jump back up to normal 14.7 this happends low throttle cruising too.
Other times it till run lean at 17s while low throttle or idle.
It kind of bounces around a little.other times its fine. Does not do it all the time. But it makes me throw a lean code sometimes.
New o2 sensor BTW, thought it would clear the issue up
Old Feb 19, 2014 | 07:04 AM
  #7657
SPDDMN36's Avatar
Wideband calibrated recently? My brother had a similar issue until he calibrated it.
Old Feb 19, 2014 | 07:35 AM
  #7658
bmxracerchamp12's Avatar
my aem one jumps a lot and i had an issue where it quit reading after i pulled my motor. got it fixed but it doesnt seem right. havent started the car in 6 months so i will deal with it when the time comes
Old Feb 19, 2014 | 08:02 AM
  #7659
armcclure's Avatar
Do you have a cat and/or rear o2
Old Feb 19, 2014 | 09:19 AM
  #7660
i944scania's Avatar
Its an aem gauge that doesn't require calibration. I can also feel the idle get a little rough when it goes lean.
I am cat less with the rear o2 deleted, taken out thru hp
Old Feb 19, 2014 | 09:57 AM
  #7661
armcclure's Avatar
Re enable rear o2 codes. Just set to "no mil" option.
Old Feb 19, 2014 | 10:08 AM
  #7662
armcclure's Avatar
When you remove the rear o2 and disable all codes, the PCM still knows something isn't right and runs a high/low test when you're coming back to idle. Having a rear o2 code on but hidden stops the test from running.
Old Feb 19, 2014 | 11:01 AM
  #7663
i944scania's Avatar
Won't it throw sensor 2 o2 code? Or there's a way to shut the DTC off? Being new to tuning, feel free to spread some detail on me lol
Old Feb 19, 2014 | 03:01 PM
  #7664
armcclure's Avatar
It will throw the code but won't illuminate the check engine light. You'll only see it if you scan it.
Your other option is putting the rear o2 back in.
Old Feb 19, 2014 | 03:03 PM
  #7665
i944scania's Avatar
Oh nevermind! tuner said he did make it hidden....So while we tuned last weekend, was fine. Did not throw any codes during the 3 hours of pulls and cruising... so i dont know.
I couldnt find any leaks, exhaust sounds tight. Intercooler or exhaust.
I do have a broken ac harness connector near my charge piping. I think its pressure switch or something.
  #7666
armcclure's Avatar
An easy way to explain it is when you disconnect the rear o2 and delete codes, the PCM sees that everything is supposed to be ok but the rear o2 isn't working. So it commands rich and lean to try to get a voltage change out of it. The only 2 ways to stop this are either allowing it to throw a hidden code (test can only run with no codes present) or to put the rear o2 back in the pipe so that the PCM sees it's actually doing something.
Old Feb 19, 2014 | 03:36 PM
  #7667
i944scania's Avatar
i never knew the rear o2 would cause that
Old Feb 19, 2014 | 03:41 PM
  #7668
i944scania's Avatar
could i just reconnect it and hang it up out of the way? with it still being hidden thru hp?
Old Feb 19, 2014 | 08:26 PM
  #7669
armcclure's Avatar
You only need to do one or the other. But even then, no, it would have to actually be in the pipe.
And to clarify, by hidden I mean it will still throw the code. If you look with a scan tool it will be there. It just won't illuminate the CEL. You cannot have it completely disabled.
Old Feb 19, 2014 | 08:47 PM
  #7670
i944scania's Avatar
okay thanks! good information to know
Old Feb 19, 2014 | 09:59 PM
  #7671
i944scania's Avatar
i have another brain buster for you guys lol. my glow shift gauge doesnt read over 15(30psi max)? accurate readings up to there (compared to electronic lsj gauge) then it stops at 15 every time.
Why would it be doing this? it worked correctly when i first bought it, went up to 20+. Possible that its like blown out?
Old Feb 20, 2014 | 07:07 AM
  #7672
because glowshift gauges are terrible. is it a digital or mechanical one?
Old Feb 20, 2014 | 08:01 AM
  #7673
574's Avatar
574
My glow shift read high just fine when I was running my 2.6/tvs...
Old Feb 20, 2014 | 08:11 AM
  #7674
SPDDMN36's Avatar
No problem with my glowshift gauges either.
Old Feb 20, 2014 | 08:43 AM
  #7675
armcclure's Avatar
Nor I. Does it flutter around there or just dead stop?
