Official Turbo LSJ thread!!!
Old Sep 18, 2014 | 01:04 PM
  #8326
574's Avatar
574
Would a cut out be beneficial on these cars or Na?
I believe that would depend on the size of your turbo
Old Sep 18, 2014 | 01:09 PM
  #8327
Bass_Waves's Avatar
I figured much. I would need a big turbo for it to be beneficial I'm guessing.
Old Sep 18, 2014 | 01:15 PM
  #8328
johnyz's Avatar
i have #60 injectors right now and staying with them since i have the stage 3 kit on and a custom tine. And the maf sensor is on the pipe going from the intercooler into the intake.
also the scip sensor is still being used, it has it own place on the hahn intake manifold.
Old Sep 18, 2014 | 03:41 PM
  #8329
armcclure's Avatar
It depends where your restriction is. With a stock or 2.5 exhaust with a full cat/res/muffler yes a cutout on the downpipe will help. If you're running a 3" straight pipe, not so much. And if you're running a Nicky downpipe, it doesn't matter wtf you do
Old Sep 18, 2014 | 04:13 PM
  #8330
InfraRedline's Avatar
Then you should have no issues driving to the tuner.
Old Sep 18, 2014 | 04:18 PM
  #8331
JapEatr's Avatar
South Central *********
hahaha
Old Sep 18, 2014 | 04:19 PM
  #8332
johnyz's Avatar
Sweet, thanks
  #8333
574's Avatar
574
Hey! That was a quality piece!
Old Sep 28, 2014 | 03:21 PM
  #8334
armcclure's Avatar
Well I finally got the s360 in the car. Felt pretty proud of myself for measuring every thing out and modifying the manifold perfectly. Just under 1/8" clearance to the firewall, but with powell's race mounts that's not an issue.
Here she is next to the s256 I pulled out:
And here she is crammed up in place. Had to un bolt the steering rack to get it up there, and even then it was like solving a rubric's cube.
All things considered I'd say she's doing pretty well. A little laggy obviously, but that will change soon
On a 15# spring, it pulls like the 256 did on 24-25 psi.
Old Sep 28, 2014 | 04:05 PM
  #8335
574's Avatar
574
Your stock block amazes me. You've put it through hell and back and when the new engine is built you can just pull this one out and save it for a backup!
Old Sep 28, 2014 | 05:14 PM
  #8336
Turbo6's Avatar
Did the compressor come like that or did you have the reducer welded on the outlet neck? I just wondered because you can get a silicon reducer for virtually any size and welding costs money. The video sounds extremely smooth so your tune is pretty decent. Looks like it pulls very hard up top.
Old Sep 28, 2014 | 05:16 PM
  #8337
mrbelvedere's Avatar
most of it is in the tune
Old Sep 28, 2014 | 07:39 PM
  #8338
armcclure's Avatar
It definitely has taken quite a beating. You just gotta treat them right
I welded the "reducer" on. The cover outlet is actually very thick; the ID of the 2.5" pipe actually matches the ID of the cover outlet. I did that so it would match up to my one piece charge pipe I had already made for my holset.
I am a machinist/fab/welder so it didn't really cost me more than a few cents
Thanks
It really is. Look at infra an several others that have ran them hard. Things are a lot different than when these cars first came out and people were blowing #4 on cars just over 300whp.
Old Sep 28, 2014 | 11:28 PM
  #8339
JapEatr's Avatar
Like the video!
Old Sep 29, 2014 | 07:33 AM
  #8340
TStone's Avatar
Arms car goes whooo whooooooooo
Got them whistle tips
Old Sep 29, 2014 | 10:39 AM
  #8341
That big boy turba!
Old Sep 29, 2014 | 03:05 PM
  #8342
mitchk90's Avatar
I have a question, I have a 07 LSJ with 163 000 KM on it. I am planning on turbo swapping the car, it burns no oil, no ticks and was really well maintained. However I would like to know if I should look into getting it refreshed before I spend the money on a turbo kit.
Old Sep 29, 2014 | 03:12 PM
  #8343
armcclure's Avatar
I have 180,000 on my stock bottom end. Do a compression and leak down test, and an oil analysis for bearing wear. If all is good, turn it up.
Old Oct 3, 2014 | 07:59 AM
  #8344
bmxracerchamp12's Avatar
that video makes me want to get my setup on the cobalt.... damn you Alan!
Old Oct 3, 2014 | 10:27 AM
  #8345
armcclure's Avatar
Old Oct 3, 2014 | 11:07 AM
  #8346
taintedred07's Avatar
You modified zzps manifold? You should sell the turbo and manifold as a kit
Old Oct 3, 2014 | 01:17 PM
  #8347
armcclure's Avatar
I would, but if all goes well, ramhorn or similar tubular style manifolds will be available by spring.
Old Oct 3, 2014 | 01:56 PM
  #8348
armcclure's Avatar
Here's some pics of the process for those interested. I was surprised by the casting voids in the zzp mani.
Old Oct 3, 2014 | 02:44 PM
  #8349
That's awesome! Could this work with a efr or are they generally twin scrolled?
Edit: screw the efrs, these turbos are cheap
Old Oct 3, 2014 | 07:50 PM
  #8350
armcclure's Avatar
Mine is a twin scroll .92
It works just fine
