Official Turbo LSJ thread!!!
Whats your base pressure at? On a base pressure of about 45-48psi I see 88-89% IDC down on 22 lbs which is just a **** hair under 500whp to give you a very slight idea since you are close to the same IDC on the same injectors. Dial it in and get it on the dyno!
Going LSJ-T need tips!
any recommendations on kits, i was thinking of pieceing a kit together, wanna know about intake manifolds, whethere it be zzp, hahn, or taking the saab one and doing it myself and saving some money in the long run,
turbo manifold
header + downpipe
exhaust, do i straight pipe? how will it sound, was thinking vibrant exhaust for the sound, (3" for sure)
turbo: something from hahn maybe the SG20 or maybe a borg warner, any recommendations, wanna be at full spool no more than 3700 rpm.
charge pipes and innercoolers
suggestions as well for custom, zzp hahn ect, if you know other places to get these parts from let me know, thanks in advance
turbo manifold
header + downpipe
here's a little grainy vid showing how it comes on from a 40-roll with the nitrous. 50hp jets, shuts off at 12-13psi, and bottle pressure was down to like 600
https://www.youtube.com/watch?v=GDQ-...ature=youtu.be
It's kind of odd, she still moves out really well but only put down just over 400whp saturday. Poor old engine is just getting tired! Measured airflow is right around 50lb/min.
The new block is at the maching shop getting it's first "process" completed, then it will come home to my local machine shop for the finishing work that i will be a big part of. It's nice being good friends with someone that owns a race shop/dyno
