Official TVS Thread!!!
Old Oct 11, 2012 | 02:04 PM
  #2551
armcclure's Avatar
30psi running what?
Old Oct 11, 2012 | 02:05 PM
  #2552
carstedt's Avatar
Wut was ur mod list to pull 370?
Old Oct 11, 2012 | 02:23 PM
  #2553
Area47's Avatar
Rent me! per hour
tvs.
mods? everything short of pistons and head work.
Old Oct 11, 2012 | 02:24 PM
  #2554
carstedt's Avatar
Wut pulley size?
Old Oct 11, 2012 | 02:26 PM
  #2555
Area47's Avatar
Rent me! per hour
i think it was either a 2.5 or 2.4. can't remember honestly
Old Oct 11, 2012 | 02:27 PM
  #2556
InfraRedline's Avatar
Originally Posted by Area47
30 psi
13.6 afr
36 degree's of timing
e85.
made dick for power. pushed coolant. why? because i wasn't paying attention when i redid the timing map for the halved map. whoops.
which leads me to think, how in the **** do people blow these things up? is it sheer stupidity of the end user and the "tuner" combined?
for argument sake, i fixed the map and the next pull was 370whp.
I came across a similar, although much less intense situation while testing out that Id1k base map data you posted on the other forum a few months ago. I lowered the timing to be safe, but didnt realize just how much the g/cyl calculation was going to be skewed. Ran 31.5* timing and 12.9 AFR for a pull. Nothing harmed though fortunately.
I know I remember you saying a while back that you liked to go to the track to see what the car would trap at the different power levels. Would you mind sharing what your results were? If not that is understandable. IIRC you had once posted up 118mph on DR's and 121-122mph on street tires, but that was a while ago and my memory may be getting old
Old Oct 11, 2012 | 02:29 PM
  #2557
carstedt's Avatar
Im going to pulley down to a 2.5 i did not know a 2.4 was out lol
Old Oct 11, 2012 | 02:33 PM
  #2558
Area47's Avatar
Rent me! per hour
the 122 was a ***** out run on a 2.5 pulley. i can't remember what it did on the dd tunes i used to run.
Old Oct 11, 2012 | 02:38 PM
  #2559
I cant imagine the torque on a 2.5
Makes me feel decent about my 119mph on 26" slicks though. On a 2.7" pulley on the tune I run every day, so the car must make decent power I have a ported head though. Was reving to 7600 to play it a little safe.
Old Oct 11, 2012 | 02:44 PM
  #2560
Melon's Avatar
Damn that's insane area! Were u running meth or just e85?
Old Oct 11, 2012 | 02:47 PM
  #2561
Area47's Avatar
Rent me! per hour
i ran up to 8k on mine. 1.9 60ft's on street tires. not much spinning going on.
just e85. i dumped the meth when i went to e85 on that car.
Old Oct 11, 2012 | 02:51 PM
  #2562
Melon's Avatar
That's amazing. Wut were u running suspension wise to eliminate wheel spin and wheel hop to run a 60 that quick?
Old Oct 11, 2012 | 02:52 PM
  #2563
Just valve springs correct? Stock balance shafts IIRC?
Old Oct 11, 2012 | 03:00 PM
  #2564
Area47's Avatar
Rent me! per hour
driver mod, and boost limiting in the tune.
the car had full suspension under it. cabs, end links, rear sway, ssc springs, ss/tc shocks n struts.
yulp
Old Oct 11, 2012 | 04:28 PM
  #2565
armcclure's Avatar
Dang. What were iat's like with that setup?
Old Oct 11, 2012 | 04:33 PM
  #2566
Area47's Avatar
Rent me! per hour
never went over 150.
Old Oct 11, 2012 | 04:34 PM
  #2567
carstedt's Avatar
Any vids of the car?
Old Oct 11, 2012 | 04:38 PM
  #2568
Area47's Avatar
Rent me! per hour
nope, not anymore at least. hell i don't even have video of my truck that i know of.
Old Oct 11, 2012 | 04:40 PM
  #2569
carstedt's Avatar
Haha darn really wanted to see a vid of ur setup in action!
Old Oct 11, 2012 | 05:19 PM
  #2570
Projekt's Avatar
Wait...Some people on here actually don’t know about Area's Cobalt?
Old Oct 11, 2012 | 05:21 PM
  #2571
Melon's Avatar
Honestly I do not. Lol
Old Oct 11, 2012 | 05:22 PM
  #2572
carstedt's Avatar
Heard bout it ehen i 1st joined a little bit but not to much
Old Oct 11, 2012 | 05:25 PM
  #2573
100% METH's Avatar
Maybe this will help
https://www.cobaltss.net/forums/2-0l...5-dyno-186685/
the car is flat out, out of injector. used the meth to try and compensate for the top end. it helped a smidge, but not enough. going to re dyno it again when i get the 1000's in the car in a week or so.
11.5 afr starting out
22 degree's total timing.
2.75 pulley
sae was 342/291
::shrugs::
not bad for an 84k mile motor with 50k on the valve spring. stock clutch as well
c16 did 352/308 {wasn't out of fuel!}
plus i could hit the timing down low a lot harder to get the torque i wanted.
::flame suit on::
https://www.cobaltss.net/forums/2-0l...o-runs-211984/
2.5 pulley vs 2.6 on a tvs.
i'll get a better dyno graph tomorrow night.
either it's out of blower, or out of header. one of the two is limiting it. i am guessing header.
23.5 degree's of timing
11.5 afr
98 lb injectors at 79% idc.
e85
::shrugs:: oh well. not what i wanted, but close enough.
374/314 2.5 pulley
371/310 2.6 pulley
https://www.cobaltss.net/forums/2-0l...arison-125002/
M62
here ya go kids. the only thing that has changed is the cams, and the air temp/humidity. they are in std for this reason. SAE numbers are sorts of wacky. this is simply a cam stand off.
colors, cams, date that it was done. street numbers, not OMG dyno numbers.
red - gmr - 7/5/08
green - 272 - 2/10/08
blue - stock - 10/27/07
red was 11.6 afr. 20 degree's of timing
green was 12.0 afr 24 degree's.
blue was 12.4 25 degree's of timing.
im aware of the torque differences. there is a reason behind it. timing has a part of it, but the bigger part of it is compression ratio.
Awkward slow clap for Area47....
  #2574
JSimons47's Avatar
More than some.... hahaha.
I wasn't around when he was. However, i've done my fair share of research and he's everywhere. Learned a lot from his postings.
Old Oct 11, 2012 | 06:25 PM
  #2575
Those dyno threads played a big part in me wanting a TVS. Seeing all these people laying down sub 300whp numbers on the TVS had me all sad...but then I found hope lol, and that hope was posted above
