Official TVS Thread!!!
Old May 17, 2012 | 10:24 PM
  #526
Blinker fluid's Avatar
Hmm... I'll have to pull the wheel and check it out.
I def don't feel any clunking during accelleration....
Just a random clunk while going over a dip or bump.
It's not a loud or heavy clunk either, so I know the struts are ok.
I also have this noise!!! Did you find the problem?
Old May 17, 2012 | 10:36 PM
  #527
RooTBeeR's Avatar
usually its just the front sway bar endlinks
Old May 17, 2012 | 10:43 PM
  #528
Can you break that down a little lol, I'm still learning the lingo. Do I tighten the ends up or do I replace them?
Old May 17, 2012 | 10:47 PM
  #529
RooTBeeR's Avatar
replace the endlinks
a lot of people go with the moog replacement part
just make sure you get the right ones for the right suspension i.e. fe5, fe3, ...
Old May 17, 2012 | 10:57 PM
  #530
nhanson's Avatar
Originally Posted by zrated89
if u up the nozzle u may be ok. But on the 80s and my 10gph nozzle thats what we were at
Where do you spray at?
Old May 17, 2012 | 11:16 PM
  #531
Bluelightning's Avatar
Got Bewst?
Throttlebody spacer pre blower. Best way to do it.
Old May 18, 2012 | 07:27 AM
  #532
Staged07SS's Avatar
Administrator
Administrator
I did actually....
My suspension is in mint condition upoun inspection. I found that my catback was hanging off one of the hangers (prob from when I made some adjustments). I reattached the hanger, and had no issues since.
It must have been bumping off the bottom of the car when I went over large dips. It was driving me nuts, because the sound was so random. I figured if it was an actual suspension issue I would hear it all the time.
Old May 18, 2012 | 08:50 AM
  #533
carstedt's Avatar
im tryin to decide if i wanna put 1m over valves in mine im not sure if the gains are worth the cost or not..any input? i hav a pretty extensive mod list as it is so im not sure if it would do any good
Old May 18, 2012 | 09:21 AM
  #534
zrated89's Avatar
Naw man my buddy danew did it and it wasnt worth the costs for minimal gains. I'm not even gonna bother with it
Old May 18, 2012 | 09:26 AM
  #535
carstedt's Avatar
ok thanks for the info i wasnt sure with them i figured itd b something to add to push me a little further but i guess ill jus stick with the set up and jus knife edge my crank lik planned
Old May 18, 2012 | 09:39 AM
  #536
zrated89's Avatar
Yea man get ur ass to the track when u get back as well
Old May 18, 2012 | 09:41 AM
  #537
carstedt's Avatar
i really want to i jus dont kno what these axles will take since im on stock with no lsd...and if i only take off at lik 2-3k im not goona get a good time prolly mid to low 12's
Old May 18, 2012 | 09:42 AM
  #538
carstedt's Avatar
but i wont b back till the end of december so it wont be till next year neways...ill prolly jus run it on the dyno and hopefully make sum good numbers i may add a nitrous shot on it jus for fun but i havent decided on that yet
Old May 18, 2012 | 10:06 AM
  #539
383_Stroker's Avatar
Everyone says the valves aren't worth it... and i think that's probably true on your average head... But if you go crazy and port yours like 100%Meth's head... i think you could see some flow benefits then.
1mm is a lot on a valve as small as ours.
Old May 18, 2012 | 11:29 AM
  #540
freakta's Avatar
Ya I'd love to get oversized valves for mine when I do came and all that... I think it will be worth it when everything is said and done
Old May 20, 2012 | 06:27 AM
  #541
Vander Nars's Avatar
Ok i just read all 22 pages of this and iv got a question if i get a tvs whats the lowest pulley i could run with no e85 or meth? I would have dual pass, zzp stg 3 fmhe, phelonic spacer for cooling would i be able to make 300 hp with that and all the other bolt ons, if i can avoid meth and still make 300 to 310 then thats what id like to do
Old May 20, 2012 | 12:11 PM
  #542
freakta's Avatar
stock pulley should make 300.
and depending on your fuel system and rpm it doesnt matter what pulley you run. just make sure you have enough for your setup
Old May 21, 2012 | 12:36 AM
  #543
Well iv seen a coupse tvs setups in the dyno sections making like 270 to 290 and i dont know of thats because of stock pulley or subpar tune, if im not atleast 300hp i dont wanna spend 1500 for the tvs hehe.
Old May 21, 2012 | 12:50 AM
  #544
100% METH's Avatar
Full bolt ons and octane will net you 300whp on a stock tvs pulley. Just don't be a weenie with the tune... Doesn't have to be crazy, a simple ramp of 15* to 24.5 will get you there
Shoot for 11.6 afr, not that your egts will be that high anyway.
What's nice about using less boost and utilizing the timing map to its full potential is it gives you more range of manipulation over the torque curve. You'll have a much flatter curve on a stock pulley vs a 2.6 per say.
What we should be doing is utilizing the upper range of our stock valve train. Our stock cams call it quits on a stock head @ 6800 rpm. Put cams in and rev it to 7500... make the power all the way up. If you decide to take it higher, supertechs or zzp valve springs, ati balancer, port it, and a NB delete or neutral Bal. shafts; take it to 8 or higher, depending on your fueling limitations.
The stock pulley @ 18-19 psi won't be making much for torque. In the end we really can't put any of it down anyway ranging from 250-270+ ft lbs (depending on your dyno). You won't have the 300 ft lbs of torque achievable on a 2.6-2.5 pulley, but you'll make up for it on the top end.
Unless you like spinning tire in 2nd-3rd gear... go ahead.. pulley it down and be aggressive in the midrange...
Old May 21, 2012 | 03:00 AM
  #545
What cams do u think i should use for 7500 revs and all i would need to rev to 7500 is just upgraved valve springs right?
Old May 21, 2012 | 03:03 AM
  #546
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Interceptor time - 13.5 @ 111mph
Track time slip - 14.3 @ 105mph (best track time was 14.2@105)
Best 60ft was a 2.4 ... ''
And now I need a new clutch
the track is off I think.. LOL
0 track prep, and everyone is a lot slower than they should have been, the only people getting 2.2 60s or less were the AWD guys.
I saw a 1.9 60 ft from a mustang on slicks, he still ran like a 14.7 though.
Old May 21, 2012 | 03:06 AM
  #547
Got Bewst?
Wow I thought you would have run much better. Are you still on a stock clutch?
Old May 21, 2012 | 03:11 AM
  #548
carstedt's Avatar
if ur revin to 7500 u mind as well get zzp s2 cams and jus balance the engine to 8k they make peak power at 7800...i got them and they help quite a bit
Old May 21, 2012 | 03:21 AM
  #549
Yeah I am on stock clutch
It's the track I was on, it's probably the shittiest stretch of 1/4 mile in existence. LOL
Not a single person had good times, except for those straight up drag cars doing low 9s, probably would be 8s if they were on a better track.
I'll be picking up a ky stg3 clutch
Old May 21, 2012 | 03:25 AM
  #550
Got Bewst?
Oh ya with your mods you definitely need a clutch haha. I will be heading to the track in the next couple weeks once I revise my tune.
