Official TVS Thread!!!
Old Jun 9, 2013 | 07:50 PM
  #6001
Omnigear's Avatar
Originally Posted by RooTBeeR
Not yet
taking long =p
/OT
Old Jun 9, 2013 | 10:34 PM
  #6002
ThexGovenor's Avatar
well that missfiring is back, Im gonna try to lower the gap down even more on my plugs and see if that helps.
Old Jun 9, 2013 | 10:36 PM
  #6003
mrbelvedere's Avatar
what do the plugs look like
Old Jun 10, 2013 | 05:43 PM
  #6004
brown, they dont look gunked up or anything. Ill gap them tomorrow and see if that helps.
Old Jun 10, 2013 | 08:07 PM
  #6005
Melon's Avatar
So this seems like a good thread to ask in as it has a lot of traffic. When doing the head and timing chain tensioner (possible ati super damper), do u guys recommend changing the water pump as well? And if so what is a good one to change it to
Old Jun 10, 2013 | 09:42 PM
  #6006
574's Avatar
574
I've never heard of any problems with the water pump
Old Jun 10, 2013 | 10:00 PM
  #6007
wp is a mother ****** to change if you leave the cover on you need this tool
or pull the front cover and retime everything
Lisle Water Pump Sprkt Holder | Wayfair
Old Jun 10, 2013 | 11:27 PM
  #6008
Melon's Avatar
I have to retime anyways though don't I. New head ported with cams and springs/retainers. Does our stock one hold up fine or does it need to b upgraded? Has anyone done this with successful worthy results?
Old Jun 11, 2013 | 12:20 AM
  #6009
Bluelightning's Avatar
Got Bewst?
Soooo I take my car for it's first rip. After some heat cycles I put my foot into it a bit. The thing is making damn near 30 psi... That aint right
Old Jun 11, 2013 | 01:20 AM
  #6010
100% METH's Avatar
ATI Balancer + tiny TVS pulley...
win?
Old Jun 11, 2013 | 01:26 AM
  #6011
Melon's Avatar
Lol win for who? U?
Old Jun 11, 2013 | 06:56 AM
  #6012
armcclure's Avatar
It's a separate chain, you do not have to even touch it doing s head swap. And I have never heard of any pump problems even on high hp/rpm builds.
Plugged up exh? What mods again?
Old Jun 11, 2013 | 07:10 AM
  #6013
Staged07SS's Avatar
Administrator
Administrator
This.
I wouldn't mess with the water pump unless there was actually something wrong with it.
Old Jun 11, 2013 | 08:51 AM
  #6014
Tjolley's Avatar
Cut the chain and slap an electric pump on much easier to change lol. Balance shaft delete FTW..lol
Old Jun 11, 2013 | 09:01 AM
  #6015
Got Bewst?
win?
I actually don't have my ATI on yet. Just a stock damper and 2.7".
Al if you click on my car under my user name you can see my mod list.
Old Jun 11, 2013 | 09:33 AM
  #6016
on the 3.1 pulley and the stock dampener zzpstg2 cams I was seeing 17lbs at 6000 with the ati and a 2.9 I was seeing 20 at 6000 and around 24lbs at 7300 you may need to limit what it puts out or raise the pulley
Old Jun 11, 2013 | 10:21 AM
  #6017
Got Bewst?
Ya I haven't even put the ATI on yet. Just wanted to drive the car. So it's only gonna get worse before it get better. How I'm seeing way more psi than most with a ported head and catless is beyond me. I'm seeing shy of 30psi and I haven't even wound the car to redline yet...
Old Jun 11, 2013 | 10:47 AM
  #6018
574's Avatar
574
Time for a 2.4 pulley
Old Jun 11, 2013 | 11:55 AM
  #6019
Tjolley's Avatar
Were is ur boost guage hooked up to cuz if its before the IC u will see a higher pressure.
Old Jun 11, 2013 | 12:39 PM
  #6020
RooTBeeR's Avatar
30 psi TVS?
Leave it alone!
Powwweeerrrr!!!!
Old Jun 11, 2013 | 12:42 PM
  #6021
Got Bewst?
I have it tapped into the vaccum off the intake manifold. It's odd because ever since I put my TVS on its always seemed to read high. Like last year the meth ate away at my cat and almost plugged it solid. Took it the cat out and it made no difference in psi which I found odd.
Old Jun 11, 2013 | 01:18 PM
  #6022
I know what you mean I would check the down pipe and see if the flex joint is coming apart other then that it may be the the different cam timing causing it tim at zzp made the comment about how fast it came on in my car
Old Jun 11, 2013 | 01:29 PM
  #6023
Got Bewst?
Fak I don't wanna pulley up but don't like seeing 30psi lol. Taylor is going to have a look at things when I go down there and then throw on my ATI. He has a 2.9" if I need to go up.
I just now gotta fix my idle issue. It seems to hunt a little and coming off decel back to idle the car will dip down to like 500 rpm. Sometimes recover and sometimes die. When it dies it's a bitch to get started again. Tune related?
Old Jun 11, 2013 | 01:30 PM
  #6024
06cobalt racer's Avatar
look at what came in the mail!!!!
Old Jun 11, 2013 | 01:35 PM
  #6025
Melon's Avatar
Plan to do the balance shaft delete
