OPTION B - did i do this wrong? pics included
Old Apr 8, 2013 | 09:45 AM
  #151
Vander Nars's Avatar
ok guys did my ottp h.e and opt b yesterday .... i was filling the system and then it started to stop going in (figured it was full) so i put the tank on an connect the lines, here are pics:
this is the hose running from the opt b tank to the "t" fitting, y is there an air pocket here?
This is a pic of the "t" connection:
any input would be great... this morning temps were about 53* crusing i was at about 80* WOT wen up to 95* for a quick pull then took a few sec for it to drop back down to 80* isnt that a little high ??
Im on the stock pulley.
Air in the system needs to be bleed, Id order the Y so it works better. Ur Iat2's is 27 over iat during cruise? Yeah thats pretty high but u have air in the system so that may be why.
Old Apr 8, 2013 | 09:52 AM
  #152
yellowsupercharged06's Avatar
i can sit there an watch air bubbles come threw the hose back up into the opt b tank, so is it something that time will take care of ? is there anything i can do ?
Old Apr 8, 2013 | 10:29 AM
  #153
Powell Race Parts's Avatar
Originally Posted by Vander Nars
Powell I like u but honestly stop patting urself on the back before u end up with a spinal cord injury, u have told us this everytime a opt b thread gets posted.
But on a serious note since u made this for gm why do they not use the Y in their kit? Last i checked gm was using a T also.
Why do GM do it this way? Cheap and because no one cares I guess. The best for the cooling is gentle sloping hoses, no kinks and no t's; not always possible.
and why do I mention it? Because folks need to hear why things cost more. And you have to repeat things many times for folks to hear it.
seems to me, you didnt hear or read the info right the first time, and in fact argued the option B deal when yours didnt work. so.
I would check connections, it is entirely possible there is a leak somewhere...
Last edited by Powell Race Parts; Apr 8, 2013 at 10:29 AM. Reason: Automerged Doublepost
Old Apr 8, 2013 | 10:36 AM
  #154
powell thanks for your input, i checked for leaks hose clamps on everything are nice an tight.
It seems like the coolant does not want to go into the t fitting for some reason from the opt b tank. If you look at the pics, the tube is full right up to the T, an it shallows out
and the air bubble is there.
Old Apr 8, 2013 | 10:37 AM
  #155
do you have a restrictor (.040) in the bleed line to the HE? Any extra FMIC or stuff like that?
Old Apr 8, 2013 | 10:39 AM
  #156
SS89's Avatar
Because he wont add the stuff to a website so we can buy it, instead u have to trying and contact his staff and place a order.... but seriously get a working site already lol
Why would I call, I don't even know what they're selling. How many sells are they losing to competitors because it's a non-functional website?
Old Apr 8, 2013 | 10:42 AM
  #157
no dual pass, ottp fm h.e and yes the restrictor is in the line(no coolant is coming out of it) so i routed it as so .... http://www.zzperformance.com/miscftp/HE%20routing1.jpg
Old Apr 8, 2013 | 11:10 AM
  #158
Good point. We don't do e commerce off our web site and it does not work very well. But the products we make are listed. and If folks wont email we will probably lose the sale. Thats unfortunate, but at the moment I cant fix the web site. Thats not my expertise. Back to making parts.
Old Apr 8, 2013 | 11:14 AM
  #159
Check with Paul P, your tuner, out there, maybe he can help you. The OTT FMIC is an issue ZZP published pictures of the cores a long time ago and maybe the restriction in the core means you have to be patient and wait for the air to get out. My guess is, the cooling with the stock HE would be as good alone as it would be with the extra FMIC and the air entrappment may well be less. Good luck with it.
Old Apr 8, 2013 | 11:27 AM
  #160
ok thanks powell ill have him check it out
Old Apr 8, 2013 | 12:26 PM
  #161
if anyone else has any input please feel free to help me out
Old Apr 8, 2013 | 12:32 PM
  #162
SylverSS/SC's Avatar
Is your pump working? No kinks in any of your hoses?
Old Apr 8, 2013 | 12:37 PM
  #163
yea pump is working no kinks anywhere
Old Apr 8, 2013 | 12:38 PM
  #164
the air bleed line does go on the stock HE right? idt there is one on the ott one?
Old Apr 8, 2013 | 12:45 PM
  #165
yea bleeder line is on the stock h.e, how doi know if its working correctly tho ?
my issue seems to be the fill hose isnt full when it hits the "t" u can see in the pics
Old Apr 8, 2013 | 12:47 PM
  #166
and the reservoir is full, right? so something isnt working right, possibly the pump. are you sure its running?
Old Apr 8, 2013 | 12:57 PM
  #167
Staged07SS's Avatar
Administrator
Administrator
When you were filling with coolant, did you make sure there was coolant sitting in the t-fitting before attaching the hose to the Opt. b tank?
I use the same proceedure for filling my opt. b tank as I did when my cooling system was stock.
1. Fill with coolant until it bleeds out of the top of the stock heat exchanger.
2. Attach new fitting with 0.040" bleed orfice to top of stock heat exchanger.
3. Continue filling until coolant is visible in the top of the T-fitting.
4. Cap/plug T-fitting, start car (I used some extra straight 3/4 hose, and plugged the top).
5. Re-check T-fitting.... If there is coolant still visible, attach Opt. B tank and fill tank. If not, fill and repeat steps 3 & 4.
Old Apr 8, 2013 | 01:00 PM
  #168
thanks staged ill double check but yea it was full after i ran the process ... ill re try it
Old Apr 8, 2013 | 01:21 PM
  #169
Staged07SS's Avatar
Administrator
Administrator
Ok. Sounds good.
Old Apr 8, 2013 | 03:14 PM
  #170
u know the system is properly bled when there is nothing but coolant running through that clear hose to the tank
Old Apr 8, 2013 | 03:24 PM
  #171
by clear hose u mean ? bleeder hose or fill hose ? ... i cant get the fill hose to fill up all the way to the "t" thats the problem.... its like its too low or sumthing but its level
Old Apr 8, 2013 | 03:27 PM
  #172
the bleeder hose coming off the h/e
Old Apr 8, 2013 | 03:30 PM
  #173
yea its black tho so i cant see whats going on inside of it
is there supposed to be any fluid in the bleeder line ? im getting mixed answers as i read other threads.
Old Apr 8, 2013 | 03:32 PM
  #174
that needs to be changed then... after all without the filler neck i dont think theres any other good way to know that the pump is working other than seeing fluid move through that line. also u know ur pump is working by turning the key on and hearing the buzz of the pump
Old Apr 8, 2013 | 03:36 PM
  #175
for some reason my pump never turns on when i turn the key to on , it only runs when the car runs... ever since day 1. i know it works cuz before my iat temps were 20* above ambient stock.
i can see coolant moving through the fill hose (clear, snake like hose in my pics above) but there is an air bubble in it as u can see in the pics.
so should there be a stream of fluid through the bleeder line ?
