Possible Intercooler Pump Upgrade (Pump Information)
Old Dec 13, 2014 | 08:54 PM
  #176
TStone's Avatar
http://www.ebay.com/itm/Engineered-Machined-Products-EMP-WP29-Electric-Water-Pump-Supercharger-/271535140350?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f38c16dfe&vxp=mtr
Old Dec 14, 2014 | 12:51 AM
  #177
Spawne32's Avatar
Well if I measured the nominal flow rates correctly, the bosch 0 392 022 002 LSJ pump is roughly 5.28gph, the bosch 0 392 022 010 comes in at roughly 6.16gph, and this WP29 comes in at roughly 28gph or so? Which I think might be a bit of overkill. lol
Old Dec 14, 2014 | 01:32 AM
  #178
Exactly
Old Dec 14, 2014 | 10:03 AM
  #179
blueLNFftw's Avatar
Head pressure is what matters tho. So many of the options that have high gph free flow have a lower flow rate under restriction. We covered some of this earlier in the thread.
Old Dec 14, 2014 | 10:09 AM
  #180
TStone's Avatar
fizzzix
Old Dec 14, 2014 | 07:51 PM
  #181
mezzanno's Avatar
Originally Posted by TStone
fizzzix
Emp wp29 flows 29 gph at 7psi head pressure if I remember correctly. This is the pump we use In pauls car and it kicks ass.
Old Dec 14, 2014 | 07:55 PM
  #182
blueLNFftw's Avatar
What about under restriction.
Old Dec 14, 2014 | 08:09 PM
  #183
mezzanno's Avatar
Read what I just wrote
Old Dec 14, 2014 | 08:14 PM
  #184
blueLNFftw's Avatar
Fail on my end.
What are his iat2 like?
Old Dec 14, 2014 | 08:20 PM
  #185
yellowsupercharged06's Avatar
They are still under construction i think
Old Dec 14, 2014 | 09:25 PM
  #186
armcclure's Avatar
Yes but do any of you understand WHY it kicks ass on his setup... All the info has been linked in this thread
Old Dec 15, 2014 | 05:36 PM
  #187
mezzanno's Avatar
Are you asking why it works better than the stock pump
Old Dec 15, 2014 | 05:45 PM
  #188
chris88z24's Avatar
Any benefit to using this on an otherwise stock cooling system? Seems like it would flow too much and blow out the seals...
Old Dec 15, 2014 | 05:55 PM
  #189
Spawne32's Avatar
The WP29? no i wouldnt even try to use it. lol The bosch that the OP was referring to for this thread should be plenty of an upgrade over the stock pump.
Old Dec 16, 2014 | 12:14 AM
  #190
armcclure's Avatar
No. Because all things being equal, aside from the flow rate, it doesn't.
I asked the question to make people think.
Old Dec 16, 2014 | 12:38 AM
  #191
Stumpalump's Avatar
Any problems getting it to work right? I bet the speed could be controlled. Here is the pin out and manual.
http://www.lingenfelter.com/sites/lp...2-May-2013.pdf
Old Dec 16, 2014 | 02:32 PM
  #192
06blackg85ss's Avatar
they do make a pump controller for it, runs canbus and can be throttled
I just run it ***** out, need something that can deal with high head pressure due to the many feet of tubing and heat exchangers in my car. Didnt test it on the stock he, but swapping to this from the stock pump, coolant stays at ambient coming into the manifold and only a few degrees temp rise under wot, drops right back down to ambient in a few seconds.
Iat's werent tested on the m62 yet (will be in a few days once the car is back up and running) but on the tvs with a 2.7 pulley max iat2 after sitting in traffic for an hour and a few back to back 3rd gear pulls got it up to about 130 degrees on the last pull with the avg pull with out heat soaking the system was in the 113-118 degree range
We also monitor the temperature of the fluid in the H.E. system with a temp gauge right before the laminova core inlet and one at the outlet so we can see exactly what the temp delta is after the cores.
stay tuned for more once the rest of the cooling system is ironed out
Old Dec 16, 2014 | 02:34 PM
  #193
only issue was finding a spot to fit it as it's a beast, made a bracket to mount it off the subframe and had to remove the stock pump bracket to clear.
Old Dec 16, 2014 | 02:54 PM
  #194
Spawne32's Avatar
What does your heat exchanger system look like that this pump was a good alternative for you?
Old Dec 16, 2014 | 02:57 PM
  #195
blueLNFftw's Avatar
it is INSANE!
Old Dec 16, 2014 | 03:16 PM
  #196
Spawne32's Avatar
it is INSANE!
ice box in the trunk insane?
Old Dec 16, 2014 | 03:34 PM
  #197
more insane than that lol
Old Dec 16, 2014 | 04:20 PM
  #198
Def more insane
Old Dec 16, 2014 | 08:34 PM
  #199
Spawne32's Avatar
****, well now you have all peeked my interest as to what his car looks like lol
Old Dec 16, 2014 | 09:44 PM
  #200
armcclure's Avatar
There's pocs in his other thread.
