Possible Intercooler Pump Upgrade (Pump Information)
You are correct.
A: Is the OUT (water is pushed out here)
B: Is the IN (water is sucked in here)
B faces the drivers side on the OEM install.
A faces up towards the hood on the OEM install.
I turned mine so the OUT faces the stock HE and feeds directly to the IN side of it. My IN side of the pump it fed from the top laminova and has the line for the option B on it.
You are welcome! You actually have a Gen 5 unit though lol. Only difference is that the Gen 5 doesn't have the drain anymore. People didn't like it.
The aren't the same unit actually. ZZP makes theirs in house from radiator cores. I don't make ours here I designed it and have it produced though.
The numbers back up that info.
Looks killer
Actually it is our design and it's different than the one GM racing used. Ours has a thicker core than they used and because of this the brackets had to be moved slightly.
Looks killer
I will be in touch with you shortly as well as my buddy cracked his block and we are going to need some parts to put her back together.
I dunno if we ever got to the bottom of this, but I found the connector PN's
LotusTalk - The Lotus Cars Community - View Single Post - Which electric chargecooler pump?
"Plastic electrical connector: # 2305400081 $1.67 Needed (1)
Wiring lead: #0005402405 $4.63 Needed (2)
This will give you 18" of wiring from the plug with a "weather-pack" type silicone rubber seal at the connector."
I never could find a connector for the pump. That and deciding to buy a LNF put this project to the side and I never did it.
Some one should. I have the link to the pump, its $103.
lol yeh, i wont be able to make any direct comparisons but I will be using this pump probably.
actually gonna order it directly from bosch through amazon so I know its legit.
aw snap, spawne's become the guinea pig!
time to switch it up, these bitchin pumps' for little kids
lets hope these bring these temps back down to ambient,
after hammering and racing acuras for more consistant damaging!
still gotta figure out my coolant routing, got hoses looped around
my super's snouting, but atleast its cooler sounding,
and leaking all over the place,
like losing control of your bowels it's a morbid disgrace,
maybe we should switch to AN fittings and braided hose
either way it goes gotta keep it tight - no air in those!
let it bleed, like dead gangstas in the street,
and hope the pump will pump like lead when wangstas make my day complete
