Possible Intercooler Pump Upgrade (Pump Information)
Old Sep 26, 2014 | 03:50 PM
  #151
Josh@ottp's Avatar
I forgot. We also made the top tank of the griffin taller for more fluid flow. It's been over 4 years now, I had to go look at the drawing.
Old Sep 26, 2014 | 06:13 PM
  #152
chris88z24's Avatar
I'm a firm believer that the stock inter cooler system is fine, UP TO GM STAGE 2 and ONLY if the pump is still good.
Old Sep 29, 2014 | 07:28 AM
  #153
Staged07SS's Avatar
Administrator
Administrator
Nice. Good to know.
You are correct.
Old Sep 29, 2014 | 08:24 AM
  #154
blueLNFftw's Avatar
wait, what? so the IN on the pump is the side facing the passenger side of the car? and the out goes into the h/e?
Nothing faces the passenger side of the car on the OEM fitment.
A: Is the OUT (water is pushed out here)
B: Is the IN (water is sucked in here)
B faces the drivers side on the OEM install.
A faces up towards the hood on the OEM install.
I turned mine so the OUT faces the stock HE and feeds directly to the IN side of it. My IN side of the pump it fed from the top laminova and has the line for the option B on it.
Old Sep 29, 2014 | 08:25 AM
  #155
blueLNFftw's Avatar
You are welcome! You actually have a Gen 5 unit though lol. Only difference is that the Gen 5 doesn't have the drain anymore. People didn't like it.
The aren't the same unit actually. ZZP makes theirs in house from radiator cores. I don't make ours here I designed it and have it produced though.
The numbers back up that info.
Looks killer
Actually it is our design and it's different than the one GM racing used. Ours has a thicker core than they used and because of this the brackets had to be moved slightly.
Great information here; I appreciate it Josh.
I will be in touch with you shortly as well as my buddy cracked his block and we are going to need some parts to put her back together.
Old Dec 9, 2014 | 02:49 AM
  #156
Spawne32's Avatar
I dunno if we ever got to the bottom of this, but I found the connector PN's
LotusTalk - The Lotus Cars Community - View Single Post - Which electric chargecooler pump?
"Plastic electrical connector: # 2305400081 $1.67 Needed (1)
Wiring lead: #0005402405 $4.63 Needed (2)
This will give you 18" of wiring from the plug with a "weather-pack" type silicone rubber seal at the connector."
Old Dec 9, 2014 | 07:52 AM
  #157
blueLNFftw's Avatar
I wish you would have posted this months ago.
I never could find a connector for the pump. That and deciding to buy a LNF put this project to the side and I never did it.
Some one should. I have the link to the pump, its $103.
Old Dec 9, 2014 | 08:52 AM
  #158
what'd you do with the pump you had? lol
Old Dec 9, 2014 | 08:59 AM
  #159
blueLNFftw's Avatar
Returned it before the return period was up.
Figured I would guarantee my money back because if I tried to sell it here people would be like, "yo, will give you 50. Shipped. Insured. Installed."
Old Dec 9, 2014 | 09:55 AM
  #160
Spawne32's Avatar
lol yeh, i wont be able to make any direct comparisons but I will be using this pump probably.
Old Dec 9, 2014 | 10:23 AM
  #161
i'll be keeping this pump in mind for sure now that the plug is there. *secretly hoping my pump fails*
Old Dec 9, 2014 | 01:19 PM
  #162
Spawne32's Avatar
I ordered the connectors from the mercedes dealer, want to verify the connector is correct before I buy the pump itself. 16.64 from benzpartsforless.com
Old Dec 9, 2014 | 01:22 PM
  #163
blueLNFftw's Avatar
Sweet. I am leaving it up to you to complete this thread for future n00bs and enthusiasts to find!
Old Dec 9, 2014 | 01:24 PM
  #164
blueLNFftw's Avatar
Here is the cheapest place I found for the pump itself
http://www.ebay.com/itm/141362886233?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Dec 9, 2014 | 01:47 PM
  #165
Spawne32's Avatar
actually gonna order it directly from bosch through amazon so I know its legit.
Amazon.com: Bosch 0392022010 Engine Auxiliary Water Pump: Automotive Amazon.com: Bosch 0392022010 Engine Auxiliary Water Pump: Automotive
Old Dec 10, 2014 | 07:49 AM
  #166
chris88z24's Avatar
Keep us updated.
Old Dec 10, 2014 | 08:30 AM
  #167
i'm expecting sub zero temps
Old Dec 10, 2014 | 04:31 PM
  #168
blueLNFftw's Avatar
Mortal combat bitch!
Old Dec 10, 2014 | 04:44 PM
  #169
Spawne32's Avatar
depends on how cold it gets this winter
Old Dec 12, 2014 | 02:58 PM
  #170
Spawne32's Avatar
pretty sure this is the correct one, gonna go ahead and order the pump at the end of the month
Old Dec 12, 2014 | 03:15 PM
  #171
aw snap, spawne's become the guinea pig!
time to switch it up, these bitchin pumps' for little kids
lets hope these bring these temps back down to ambient,
after hammering and racing acuras for more consistant damaging!
still gotta figure out my coolant routing, got hoses looped around
my super's snouting, but atleast its cooler sounding,
and leaking all over the place,
like losing control of your bowels it's a morbid disgrace,
maybe we should switch to AN fittings and braided hose
either way it goes gotta keep it tight - no air in those!
let it bleed, like dead gangstas in the street,
and hope the pump will pump like lead when wangstas make my day complete
Old Dec 12, 2014 | 03:35 PM
  #172
Spawne32's Avatar
do you mind if i steal that and use that on my fb to caption these pics? lol
Old Dec 12, 2014 | 03:38 PM
  #173
long as credit goes to riceburner lol
Old Dec 12, 2014 | 04:30 PM
  #174
mezzanno's Avatar
Dont waste your time with a bosch pump. Just get an emp wp29 and be done with it
Old Dec 13, 2014 | 08:10 PM
  #175
mrbelvedere's Avatar
link it up dawg
