Pullies
no, psi does not eqaul power. Psi is the measure of pressure in your manifold. If you are running 16 psi and another guy is running 14 psi becuase he has a full exhuast he will be faster
i would go with a 2.5" exhuast unless you plan on going further like me. You lose a little low end when you go 3" but you make it up on the top end. When you are modded like me though and break the tires loose in second gear at any speed that low end is something i can sacrfice.
Blue04RedLine
Jan 10, 2006 11:37 AM
