tank for intercooling system(interest)
Old Feb 28, 2009 | 11:39 PM
  #51
HunterKiller89's Avatar
Originally Posted by BlilBT
Its is when it gets hot ...why do you think they put a 5 psi release cap on there , I have seen plenty of LSJ's dump fluid out of the overflow! Vent tube, They are both overflows...the stock neck is a 5 psi cap & the option B redline tank is a 14 psi cap only other lines on the option b are 1/4 line in & 3/4 line out.
Like I stated i will be interested to see the outcome, but it still seems like alot of money for just a filler neck... Fluid wise it wont help with cooling at all.
By the way you can also take the cap off a radiator...but don't open it HOT
i meant you can take the cap off the opt B tank when hot or not, whereas you cant do that with the engine coolant. Im just saying they cant be pressurized systems because there are overflows on both of them. If pressure were to build, it would just relieve itself through the overflow, which is why pressure cannot build.
Old Mar 1, 2009 | 10:25 AM
  #52
BlilBT's Avatar
LOL there is no open over flow on the system...it is a pressure release cap rated at 5 psi stock look at your cap! Loook at the redline bottle & cap on crate engine depot it is rated to release at 14psi thats the overflow. If the system gets to 5 psi stock the cap lets out the extra pressure via the overflow line just below the cap just like a radiator,,,,I have seen this happen. The option B changes the cap to 14 psi before it lets out the pressure via the overflow line just like on the reservoir I had made! If there was no pressure ever in the system....Why did they change the PSI rating from 1 cap to the other? Either way take my word for it or not...but every thing is designed for a reason.
Old Mar 1, 2009 | 11:16 AM
  #53
SSdan's Avatar
Ever take the cap off the IC tank when the car is running and hot? The coolant rises and overflows out the system, just like the engine coolant would.
Old Mar 1, 2009 | 11:27 AM
  #54
chevysssc's Avatar
i have a guy now working on a dry ice tank that should be done tuesday
Old Mar 1, 2009 | 11:38 AM
  #55
flash13brandon's Avatar
So is Hatrickstu's cooling mod not correct because it does not retain the pressure? I am running an extra tank w/ just the CXR h/e. I do not have a 1/4" hose running from the nipple on the top of the h/e to the top of the extra tank. Do I need to have a hose there to retain pressure or what?
Old Mar 1, 2009 | 11:52 AM
  #56
BlilBT's Avatar
If you are running a 5 psi cap on the stock system it's fine, the 1/4 hose is for the bleed line from the stock H/E & if the bottle isn't filling while running it sounds like it works! The system only pressurizes when it's hot,,, just like on the cap it says be carefull & never open hot. 5 psi isn't much pressure at all but 14 is. the system is designed to relieve the pressure if it gets to hot...because remember fluid exspands when it gets Hot which will create pressure in a closed system! Thats why they put the overflow on the system, if it never pressurized you wouldn't need a relief valve! Our intercooler are set up just like a radiator even when hot you can have the cap off & mine lets out fluid even then ...but once you put the cap back on it will create it's on pressure.
Look at it this way if you take a glass bottle & put water in it cold...then you heat the bottle pressure will increase in the bottle!
yup! hell when they 1st made my reservoir it had a small pinhole at the top corner on 1 of the welds & the reservoir was only half full...but fluid was coming out of the hole in the form of a drip...only thing to make that happen is pressure & it only did it while the cap was on!
Old Mar 1, 2009 | 11:53 AM
  #57
If you are running a 5 psi cap on the stock system it's fine, the 1/4 hose is for the bleed line from the stock H/E & if the bottle isn't filling while running it sounds like it works! The system only pressurizes when it's hot,,, just like on the cap it says be carefull & never open hot. 5 psi isn't much pressure at all but 14 is. the system is designed to relieve the pressure if it gets to hot...because remember fluid exspands when it gets Hot which will create pressure in a closed system! Thats why they put the overflow on the system, if it never pressurized you wouldn't need a relief valve! Our intercooler are set up just like a radiator even when hot you can have the cap off...but once you put the cap back on it will create it's on pressure.
Well I'm not running a pressurized cap or a bleeder line. I do not have the filler neck anymore. Just the CXR h/e and the extra tank. I can open the tank when its hot and nothing happens. Am I doing something wrong?
Old Mar 1, 2009 | 11:57 AM
  #58
BlilBT's Avatar
what cap are you running on the new reservoir
Old Mar 1, 2009 | 11:58 AM
  #59
Just a plastic push on cap. It's just a generic tank from Autozone. Just like Hatrickstu
Old Mar 1, 2009 | 12:02 PM
  #60
BlilBT's Avatar
I haven't seen his or payed attention, but yea the stock neck had a relief cap rated at 5 psi that then released if to much pressure was built up & dump it out the overflow that is on the stock neck!
The option B tank is a redline tank...because on the redlines their engine coolant tank has a 14 psi relief cap, Our cobalts don't have a relief cap on the engine coolant reservoir!
But if it works it works, Remember 5 Psi isn't much at all!
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
riceburner
Sep 26, 2015 12:57 AM
