TVS Dyno Number's
Old Jun 16, 2009 | 03:46 PM
  #126
EXsoccer1921's Avatar
i never said what i made. cause i don't know. but i know its more than 260. the dyno we were TUNING on was way off. owner said people generally dyno'd 8%-12% less at his dyno than any where else
Old Jun 16, 2009 | 03:54 PM
  #127
drew1991sf's Avatar
o i thought u said that. but w/e lol u would prolly be a good race for him ahaha u'd prolly only lose by a car or two
Old Jun 16, 2009 | 03:55 PM
  #128
*sigh*, you and you're who should race who mentality
Old Jun 16, 2009 | 03:56 PM
  #129
G85 SS's Avatar
Originally Posted by Tennpenn83
would you expect 250whp out of the stock m62 pulley? of course not. how do you make more power throughout the powerband? drop pulley sizes and supporting mods, right?
why expect any more than 300 with the "stock" TVS pulley? 90% of TVS owners are still on teh stock pulley. almost all of the "TVS dyno #'s" threads are on base tunes from ott with almost no individual tuning done. that's it. until there is more time spent on the tuning, then no, you won't see over 300. drop pulleys, do supporting mods and tune like a **** and you'll see well over 300. i imagine i'm there already
I've got some stuff I'm gonna be doing. Hehehe
My Progressive Meth Kit is going in Friday - 80/20 meth/water mix I'll be running. Also, once we get it dialed in, I'll be dropping down to a 2.9 on the TVS. I'm already bored with the 3.1..Yeh it's still a blast to drive, but I want moar!
Old Jun 16, 2009 | 03:57 PM
  #130
drew1991sf's Avatar
u know it would be a good race lol
Old Jun 16, 2009 | 03:58 PM
  #131
ShortStack's Avatar
bah, youll be better off with the standard kit, non progressive.
Old Jun 16, 2009 | 04:00 PM
  #132
younchamp's Avatar
Wow what's going on in this thread?
  #133
G85 SS's Avatar
Bah...not!
Think of meth as a 5th injector. At 1/4 throttle it would make no sense for your injectors to dump fuel to support wot if you're not wot. The meth kit is no different.
Old Jun 16, 2009 | 04:01 PM
  #134
hahaha no, methanol is not like a 5th injector. its not dumping NEARLY enough
Old Jun 16, 2009 | 04:08 PM
  #135
Bika's Avatar
Fail Less.
Einstein, I didnt say I expect over 300 on a stock TVS pulley. howerver 290-300 should not be out of the question with basic supporting mods like 3" exhaust, decent dyno tune, and maybe w/m injection. I have personally watched two TVS cars dyno just as I described ^^^ and put down 280/240. One of which I rough-tuned after he leaned out horribly on a canned tune. The other was tuned by WickedSS, who is a respected tuner.
Considering that on the same day I dynoed 255whp and 240wtq with only a 2.9" pullied M62, 2.5" exhaust(stock manifold), and meth injection. The torque curves were very similar. i dont think its worth $2000 to gain 25whp and 0wtq.
Old Jun 16, 2009 | 04:12 PM
  #136
G85 SS's Avatar
Riddle me this:
The Nozzle sprays a Methanol mix which goes into the combustion chamber. When you are on meth your car will run richer. So how is the nozzle for meth not like an injector?
Simply because it does not flow the amount, say 60's do, does not mean it is not similar to an injector. Plus, that is how you tune for meth. As if it was a 5th injector.
Old Jun 16, 2009 | 04:14 PM
  #137
ShortStack's Avatar
Actually... Meth will lower IDCS.
Add meth to a car and leave the tune. Look at your AFR.. OH MY!.. Its richer...
Hes not saying it is a 5th injector.. but it does add fuel like one.
Old Jun 16, 2009 | 04:52 PM
  #138
i thought you were saying that you thought it WAS dumping the same amount as a fuel injector. but methanol. i misread it
Old Jun 16, 2009 | 05:52 PM
  #139
Maxim_X's Avatar
Well 6gph is what I'm using right now. 1 gallon is 6.6 lbs so that would like a 40# injector. If you were spraying 10gph, which I plan to, it's like a 66# injector. So it is very much like a 5ht injector.
Old Jun 16, 2009 | 06:09 PM
  #140
Rodimus_Prime's Avatar
I was referring to Area im curious on how much horsepower he gains between 7000rpm to his 8000+ redline which people on a stock motor cannot do then folks try to compare his numbers to everyone else's who do not have valve springs and cannot rev to 8000+ and then try to praise it all under exceptional tuning
Old Jun 16, 2009 | 06:15 PM
  #141
scott allen's Avatar
plus he is on a dynojet wich read 11% higher than some of us that have dynoed on a mustang dyno.
Old Jun 16, 2009 | 06:24 PM
  #142
ShortStack's Avatar
Wow....
Old Jun 16, 2009 | 06:26 PM
  #143
Tennpenn83's Avatar
then it's as simple as "they need to re-tune"
my 285 was had in very bad conditions on a very safe (and rushed) tune. i made 250 wtq. easily. when conditions are better, and with my revised tune, 300+ can be had on the stock TVS pulley, with much more to be had if I pulley down
2000 for the blower for 25hp/0tq? not quite. but let's use your math
$2000 (TVS) + 55 (any size TVS pulley you like) = well more than 25 hp.
come on, did you really think people would stay on the stock TVS pulley forever?
Old Jun 16, 2009 | 06:33 PM
  #144
STS2/SS's Avatar
I go for an interview tommorow for a job im trying to get, if i get this a ported and polished head with valve springs is one of the first things on my list. im interested to see what the gains are as well
I just ported and polished freakta's yellow balt he also has a TVS he goes to SMG on saturday we'll find out if it makes a huge diffrence? I deffinintely took out quite a bit of material in the runners as well as took the exhuast port from a 110 degree knee in, which is horrible!!!! to a 70 degree knee with 23mm bowl's (stock where 16mm) that I hand blended into the runners. that head flows 38% more over stock at .240 inches of lift!!!!! and 46% more at .480 inches of lift!!!!! I better see some numbers of the tunner needs a bumb on the head..... No I love Fred he's pretty good. With a port job like that and the mirror polish the numbers on an M62 car would be rediculous!!
Old Jun 16, 2009 | 07:05 PM
  #145
coopn8r's Avatar
We will see what my m62 will do with a ported head.
Old Jun 16, 2009 | 07:27 PM
  #146
freakta's Avatar
and sat we will see what a tvs does with a ported head hahahaha go me go jerome go fred hahaha bad combination
Old Jun 16, 2009 | 07:50 PM
  #147
i'm running 90/10 methanol/water @10gph. and it works out to only 5%/95% methanol/gasoline per cylinder
Old Jun 16, 2009 | 09:47 PM
  #148
STS2/SS's Avatar
Please let me know asap!
Old Jun 20, 2009 | 08:45 PM
  #149
all4glh's Avatar
Mine is 286whp/246trq so far.
Old Jun 21, 2009 | 03:17 PM
  #150
EatonTVS07's Avatar
looking forward to seeing what i gain with this thing
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
