tvs owners.
Old Jan 4, 2009 | 03:32 PM
  #101
WSFrazier's Avatar
Originally Posted by Area47
this is true. easier power! 340whp on 18 psi from a blower. or 400whp from a 60-1 on the same boost levels. gee. let me think here!
my final goal is 400whp. be it with a turbo or blower. the goal is the same. this being in dream land for right now. BC wants 1520 dollars to grind the cams i want. they get the finger.
380whp on stock cams can be had. never said it would be easy either.
Screw cam sensor, buy two 2.2 intake blanks. Crower or Crane should grind those real blanks to anything you want.
If you want the cam sensor that bad, have a shop change the hex angle, or just use a big fkn screw driver, lol.
Old Jan 4, 2009 | 03:34 PM
  #102
IR0NS1N's Avatar
Some nice numbers area! real nice!
Old Jan 4, 2009 | 03:42 PM
  #103
PRND3L's Avatar
whats faster, areas car or superman??
Old Jan 4, 2009 | 03:45 PM
  #104
Mimmsey's Avatar
I would venture to say that maintenance is a major factor in people not making power with near identical setups. Spark plugs, oil, air filters, fuel filters, and general upkeep make a BIG difference. Case in point. my car with a fujita intake, lighter wheels and a 3" dp only lost by car length to a wrx which had a full vishnu setup (identical to the one sport compact car tested to run a 12.8 in the beat the sti issue). While i realize there are many factors that come into play in a drag race he really doesnt take care of his car: oil changes are sporadic, no new plugs since he has bought the car and im sure he doesn't clean his filter every oil change. I on the other hand do an oil change around 2,800 -3,000 miles, clean the air filter every 2 oil changes, do an engine flush every two oil changes, seafoam every 15k miles, brake fluid every 30k, plugs every 15k. When we raced I was on fresh oil, fresh plugs, fresh fuel filter, freshly cleaned air filter and new coolant, all things considered i feel as though i did well. So yes, that's my maintenance theory, just my 2cents.
Old Jan 4, 2009 | 03:46 PM
  #105
dylaNNN's Avatar
anyone have a TVS for sale?
Old Jan 4, 2009 | 03:48 PM
  #106
EatonTVS07's Avatar
OTT
Old Jan 4, 2009 | 03:59 PM
  #107
HunterKiller89's Avatar
while your car will probably last longer than his, maintenance doesnt really provide a gain in power, so i doubt that is why you won the race....but i guess its good to throw out every posibility
Old Jan 4, 2009 | 04:02 PM
  #108
Area47's Avatar
Rent me! per hour
06black is way faster than my measly blower car
Old Jan 4, 2009 | 04:23 PM
  #109
06black's Avatar
we found this little snip-it out in chi-town last year.
silly people trying to do a highway pull agenst me in there blower cars......
this thread does make me giggle tho, I 2nd area's question.
i was popping 300whp outta the m62 ~3yr's ago. it took a wild tune to get it there, but still!
this was done on a bitch of a land and sea dyno. same one Dan's turbo RL netter low 300's and most 2.5-2.7 cars go 260-240whp
the thing that kills me are torque numbers i see people post. does no one ever go for peak cylinder pressure?
i see many 300-320whp TVS cars here with 260-270wtq, i was netting 280-290 on a m62.
yet people are still crawling in the 250-260 range on wayyyyy more mod's then i ever used back in the day.
you need two things to make decent power on this car. a higher lift cam as the stocker will put up a brick wall toward the 400 mark. And a cylinder head with at least a vary ported exhaust side. 270-280CFM.
Old Jan 4, 2009 | 04:40 PM
  #110
Area47's Avatar
Rent me! per hour
we never ran in chitown asshat!
Old Jan 4, 2009 | 04:45 PM
  #111
EatonTVS07's Avatar
thems sound like fightin words
Old Jan 4, 2009 | 05:06 PM
  #112
ColeJJones's Avatar
Bannned
Originally Posted by Zooomer
Cookie cutter to me would be running a blower because that's what 99% of the people here are doing. Turbo or twin charged would be unique.
In terms of power though, I'd be curious as to how a stock M62 with a ported head would compare to a stock head TVS car. The head is 1/2 the cost and may produce all of the gains... Then again both would be even better but if you're doing head, cams, blower, header, exhaust, it seems like a buttload to spend.
that will be tested soon...
Old Jan 4, 2009 | 05:11 PM
  #113
ralliartist's Avatar
I see you post this **** all the time. WTF did you have done to your car to break 300 so easily yet so many people can't do it nowadays? I think you went to a happy dyno and you should just quit bragging. I do realize that your cobalt is the most modified right now and makes the most power, but I don't think your 300whp m62 claims are realistic.
What were your trap speeds at the 1/4?
Old Jan 4, 2009 | 05:13 PM
  #114
Area47's Avatar
Rent me! per hour
he's not bragging. he's making a point. i know what was done to it. however, it is not my place to say
Old Jan 4, 2009 | 05:14 PM
  #115
EatonTVS07's Avatar
how much power is he makin? if this is at liberty to discuss
Old Jan 4, 2009 | 05:18 PM
  #116
1badBlueberrySC's Avatar
06black??? 400+
Old Jan 4, 2009 | 05:20 PM
  #117
I don't care how much he's making now, I wanna know what he did to break 300whp 3yrs ago on a m62. and why no one can do it now.
  #118
EatonTVS07's Avatar
guess i never realised this lol
Old Jan 4, 2009 | 05:21 PM
  #119
ColeJJones's Avatar
Bannned
i know of 4 people to have over 300whp. i know one of them is a redline
Old Jan 4, 2009 | 05:22 PM
  #120
brag all he wants, I want to know why. what were his mods and what were his trap speeds.
are they all TVS cars? or m62?
Last edited by ralliartist; Jan 4, 2009 at 05:22 PM. Reason: Automerged Doublepost
Old Jan 4, 2009 | 05:25 PM
  #121
ColeJJones's Avatar
Bannned
m62.
Old Jan 4, 2009 | 05:29 PM
  #122
BoostedYards86's Avatar
i'm pretty sure ther were two redlines with over 300whp on the ole m62
  #123
Most and I do mean MOST of the higher HP blower cars keep their **** secretive... your gonna just have to deal with it man... hell I can barely get anything outta' Area and thought we were friends!
Old Jan 4, 2009 | 05:33 PM
  #124
ColeJJones's Avatar
Bannned
yea, i knew of one for sure
Old Jan 4, 2009 | 05:39 PM
  #125
well, too bad none of those 300whp m62 can drive worth a damn. maybe that's why a 250whp stock blower cobalt has the record right now.
