Why am I getting knocks?
Old Dec 27, 2009 | 01:26 PM
Frew's Avatar
Originally Posted by selfinfliction
he's been around almost a year longer than you, and both of u are nubs btw.
so just cause hes on .newb longer this means he knows more? stfu newb
Old Dec 27, 2009 | 01:28 PM
slowswap's Avatar
Keep beating on the car in the cold and I'm sure you'll love your cracked block as a show piece in your living room.
dumb people
Old Dec 27, 2009 | 01:31 PM
Frew's Avatar
dumb people
thank you, this was my original point til all these douchelords chimed in
Old Dec 27, 2009 | 01:37 PM
blackbolt89's Avatar
try to put some 93 in your car and see if you get rid of the KR.
that should have been your first course of action. and if you cant get 93 up by you get a aftermarket tuner to tune you for whatever the highest octane you have in your area is. putting out the extra 10c per gallon is worth it when the motor is worth 3k
Old Dec 27, 2009 | 01:45 PM
twzted's Avatar
*waits for knowledge to based on post count*
Old Dec 27, 2009 | 01:56 PM
Frew's Avatar
lolz
Old Dec 27, 2009 | 02:36 PM
selfinfliction's Avatar
when comparing u to him, yes. but looking at it from my perspective, both of you are ********, now go back to your nintendo
Old Dec 27, 2009 | 03:02 PM
F3Z's Avatar
F3Z
why are u even getting mad.. its his car and he may go WOT anywhere he wants at any wheather he wants... if he messes up his car then its on him...and plus if its snowing or cold as ****, thats when u blast ur heater and put ur pedal to the metal and mess around..
Old Dec 27, 2009 | 05:09 PM
Maven's Avatar
The answer as to why its knocking has been stated already, and its most likely because its 10F and youre doing WOT runs. Stop doint WOT pulls in sub freezing weather and you want get knock. Or MAYBE try putting your 60s back in since for some reason you decided it was wise to pull fuel out of the engine at the same time nature is forcing more in.
Old Dec 27, 2009 | 06:51 PM
and the knowledge based on post count has spoken! all hail king Maven!
Old Dec 27, 2009 | 06:53 PM
  #36
slowswap's Avatar
Nothing that multiple other people haven't posted.
Maven, is it hard to walk with all of the nut huggers? lol
Old Dec 27, 2009 | 07:51 PM
  #37
HunterKiller89's Avatar
im sure he loves them. helps keep em warm during the cold winters
Old Dec 27, 2009 | 11:16 PM
  #38
firepinch's Avatar
Lmao!!! This tread becomes funny!! I think that I wasnt enough clear for how I act with my car during the winter. Anyway I don't care of any thoughts about it, I'm just gonna say that
1. I did some pulls during ONE day when the road was clean, there was not any snow at all, that was during November. I did that in a long empty road with no cars around and no house, nothing. Then when I saw those knocks, and those knocks were DURING the pull and not at the beginning (I already know that its normal to get knock directly when you depress the gaz pedal).
2. Once I saw that I had knocks, later when I had the chance to pass again on that road, I did a WOT pull in third for testing purpose in order to see if what I saw was real and if I could repeat again what I saw. Again again and again, the knocks occured constantly during the pull, not at the beginning.
3. Since then, I stoped to do WOT pulls cuz I don't want to break my car, I'm not that stupid and I know that doing that in cold weather is not so good for the car too. Talk about a complete newb!
I'm not an expert but I know some stuff lol, the reason why I'm discussing in that forum. That is for knowledge sharing and for knowing what other smart people have to say. And like I said in the beginning, I wondered if the problem could be my plugs OR the cold weather. This can be both of them too... Why I'm thinking about the plugs??? Because the one I have are actually one step colder so... in colder weather this may (MAY NOT MUST) cause knock, I dont know, that is why I'm asking. Normally, you are not supposed to get knock because the intake charge temperature is too hot? That is why cooling mods help getting the knocks out of the way.
And to finish, there is one station here that sells 93 octane gaz but it doesnt seem to help much the knock problem I'm getting in cold weather. I tested once when I tried the 93 octane gaz.
UPDATE
My intercooler pump didnt work for a while cuz I just got ride of the intercooler pump relay. I did that because I didnt flush enough the distilled water which was in my tank, as a result, the coolant just froze. But today, this was a hotter day, the temperature went just a bit over 0 Celcius so I decided to flush about 2 liters of my intercooler coolant and put back some Dexcool. I put back my intercooler pump relay and everything is functionning fine. I hope that this time the coolant will not freeze...
So I decided just by curiosity to do a pull, on that famous long road. NO KNOCK now!!! So I guess that I could get knock because of the colder weather before.
Even if my IC pump wasnt working during a while, the IAT2s never passed 120F, so to me, that was not critical. However, maybe the contrast between the IAT2 and the very cold IAT1 I had, was not liked by my engine, therefore, the knocks I had. When I was cruising however, the IAT2 temps were around 90F. 120F only occured when I didnt move much.
Well, so I'm not worried anymore, everything is fine. Thanx for your thoughts people!
P.S.: For the distilled water that wasn't enough drained... u know, below the OTTP heat exchanger, you have a valve that you open if you want the coolant to exit. I drained the distilled water that way, while the pump was working but I just think that I thought that all the water was drained but it wasnt... I could see some water exiting after many minutes but I didnt thought that the entire system could have like 1.5 liter after I closed the valve. But now I know... next winter, the coolant wont freeze beleive me I'm so lucky to have a working IC pump again! Call me ******* if you wish... but the mistake was done, I was too much hard pressed, I had too much thing to do that day :P
Old Dec 28, 2009 | 11:36 AM
  #39
Maven's Avatar
okay. whatever. LOL.
Old Dec 28, 2009 | 12:23 PM
  #40
JapEatr's Avatar
South Central *********
ALL YOU ARE NOOBS <---checks join date
Old Dec 28, 2009 | 12:41 PM
  #41
Maven's Avatar
you got me beat by less than two weeks...LOL, all hail the senior member.
Old Dec 28, 2009 | 04:08 PM
  #42
firepinch's Avatar
Haha!! Funny how this tread started with smarter answers and then finish with jackass one! Thanx anyway guys!
Old Dec 28, 2009 | 05:05 PM
  #43
JapEatr's Avatar
LOL...expirience is everything...Old Spice
Old Dec 28, 2009 | 05:08 PM
  #44
yeah but being associated from the same place as george bush is an automatic fail.
your counter starts over ... now
Old Dec 28, 2009 | 05:15 PM
  #45
JapEatr's Avatar
HAHA...i like your style, did you know Kentucky is the birthplace of the TOOTHbrush, because if invented anywhere elese it would have been named the TEETHbrush....
Btw....4006...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 22, 2015 08:56 AM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
