Drumrush's build thread
Old Nov 11, 2011 | 11:45 PM
  #151
TommyP's Avatar
AWD > FWD
Ya quite a lot actually, you may see lower boost numbers than you expect because of it, but you will still be flowing more air, since boost is just a measure of restriction.
Old Nov 11, 2011 | 11:47 PM
  #152
drumrush's Avatar
yeah. it turns out my blower has a smoothflow hub on it, so instead of putting on the gm stage 2 pulley im thinking about a 3.1 pulley. maybe even a 3.2 to go easier on the engine, but at the same time i want that extra boost
Old Nov 12, 2011 | 01:46 PM
  #153
drumrush's Avatar
ok guys i think i have a problem.
this is the alternator bracket with the tensioner installed, correct?
and it appears that the corner is cracked off... what is supposed to be here? just another mounting spot?
Old Nov 12, 2011 | 01:50 PM
  #154
zerosk8ter83's Avatar
I dont think it really matters as long as the tens is bolted down good
Old Nov 12, 2011 | 01:54 PM
  #155
1LowLS's Avatar
the pulley needs to be up more.The tensioner should be straight up and down.un bolt the bottom bolt on the actual tensioner shock and rotate the pulley assembly up then rebolt it down.Make sense?See how the shock is diagonal?It needs to be straight up and down with the bracket.
Old Nov 12, 2011 | 01:57 PM
  #156
drumrush's Avatar
ok. ill try and figure that out later, right now i cant let my eyes off the kid haha
Old Nov 12, 2011 | 03:18 PM
  #157
huckernage's Avatar
here the solutions
Old Nov 12, 2011 | 06:01 PM
  #158
c1_c1rca's Avatar
doesnt that piece thats hacked off have the ac condenser mount to it?
Old Nov 12, 2011 | 06:17 PM
  #159
drumrush's Avatar
The guy I bought it from said he used it with no problems
Old Nov 12, 2011 | 07:52 PM
  #160
drumrush's Avatar
im stuck between a 3.0 and 3.1 inch pulley.. what do you guys think? i want to go a bit easier on the engine, so maybe even a 3.2? how much power would i be losing going from a 3.0 to 3.1 to 3.2?
Old Nov 12, 2011 | 08:02 PM
  #161
thedubsack85's Avatar
From the short look of the build list i read you have the mods and gauges to be able to know what's going on, Some people have gone lower then 3.0 on pulley without an issue, It's hard to say exactly how much hp you would lose cause every car/tune is different, Just dont beat on her and you will be fine with the 3.0 just keep an eye on her!
Old Nov 12, 2011 | 08:05 PM
  #162
drumrush's Avatar
ok. im thinking 3.1 to start off, and then i might drop a pulley size after a dyno if im nowhere close to 250whp. my goal is to stay right around 225-230. plenty of power, but not pushing the limits either
Old Nov 12, 2011 | 08:09 PM
  #163
1LowLS's Avatar
just run a 2.5.youll be good lol jk
Old Nov 12, 2011 | 08:21 PM
  #164
c1_c1rca's Avatar
Im running a 2.9 pulley and hitting 14 psi on stock internals and on 42s, only problem im having is my tune at the moment
Old Nov 12, 2011 | 08:35 PM
  #165
1LowLS's Avatar
2.9 @ 11 psi here.No issues other than tuning as well.Just a idle misfire.Other than that,she runs mid 13's all day long sweet suzzie
Old Nov 12, 2011 | 08:41 PM
  #166
drumrush's Avatar
I know there's not immediate problems, I just need this car to last
Old Nov 12, 2011 | 08:45 PM
  #167
1LowLS's Avatar
Just treat it with respect and you'll get longevity.
Old Nov 12, 2011 | 08:49 PM
  #168
c1_c1rca's Avatar
have u changed your oil to synthetic?
Old Nov 12, 2011 | 08:55 PM
  #169
1LowLS's Avatar
who you talking to?
Old Nov 12, 2011 | 09:02 PM
  #170
c1_c1rca's Avatar
everyone
Old Nov 12, 2011 | 09:07 PM
  #171
1LowLS's Avatar
yes Castrol Syntec Edge 5w-30
Old Nov 12, 2011 | 09:16 PM
  #172
drumrush's Avatar
mobil-1 EP
Old Nov 12, 2011 | 09:17 PM
  #173
c1_c1rca's Avatar
royal purple mafackers
Old Nov 12, 2011 | 09:21 PM
  #174
1LowLS's Avatar
too expensive for my blood lol.I couldnt tell much difference when I tried it.Thought it was cool that its actually purple lmao
Old Nov 12, 2011 | 09:23 PM
  #175
c1_c1rca's Avatar
i got 6L for 60 bucks and an oil filter..... so 1.5gallons for u american foke lol
