Drumrush's build thread
Old Nov 14, 2011 | 05:49 PM
  #201
c1_c1rca's Avatar
i think mine did that to, i had kinda a rough texture to mine, i thought it was just the paint i used, but it might be the metal, donno i like how mine looks lol
Old Nov 14, 2011 | 05:50 PM
  #202
1LowLS's Avatar
its basically the paint seperating from oil.It just wasn't prepped and cleaned enough
Old Nov 14, 2011 | 06:06 PM
  #203
drumrush's Avatar
hmm thats the thing, i sanded the hell out of it to have a nice level surface to paint, and then thoroughly cleaned it with an industrial grade degreaser
Old Nov 14, 2011 | 06:29 PM
  #204
drumrush's Avatar
Old Nov 14, 2011 | 06:45 PM
  #205
1LowLS's Avatar
maybe the degreaser made it do that.When you clean after prep,use a solvent base cleaner.That will get all contaminants off.
Old Nov 14, 2011 | 06:47 PM
  #206
drumrush's Avatar
the primer went down without a problem, and then the paint just got screwed up on top of the primer. so im thinking it was the humidity
Old Nov 14, 2011 | 06:55 PM
  #207
1LowLS's Avatar
I've never seen humidity cause fish eyes.Unless it was high enough that water was forming on the blower.I dunno I also live in AZ where we don't really have humidity lmao so I guess its possible.
Old Nov 14, 2011 | 07:00 PM
  #208
drumrush's Avatar
yeah. it started pouring and got really cold right before i put on the black
Old Nov 14, 2011 | 08:51 PM
  #209
drumrush's Avatar
got this in the mail
and i modified my extra map sensor to fit the lsj intake manifold.
Old Nov 14, 2011 | 09:48 PM
  #210
1LowLS's Avatar
How'd you modify the map?Pic please
Old Nov 14, 2011 | 09:57 PM
  #211
drumrush's Avatar
i removed the metal ring in the hole to make the opening bigger
and that gave me enough room to screw it in
it seems to have a good seal, but im not positive. i might fab up a seal of some sort to put under it
Old Nov 14, 2011 | 11:33 PM
  #212
1LowLS's Avatar
How exactly did you get the ring out?thats a dam good idea.
Old Nov 14, 2011 | 11:34 PM
  #213
1LowLS's Avatar
And can you tell me if that bolt hole goes all the way through?
Old Nov 14, 2011 | 11:37 PM
  #214
drumrush's Avatar
i actually tried drilling it out, but the bit caught on it and it just pulled it out. and what do you mean if the bolt hole goes all the way through?
Old Nov 14, 2011 | 11:51 PM
  #215
1LowLS's Avatar
the bolt hole on the intake manifold for the map.does it go all the way through into the runner or is it blocked off.Like if you left the bolt out,would it leak boost/vacuum?
Old Nov 14, 2011 | 11:53 PM
  #216
drumrush's Avatar
oh i get what your saying, let me go check for you
Old Nov 14, 2011 | 11:55 PM
  #217
drumrush's Avatar
it doesnt go all the way through
Old Nov 14, 2011 | 11:56 PM
  #218
1LowLS's Avatar
sweet cool thanks
Old Nov 14, 2011 | 11:58 PM
  #219
drumrush's Avatar
Why wouldnt you use the bolt though?
Old Nov 15, 2011 | 12:00 AM
  #220
1LowLS's Avatar
I didn't think to pull the ring out like you did so I made an alternate hold down.But now since I know you can pull the ring out ill do that with a bolt
Old Nov 15, 2011 | 12:04 AM
  #221
drumrush's Avatar
did you have to seal the sensor in or did the stock o-ring on it seal it good enough?
i have a stock lsj map sensor as well, but im too lazy to try and figure out the wiring for it
Old Nov 15, 2011 | 12:07 AM
  #222
1LowLS's Avatar
I have the stock LSJ map that I wanna use as well but I need to find a pigtail for it.Our Stock MAP's only read 2.7 psi max and the LSJ sensor can read IAT2's,which you would have to pull the IAT1 wire from the MAF and run it to the LSJ map.But as for the stocker in the manifold,It's the same size in diameter as the LSJ so it seals just fine.
Old Nov 15, 2011 | 12:09 AM
  #223
drumrush's Avatar
ok. if you ever do the lsj map swap let me know how you did it, i would be interested
Old Nov 15, 2011 | 12:11 AM
  #224
1LowLS's Avatar
I will indeed.Just gotta find out what wires what on the LSJ map and match it to the L61 wiring,then find out which wire on the MAF is for IAT1 and wire that to the LSJ MAP so you can see IAT2's.I know how to do it,just need a detailed diagram of the wiring.
Old Nov 15, 2011 | 12:13 AM
  #225
drumrush's Avatar
thats the hard part to find. i saw i diagram somewhere, but i couldnt really follow it
