Jn2's goes the easy route
ps added another picture above
yeah i wanted a cobalt series aswell, since my boost and oil temp gauges are both cobalt series, but they want close to 400 bucks for it, fuuuck that...innovate FTMFW, and the h/e is literally a perfect dam fit, ima have to be careful with it lol, it comes down to match the bumper
Ya, I think I'll stick with a Cobra for the time being, at least.
And yeah, the Cobalt W/B is INSANELY expensive!!!
on further news, the sc came in today, came in nicely pakaged, only one flaw, there was a hole in the bag wraping the blower, so styrofoam got inside thru the TB hole, i got most of it out, but now its in my head, to take this thing apart, i undo the bolts going around it right? than pull the whole neck out with the blades attached? ill search for a how to
expect a modular pulley system on that thing later on next month, im still debating on pulley size, probably going to run a 3"
yeah but you see with this one, no need for bracket, i just drill a hole in the iompact bar, the tabs on the h/e line up perfectly, than run a bolt and nut and tighten it down and your set, no need to jump hoops to get it to bolt on
how much money have you used already? for both your set ups?
and if you need any help with the build you can send me a pm or just ask. its really easy. cuz you did it to haza car.
yeah; on both setups, im still at the same cost; everything from the turbo build sold and i bought the m62 with the money, so im sitting @~1025 right now
yup, im still debating on pulley size probably a 3" i think i have to use a stgII belt for it too, not sure, haza has stock pulley on stock belt
yeah i have a local guy who has a bottle of sc oil im changin that too, and i found the how to for the removal, so when i undo the bolt pull the neck out, making sure not use the pry point to not spill oil everywhere :p which i dont think matters since ima change it anyway lol, but to avoid a mess; yeah i have to take it apart to plug the sc holes, and get styrofoam out of the rotors
Well I'm buying a full exhaust since I'm all stock now, need a exhaust...here's what I'm looking at
Ca v2 header
Xtc downpipe 2.5"
Vibrant 3" exhaust
Getting the first 2 from CA, and the exhaust from ttr, going 2.5 prior to catback to help conserve low end, and 3" exhaust to help the high end
Ca v2 header
Xtc downpipe 2.5"
Vibrant 3" exhaust
doesnt work that way. one solid size would be better, and if you need different sizes, its better to start large and then small (IE 3" DP and 2.5" catback)
