Sentry's Turbo Build Thread Extravaganza!
i didn't think RTV took that long to dry.. got any more pics of under the hood?
thw 2.5" dp wont be bad for right now.. hell just get a cutout put in there at some point.. that way you can have a nice quiet exhaust but when you want you can let it rip
Mine is the regular black rtv. And yes, full cure is 24 hours even though right now the dab I tested seems to be fully dried. I hate making you guys wait, I really do, but when it's done it's done. I like to do it right the first time. Really though, there is nothing in the way of a test run tomorrow for sure.
good to know best be seeing mucho pics and vidz tomorrow no biggy on the wait .. do it right or don't do it at all
So ready to get home and test it out. Been without a car for weeks now. I'll be so afraid and exhilarated at the same time, lol.
I get off in another hour and a half, so we will see then!
I finished tapping it off with oil, and got a jump and guess what, doesn't run. It turns over but it gets through a couple of cycles and dies. I'm thinking it's the spark plugs, but obviously I'm not too sure. Anyone got any suggestions?
I'm open to suggestions.
remove the fuel rail, with injectors attached, and turn the key, make sure they all spray fuel out; be careful, do not aim at any open flames/antyhing that will ignite fuel
ps this will make a mess; cover your eyes or anything else fuel sensitive :p im not responsible for any damages or w/e happends from this
also pull 1 coil at a time, stick a screwdriver into the boot, turn the key, make sure they all give spark, do this 1 at a time, so 3 should be in, 1 is out, make sure they all give spark, you can do this after checking to make sure your engine is getting fuel
ps. not resonsible for anything from doing that either
careful, it will shock you, thats how u know its giving spark
sounds like the injector idle pulse width is out of wack if you can't find anythigne else wrong.. what injectors you have again 42s or 60s?
thats what happened to mine when i went back to NA
the stock tune didn't reload so it was trying to run the car on virtually no fuel but i could smell loads of fuel... it would crank and if i held the car floored it would hold but soon as i'd let off the car would die
