Sentry's Turbo Build Thread Extravaganza!
Old Feb 5, 2009 | 07:53 PM
  #176
Jn2's Avatar
Jn2
yay, it might of won every battle, but you won the war
PICCCCCCCCCCCSSSSSSSSSSSSS MOOOOOOOOOOOOAAAAAAAAAAAAAAAAr
p.s. dont sho ur face in any other threads until my hunger for pics is satisfied :P
Old Feb 5, 2009 | 11:27 PM
  #177
mrsilent13's Avatar
congrats on finally getting that lil thing out...lol....hope you finish soon
Old Feb 5, 2009 | 11:43 PM
  #178
elecblue06's Avatar
awesome man.. I thought about mentioning torx bolts.. but the bolt looked pretty stripped so i didn't think it would work
Old Feb 6, 2009 | 12:34 AM
  #179
Sentry's Avatar
So, got manifold back on and bolted the wastegate down. Ran vacuum line to T.
I had to bring the turbo up from the bottom, it would not fit from the top. It's a big boy.
As you can still see though, it's not mounted. Sadly, I didn't have the right size studs for it and it's way too late to run to the store. It will have to wait til tomorrow afternoon. If everything in the pic looks dirty, it's because it is. Need to redo my valve cover.
Checklist of things left to do:
  1. Get correct sized studs and mount turbo
  2. Screw on oil lines
  3. Tap oil pan
  4. Get downpipe made monday
  5. Plug in gt tuner and my laptop to my wideband and start logging
Old Feb 6, 2009 | 12:36 AM
  #180
Jn2's Avatar
Jn2
Sweet finally
Old Feb 6, 2009 | 12:45 AM
  #181
Sentry's Avatar
Originally Posted by Jn2
Sweet finally
Yeah, I know everyone was waiting on pics of the turbo all mounted, but it wasn't happening without those studs. To answer dave's question a couple of pages back, yes I am using a filter. It's the same K&N filter from my NA intake, just modified for use on my piping.
Old Feb 6, 2009 | 12:47 AM
  #182
elecblue06's Avatar
getting there man gettinnngerre..
Old Feb 6, 2009 | 01:59 AM
  #183
mrsilent13's Avatar
o snap....almost done...i told you, it wont fit through the top......lol...i tried to put mine in through the top as well but it wasnt happening...the only way to get the turbo on through the top is by taking off the head...which is too much work...but i did it when i blew my piston up....now i have forged pistons and rods, studs, upgraded springs and valves, and mounts..looks like we have almost the same amount of mods done....how much you planning on pushing?
Old Feb 6, 2009 | 07:55 AM
  #184
Sentry's Avatar
Wastegate is set at 7 psi, hoping for ~240 whp.
I don't have everything in my sig, that's why it says coming soon. That's my future build that I haven't started yet. Once I do get fully forged and build the head, I'm thinking I'll up the boost and try to make at least 400 whp.
Old Feb 6, 2009 | 09:46 AM
  #185
roadrage06's Avatar
looking good. keep us posted. dyno when you can to let us know how it all worked out.
Old Feb 6, 2009 | 10:03 AM
  #186
06_ion2's Avatar
nice man wish i woulda went turbo but i got a deal on the s/c..
Old Feb 6, 2009 | 01:28 PM
  #187
mrsilent13's Avatar
7 psi is nice..wont even feel like the car u bought at the dealer. whole new beast....but now im shooting for 14lbs until i can get a new intake manifold....but its looking good
Old Feb 6, 2009 | 03:07 PM
  #188
Jn2's Avatar
Jn2
7psi is a good entry lebel amount of boost, im actually going to be pushing w/e psi i need to get 230whp
Old Feb 7, 2009 | 05:04 PM
  #189
vulcanturbo's Avatar
lookin really good! I love those turbos... ill be listing wastegates and turbochargers on our website soon as well for you guys! I know everyone always requests them and ill make it easier so you dont always have to call to order... thanks again for the support everyone! Sentry just so you know those studs in the manifold need to be 10x1.5mm and about 35-40mm long.
Old Feb 7, 2009 | 06:59 PM
  #190
Sentry's Avatar
Yeah, I made the mistake of getting 10x1.25's and they did NOT thread right.
Everything is just about done now. I gotta get (3) 10x1.50 15mm bolts to finish the oil lines, and tap the oil pan. I got a question though, what's to stop me from just using the oil drain bolt instead of tapping a new hole? I believe I have the right fitting to make it work, any kind of technical reason why that might not be a good idea?
Old Feb 7, 2009 | 08:37 PM
  #191
Jn2's Avatar
Jn2
Yes the drain has no presure it will build up, and fill the chra with oil and blow ur seals, it's gravity based, which is why it's drains above oil level, not below it
Old Feb 7, 2009 | 11:52 PM
  #192
^^ correct you want the oil to drain as feely as possible, using the oil drain pan bolt would not be large enough and would cause the hose to fill up with oil.
Old Feb 7, 2009 | 11:55 PM
  #193
mrsilent13's Avatar
so you havent tapped nothing yet?....well hope to see her running soon...do you need to see where i tapped mine
Old Feb 8, 2009 | 12:02 AM
  #194
Jn2's Avatar
Jn2
Mr silent post pics :p I'm curious too
Old Feb 8, 2009 | 12:17 AM
  #195
mrsilent13's Avatar
alright
i tapped it the same place the garrett kit tells you to tap
hold on ill get a better pic from garrett
Old Feb 8, 2009 | 12:18 AM
  #196
Jn2's Avatar
Jn2
The gurdle, how thick is that thing anyway?
Old Feb 8, 2009 | 12:25 AM
  #197
mrsilent13's Avatar
top right pic shows where you need to drill
top left shows the top view of the oil boss...looks like a dimple
bottom shows both the oil feed and oil return nipples installed
Old Feb 8, 2009 | 01:12 AM
  #198
Sentry's Avatar
So wait, you drilled into your block instead of your pan?
The thing is, I don't have a tap that big. You're supposed to use a 1/2" tap, but even with the huge set I have, nothing even comes close. I was going to use a 1/4" for the return, guess that's out of consideration. I don't have anything to tap with now.
Old Feb 8, 2009 | 01:17 AM
  #199
mrsilent13's Avatar
just go to sears and get a new tap..and if you have to...get a die set as well cuz you might need it for the new nipple
Old Feb 8, 2009 | 01:27 AM
  #200
Sentry's Avatar
I've never understood what the difference between NC and NPT on these fittings. I think I have NC taps, but a 1/2" NC tap is much smaller than a 1/2" NPT fitting. What should I look for?
