supercharged build problem
Old Feb 9, 2010 | 10:30 AM
  #201
rico's Avatar
yeh its easy
Old Feb 9, 2010 | 11:58 AM
  #202
Fonzi1289's Avatar
Yep dont worry u got this lol
Old Feb 9, 2010 | 03:11 PM
  #203
HunterKiller89's Avatar
Originally Posted by ryansalazan
ok cool so then i can just unplug the battery and then take out the old piller and slip the new one right on? sounds easy enough lol. i was just making sure didnt want to take it off and then the airbag just ex[plode in my face lol.
i thought the same thing dude, lol. once you get it off, you'll see there was no reason to worry
Old Feb 10, 2010 | 12:23 AM
  #204
ryansalazan's Avatar
ya lol ive got the guages on was a sinch a bolt and clip off lol thanks guys! its just the air bag flip up scared me haha. oh and i had something that i wanted to ask... how much are you guys boosting with a 2.8 pulley or how much are you boosting in general?
Old Feb 10, 2010 | 08:48 AM
  #205
rico's Avatar
i was boosting around 17 psi max i beleive that was with full exhaust too
Old Feb 10, 2010 | 09:47 AM
  #206
damn dude well; i think there might be some kind of pinch or something in my boost line tubing, i floored it yesterday and only peaked 5.5 psi... and it doesn NOT feel like 5 more like 10 or more. its very loud and pulls hard but 5? any reason you think its like this? i also am running on stock headers so would this effect it? and the tubing doesnt seem to have a pinch in it.
Old Feb 10, 2010 | 09:51 AM
  #207
rico's Avatar
clogged cat?
Old Feb 10, 2010 | 10:53 AM
  #208
06_ion2's Avatar
Bet you got a cracked line. vacuum look normal?
Old Feb 10, 2010 | 12:13 PM
  #209
Fonzi1289's Avatar
If he had a clogged cat wouldnt it boost higher?
Old Feb 10, 2010 | 12:53 PM
  #210
on your boost bypass actuator, the hose/nipple on the bottom is not connected to anything, correct?
Old Feb 10, 2010 | 05:13 PM
  #211
My cat or exhaust I should say doesn't sound wrong just louder because of the blower. On my t-fitting one of the nipples is connected to the small nipple on the manifold, another is connected to the boostguage itself, and the last is connected to the vacuum line. Yea the vacuum looks normal but when I hit the throttle the vacuum shoots to only 5.5 psi boost... It honestly feels alot more than that.
And does anyone know where to hook in a tranny temp sensor lol and also on a air to fuel ratio, where would you connect on the o2 sensor? Sorry for a lot of questions and late response I'm at work lol thanks guys!
Last edited by ryansalazan; Feb 10, 2010 at 05:13 PM. Reason: Automerged Doublepost
Old Feb 10, 2010 | 05:34 PM
  #212
what vacuum line are you referring to? The bottom nipple of the actuator? If so, then thats your problem.
Old Feb 10, 2010 | 06:54 PM
  #213
scottyguy401's Avatar
The nipple at the top right on the black thing doesn't have anything plugged into it right? That would limit your boost significantly.
Old Feb 10, 2010 | 09:01 PM
  #214
Fonzi1289's Avatar
No the bottom one shouldn't be connected to anything man. There should be no t fitting and the vaccum for the boost just goes straight to the manifold
Old Feb 10, 2010 | 09:20 PM
  #215
i have a t-fitting the left and right sides are one to manifold and the other to the vacuum line that is plugged on the throttle body. and the last nipple facing up goes to the boost gauge. is the nipple from the picture above on the top right supposed to be connected? ans if so to what? that may be my problem cause i dont have it connected. its just taped
Old Feb 10, 2010 | 09:33 PM
  #216
It shouldn't have anything connected to it. It should be able to breathe freely into the atmosphere
Old Feb 10, 2010 | 09:40 PM
  #217
Fonzi1289's Avatar
Yeah nothing to it. And nothin should be teed man. Boost goes straight to the nipple on the man right by the injectors and nothing into the tb connector. And big booster goes to tb. And the top nipple on the bpv should be already routed to the blower.
Old Feb 11, 2010 | 01:11 AM
  #218
theres your problem. it shouldnt be taped. it needs to vent to the atmosphere
Old Feb 11, 2010 | 01:44 AM
  #219
lol i found what it was! fonzi was right and you as well hunterkiller i hooked the hose up to the manifold and to the boost gauge and then the nipple on the wastegate to the vacuum hose. now it all works i peak 17psi not bad lol. does anyone have any secrets on to how to keep the stock map sensor in place on the intake manifold? i use my stock one and put it on the intake manifold but it popped out and made the car go insane lol. anyone have any ideas? a bolt wont work because its not lined up properly.
Old Feb 11, 2010 | 05:46 AM
  #220
gotta make a custom bracket (bend a piece of aluminum or something) or make the sensor part wider with something like pipe wrap
Old Feb 11, 2010 | 09:43 AM
  #221
ya lol thats what i was thinking but i was just asking if there was an easier way i guess not lol. well its all good. ive put soo many hours into this car of work whats another hour or two? lol
Old Feb 11, 2010 | 09:44 AM
  #222
rico's Avatar
its NOTHING lol
Old Feb 11, 2010 | 10:30 AM
  #223
Fonzi1289's Avatar
Yeah u gotta custom it up man.. thats what i did.
Old Feb 11, 2010 | 01:15 PM
  #224
lol i kow guys im just being lazy lol. i typed that last night before i went to bed.
Old Feb 11, 2010 | 01:23 PM
  #225
Fonzi1289's Avatar
So hows it going?
