Tom's Build :D
Old Mar 18, 2009 | 09:45 AM
  #176
BlackCobalt707's Avatar
hows the build goin?
Old Mar 18, 2009 | 10:27 AM
  #177
NWAE Cobalt's Avatar
Originally Posted by Sentry
Have you checked your spark plugs to make sure they're any good? As long as you are sure the timing is good, plugs are the first thing you should be looking at. It's possible you could have fouled them up while it was running bad.
what do i need to do to check those?? is it proboble that ALL of them went caput at once????
if i do need to replace should i replace them with stock? one step hotter?
Old Mar 18, 2009 | 11:10 AM
  #178
VinceTrifecta's Avatar
Compression test is a good idea, that engine didn't sound right when we cranked it. It sounded like my Ford Escort did after the timing belt broke
I'll be down in your neck of the woods again on Friday for dyno tuning you can borrow my compression gauge if you want.
Old Mar 18, 2009 | 01:28 PM
  #179
i wont be able to get it back to you that day as ill be at work, but that would be much appreciated unless i can get it started lol, i got it all timed...so i know mechanicaly thats all good and such, im starting to think either no compression still (or not enough) or that it is the injectors/ plugs..im going to replace the plugs and redo the wiring harness without the butt connectors tonight and try again...if that doesnt work then compression test time
bump for any help
Last edited by NWAE Cobalt; Mar 18, 2009 at 01:28 PM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 01:48 PM
  #180
MP Cobalt's Avatar
Did you check the harness? You plugs should be fine. Vince which tune did you use for his base was it the one you had for mine?
Old Mar 18, 2009 | 02:42 PM
  #181
i didnt..i went and had a few drinks last night to take the edge off the day
im going to replace the plugs and check the wiring tonight and then try again...
Old Mar 18, 2009 | 02:58 PM
  #182
MP Cobalt's Avatar
lol I wish I knew whats wrong.
Old Mar 18, 2009 | 08:16 PM
  #183
ya....im *HOPING* that i didnt have valve tap at first and bent something...ill be broke with no car and crying myself to sleep
compression test tonight too
Last edited by NWAE Cobalt; Mar 18, 2009 at 08:16 PM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 08:18 PM
  #184
Sentry's Avatar
Don't worry too much about it. I doubt you messed anything up, timing is probably just off.
At the worst case scenario, you might have to get a tow to a shop. No biggie.
Old Mar 18, 2009 | 11:08 PM
  #185
i took the whole thing apart and retimed it the hard way yest....
im thinking maybe fouled plugs or problem with injectors still...compression test just to make sure....hopefully one of the first two though...thats an easy tonight and get it running fix...
dyno numbers will have to wait though getting in to the stages of brokeness
soooo....0 compression on cyl 1...tested the tool on mels car and it works fine...no compression on mine, took all the plugs off and cranked it and no fuel spirted out, so i put on safety glasses and looked down while cranking - piston still moves which means no hydrolock. put the stock injectors back in to plug the hole (making sure its not leaking from the new injectors) and that isnt the prob.........
buddy who is a gm tech is coming over to take a look, but we are leaning towards internal damage...maybe bent valves.....but he has a spare motor i can work on if i absolutely have to...hopefully there is just something i missed...but maybe not
Last edited by NWAE Cobalt; Mar 18, 2009 at 11:08 PM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 11:11 PM
  #186
Jn2's Avatar
Jn2
ur car will run on just 2 cylinders btw, so even if 2 were shot, it would run on just 2, i know mine ran one 2 for a good 70 miles before i got it fix'd
Old Mar 18, 2009 | 11:14 PM
  #187
if the timing was wacked out though...and that caused 1 cylinders valves to bend..then its likely it happened to all of them...i didnt even bother testing the others after that
Old Mar 18, 2009 | 11:17 PM
  #188
Jn2's Avatar
Jn2
ohhh right, ur timing forgot that... :p
  #189
MP Cobalt's Avatar
Whats the compression with the stock injectors?
Old Mar 18, 2009 | 11:18 PM
  #190
0....same
Old Mar 18, 2009 | 11:22 PM
  #191
MP Cobalt's Avatar
Take your valve cover off and take a picture of the cam gears with the marks on the side. If there right I trying to think what else could be off or wrong. If you didn't hear valve tapping your valves should be fine
Old Mar 18, 2009 | 11:27 PM
  #192
i cant take a pic now...to late to be taking that apart and i have to work tomorrow...
the timing may be on now, but if it was off to begin with i may have already done the damage and bent hem just enough to be out of the way of the piston but still not seating and sealing
Old Mar 18, 2009 | 11:29 PM
  #193
Old Mar 19, 2009 | 12:56 AM
  #194
07cobaltguy's Avatar
im sorry for your troubles as i have had my share of them also but.......... This is why everyone who uses the "zip-tie method" gets flamed. not trying to be an ass but this is how it is.
Old Mar 19, 2009 | 01:15 AM
  #195
Sentry's Avatar
You got valves for the repair? I've got some quality stainless ones I could sell you, would work good for your application. Definitely sounds like a bent valve, sorry about the bad luck. It could always be worse though. While it's down, get the head ported and some stainless valves. That's what I would do, but you probably need your car sooner, and some R&R is probably more of what you are needing for now.
I've got a spare head and valves like I said, let me know if I can help.
Old Mar 19, 2009 | 01:25 AM
  #196
well...good news is we know what the issue is...
bad news is at least one bent valve
so this weekend i will be pulling the head, at minimum i have to replace the valves and valve springs and retainers and roller rocker thingys lol. since i have to get the head milled while off im prob going to shave the head to get higher compression as well as the cometic head gasket since that will have to be replaced too...
basically im going to replace what i have to but im going to upgrade what i have to replace
i do have a motorcycle while this is down...so thats good
also, if its bad my buddy has an extra 2.2 he can sell me but that needs a good going through to be safe to run.
he is an ase cert gm tech and said he'll help me out...so thats GREAT.
i will never cheat while timing again
more updates to come.
ill let you all know when i get the head off what needs to be done exactly and then ill be looking for parts
sentry..i may take you up on that offer if needed
Old Mar 19, 2009 | 02:23 AM
  #197
Sentry's Avatar
I doubt you'll need a new head, just throwing that out there. I've got a set of stock 2.2 valves, they're a bit dirty but they are straight and will work. Let me know, hell I'll give them to you, just pay shipping. Did you bend an intake valve or exhaust and how many?
Old Mar 19, 2009 | 08:19 AM
  #198
MP Cobalt's Avatar
I told you I told you. cheating with that gets you broke. Well there's at least a month until you tryo to put it back together.
Old Mar 19, 2009 | 10:25 AM
  #199
3 weeks to a mo ya
it would be sooner if i wasnt going out to texas next week....
but weekend after this ill pull it apart and have my buddy come look to make sure nothing else is fucked.
buy parts, weekend after that reassemble *hopefully* and then retime and all that jazz
Old Mar 19, 2009 | 12:34 PM
  #200
OBZ's Avatar
OBZ
Well at least you found the problem.. I know this is a big learning experiance for you as well as many others.. So thanks! lol No but like I've always said..
If you have to replace, upgrade!
