Tom's Build :D
lol, ill see if i can cancel my order with ced...as it is on back order and they havent processed, but i would LOVE a set of head bolts!! and do you have all 14 of them?? the e socket star ones and the 10 inner?
ya...all the exhaust valves are bent...
cyl looks ok, you can see where it impacted but because it was only as fast as the starter was turning it its ok...
and some more pics..
and this is where i get to work on the car lol
REM TO TAKE THEM OFF IN THE RIGHT ORDER OR YOU COULD WARP YOUR HEAD!!!!!!
wanna come work on a cobalt in the cold again?? :P cant be any worse then blakes turbo build
Last edited by NWAE Cobalt; Apr 1, 2009 at 03:08 PM. Reason: Automerged Doublepost
well, steve came over (yelloweye) and we put the car back together yest
made sure everything was happy and such installing and then fired her up today (after making sure the fuel pump relay was put back in the right spot
that was an adventure unto itself) and she starts
it idles like **** but it starts haha
we tried taking it around the block and i got engine power reduced (no flashing check engine which is good lol)
put it back in the driveway and are leaving the battery unplugged for a while to see if it fixes the codes it was throughing (was having a problem with the map/maf correlation and also this causes a random misfire)
so i called vince to see if we can work it out lol, but hoping it will at least run after i reset the battery for 30 min or so
not running it till vince is here again...it runs like ****
bounces from 500rpm-1500rpm unless you hold the throttle, then it throws a code for maf/map correlation (p0068) and then misfires, then engine power reduced....
lolol, and i need to have money to pay him lolol
got fog lights installed now too
Here you go
http://www.youtube.com/watch?v=7CS_cC_ywM4
here are pics of reassembly
https://www.cobaltss.net/forums/pictures-videos-64/ls-head-reassembly-166245/
Here you go
Last edited by NWAE Cobalt; Apr 15, 2009 at 04:58 AM. Reason: Automerged Doublepost
Here you go
https://www.cobaltss.net/forums/showthread.php?t=166245
Here you go
my stage 2 camsYou will see the idle around a grand or so once tuned but the idle will be bouncy all the time just not that bad.
