noorj's turbo "build"
3 psi spring in lol, I didn't have time to play with it last night but I couldn't get my zzp bov to open. just keep getting compressor surge, anyone have this problem before/know how to fix it?
not many pics during the actual build but heres some
downpipe I made, gotta love that miller
gaskets I made for turbo drain flange and vband adapter until I get my new turbine housing
and here's what it looks like now
waiting on a gasket before I put the saab lk9 on, gonna swap the ky stage 3 in sometime over the next couple weeks and have a new turbine housing in the mail then it's officially done.......for a little while
never knew 11 psi could be so fun, pushed 35 lb/min ve
I'm having a problem controlling boost tho, one minute I'll get 4psi (spring pressure) next I'll get 11 psi
I talked to Hallman and they said that there was a problem with a batch of controllers going out without the little assembly grease on the spring in the body of it. My thoughts are that it is getting stuck on some pulls and not on others. My map would always either read 132 kpa or 176 kpa (4 ish psi or 11psi).
They said a fingertip of any type of grease on the spring should make it function correctly
but i'll deff be going to empire, probably next friday if tuning the 80's goes well!
If I'm ever back in albany well have to meet up man
