2010+ Future Cruze Discussions Discussions and information related to the upcoming 2010 Chevy Cruze
Vince buys a Cruze LTZ
Old Nov 22, 2010 | 10:24 AM
  #101
imphat0260's Avatar
Originally Posted by Area47
you do realize that you do have a cobalt. this kills resale all together.
Old Nov 22, 2010 | 10:59 AM
  #102
umrdyldo's Avatar
Big question on my mind is what type of tuning if any has GM done for the ECO version and can it be reproduced on the base model.
Found a 2011 with 800 miles on it for 16k already. Bye bye resale.
Old Nov 22, 2010 | 11:07 AM
  #103
VinceTrifecta's Avatar
That's a good question. Tuning is likely part of it, but there are some mechanical differences, also. The ECO uses low rolling resistance tires, different aerodynamic body panels, and a shutter system in front of the intercooler to reduce drag under certain conditions.
The ECO model also has a special manual transmission, although the 6sp auto is an option for it.
Old Nov 22, 2010 | 11:10 AM
  #104
Originally Posted by riko540
The LTZ trim only comes with an auto no manual option IIRC.
According to my brochure (unless I read it wrong), the manual transmission is only available on the 1.8L non turbo version, and the ECO version.
I would personally prefer to have a manual transmission but I need at least one 6sp auto in the family to tinker with
Old Nov 22, 2010 | 11:11 AM
  #105
umrdyldo's Avatar
Has anyone found a picture of the shutter? i would like to see how it works.
NM, http://www.greencarreports.com/blog/...o-reach-40-mpg
Half a mile per gallon in combined driving. Blah, no thanks.
Old Nov 22, 2010 | 11:14 AM
  #106
Update:
I was at the dyno again on Friday, but I didn't get a chance to put the car on the dyno due to needing to sort out some torque management issues. Those issues have been sorted out, the car is running nicely at 15psi (about 3psi over stock). I hit 18psi when I was still working on the torque management issues and popped a boost sensor out of range code, so I'll be looking at the diagnostics for the boost sensor next.
These new ECMs have a very accurate torque calculation system in them. According to it, the torque has increased about 15 lb-ft by nudging the boost up. It's a start!
Old Nov 22, 2010 | 11:28 AM
  #107
Billig ss/sc's Avatar
Sub'd! Not expecting any kind of huge numbers, but should be a cool little toy!
Old Nov 22, 2010 | 11:30 AM
  #108
elecblue06's Avatar
Update:
sounds like it's only a 2 bar map sensor.. maybe picking up an sstc stock sensor would be in order to work with it
Old Nov 22, 2010 | 11:31 AM
  #109
It's a 2.76bar sensor like the LNF, and interestingly enough the MAP is the 3bar sensor used from the GMS1/LNF kit, but they never expected the absolute pressure levels to exceed 210kPa or so, so it's tripping the diagnostic and limping out. Haha
Old Nov 22, 2010 | 11:33 AM
  #110
Agreed. With E85 or water/methanol injection we might be able to go further with it, but if we reach 170whp I'll consider that a decent gain.
Old Nov 22, 2010 | 11:36 AM
  #111
Terminator2's Avatar
Gotta find and remove the overboost. The stock OS may not have the maps scaled to run 3 bar pressure even if the sensors are the 3 bar bosch sensors. Might need to adjust the map scaling so you can run above 210 kPa
Old Nov 22, 2010 | 11:38 AM
  #112
Yea definitely! If nothing else, just because GMs tune isnt even close to performance-minded. I really like thr Cruze, cant wait for a SS version to come out. Then the fun can really begin!
  #113
subd
  #114
Yeah, I am pretty sure once we fix this issue, we'll run into something else. In software engineering, this is called "peeling the onion". Haha.
Old Nov 22, 2010 | 11:41 AM
  #115
MAP voltage output vs absolute pressure probably needs to be rescaled, or even better the operating range needs to be extended if 210 kPa is not a hardcoded ECM limit.
Old Nov 22, 2010 | 11:42 AM
  #116
Matt M's Avatar
Originally Posted by JL-KA
What happened to getting those pictures?
I hate the Cruz with an undying passion. Makes me feel like GM is just shitting on the people who bought Cobalts(LS and LT). They come out with a much improved car for the same price. Means they raped us on ours. They will KILL the resale value of base Cobalts. The only ones worth anything now will be the SS's. I'm sure I'll get F-ed when I trade in for something else.
It's just a trade-off. Even if the Cruze is better in many ways, the Cobalt easily out-performs it dollar for dollar. SS/Ts give you a turbo, direct injection, variable valve timing, and great handling all in a car that can be found new for under $20k. I would hardly consider that getting raped.
Old Nov 22, 2010 | 11:48 AM
  #117
Totally agreed.
On a personal level I really like the car, and I like it tons more than the 2010 Buick LaCrosse I had for business use before the Cruze, but for performance, it's not even close to what the LNF can do. And to be fair it wasn't designed to.
However, the LaCrosse, Cruze and the Regal are ushering in a new era of ECUs for GM vehicles which we are interested in. That, and the rumor is that the upcoming (if it goes to production) Aveo RS is going to use this 1.4L turbo engine.
Old Nov 22, 2010 | 11:52 AM
  #118
Matt M's Avatar
Totally agreed.
I hear that the turbo Regal ECMs are pretty complex. I bet you are looking forward to sorting all of that out!
What's the story with the Buick Verano? Is it going to use the same drivetrain as the Cruze?
Old Nov 22, 2010 | 11:53 AM
  #119
umrdyldo's Avatar
Totally agreed.
HMMM, If they gave it the same HP and you could tune it, that would be a fun little 145-150whp go cart. That would spank a lot of the base cobalts on here.
Old Nov 22, 2010 | 12:02 PM
  #120
That's exactly why I bought the LaCrosse back in May. It was one of the first vehicles to use one of the new controllers.
All of the new vehicles are using a new set of "turbo aware" controllers from Delphi (the E69 is finished, other than use in the 3.6L LLT engine in the new Camaro, Buick LaCrosse and a few others). The Regal is getting the E39 which is SIDI capable, and the Cruze gets the E78 which is designed for non SIDI applications.
We're ready to go on both of these, and everything we learn about tuning the Cruze will apply to tuning the Regal as well.
Not sure on the Verano. Wiki says it will use the Delta II chassis but doesnt give any more information about the powertrain.
Old Nov 22, 2010 | 12:20 PM
  #121
Matt M's Avatar
Last I heard, the Verano will use the 1.4 turbo, and possibly a 1.6 turbo.
Old Nov 22, 2010 | 03:23 PM
  #122
philupondes's Avatar
I want a aveo turbo!!!!! lol
Old Nov 22, 2010 | 05:05 PM
  #123
JL-KA's Avatar
Yup...this will only make it worse though.
Old Nov 22, 2010 | 05:18 PM
  #124
ripped's Avatar
cruze reminds me of the 1.8t vw gti and jetta. seems like gm with all this ecu nonsense is trying really hard to keep tuners out of the ecu hehehehe.
Old Nov 22, 2010 | 07:11 PM
  #125
Ch1ck3n's Avatar
Originally Posted by philupondes
I keep seeing E-85 all around on this site, I know what it is but tunning for 85 would make more power than 93? O and i tried to search for someone you sales 85 around my area, haha closest is about 45 mins away.
E85 has a higher octane rating than 93, so you can run more timing. More timing = more torque = more power
