"LEJ" Hybrid Build/2011 Build Thread
Old Jul 4, 2011 | 10:19 AM
  #151
Speedytec's Avatar
Originally Posted by newt
Well assembling the LSJ head didn't go as planned, turns out Supertech valve springs don't fit in the LSJ head. Maybe this is why you guys have been having so many issues.
A bit of die grinding will sort this out tho.
Never heard of this ^ before.
What/how does these not fit in the LSJ head?
Old Jul 4, 2011 | 11:21 AM
  #152
newt's Avatar
This is the first I've heard to this too, I was always under the impression they fit in the LSJ head since Supertech lists them for the LSJ as well as the L61, so I was quite surprised when they didn't fit.
If you look closely, the spring is contacting the head casting directly infront of the lash adjuster. That was the only spring I installed, but by placing the other springs in the head it would seem that some have clearance and some don't. The ones that do have clearance however are too close for comfort IMO to the head, if you take into acount spring deformation when compressed.
This is the Supertech 78lb kit that I have, to clearify.
Like I said, I have never heard of this issue before, but I have heard enough people have had issues with Supertech springs here in LSJ's. I'm not sure specifically what issues, but maybe this is part of the problem.
I might post this in LSJ Tech and see what some of the other guys have to say.
Old Jul 4, 2011 | 02:01 PM
  #153
D-mac's Avatar
The valve cover will be dirty in no time anyways as this is my "drag car", the only time the hood gets poped is when something is broken...haha.
What about the Car Shows you attend?
Old Jul 4, 2011 | 02:32 PM
  #154
newt's Avatar
Hood stays closed, I get so many points for my mad sick exterior that I don't need the extra points from the engine bay to win.
LOL
Old Jul 6, 2011 | 11:29 AM
  #155
newt's Avatar
Some updates:
Clearanced my head for the valve springs and cleaned it out again.
New Ford Racing 42lb "Blue Demon" fuel injectors shipped out yesterday.
Pulled the oil cooler sleeve out of my oil filter housing, so now I can block the holes off.
Bad news:
Cylinder head dowels are a 5-7 day wait from GM, ordered yesterday, so wont be in till next week.
Fucked up all my valve seals pulling them back out of the head....so I have to order a new set from GM.
Other than that...nothing to report.
Don't worry tho, SOMEDAY day this engine will run....hahaha
Old Jul 6, 2011 | 07:56 PM
  #156
Leafydialupking's Avatar
How hard was pulling the sleeve? I can get an engine with the oil cooler for 150-200 buck cheaper than one without.
Old Jul 7, 2011 | 07:39 PM
  #157
newt's Avatar
Not to bad, we trapped it then left the tap in, put a pair of vice grips on the tap and then heated the sleeve and used a long pry bar against the vice grips and it poped right out.
There is an o-ring in there that holds it in, the pry bar probably would of worked without heating it.
Old Jul 7, 2011 | 07:42 PM
  #158
Huh? So you put a tap into it put vice grips on the tap and pried it out. Thats an interesting way to do it.
Old Jul 8, 2011 | 11:23 AM
  #159
newt's Avatar
Ya, we were gonna use a slide hammer but my buddy forgot to grab it from work so we improvised.
We tried to hit the vise grips with a hammer but they weren't solid enough to transfer to force to the sleave.
I know it sounds kinda haywire...but it worked like a dream, hardly any pressure with the pry bar and it poped out.
ZZP welded a nut to the end of the sleave, then threaded in a slide hammer and poped it out....I didn't really feel like welding a nut on so I did it my way.
Old Jul 14, 2011 | 08:43 AM
  #160
newt's Avatar
More progress:
Cylinder head FINALLY assembled
Made my block off plate for where the CPS sensor would normally go
Addition to my valve cover
Mock up to see the finished product
Old Jul 14, 2011 | 09:46 AM
  #161
elecblue06's Avatar
nice keep up the good work.
not really feeling the powered by ecotec but it's your car
Old Jul 14, 2011 | 10:26 AM
  #162
newt's Avatar
Looked to plain without something on there, plus its a bit of a homage to the GM Ecotec race cars.
If I get bored of it its just a sticker so it will peal off, if it doesn't get really hot and burn off first, that is...lol
Old Jul 14, 2011 | 10:30 AM
  #163
newt's Avatar
Also, better pic of my block off plate I forgot to post.
It isn't perfect I know, but I made this in 20 mins with a hacksaw and a 5" flapper disk on a grinder, and it shows..lol
Will hardly be able to see it anyways.
Old Jul 18, 2011 | 09:22 AM
  #164
newt's Avatar
Motor is together, and assembled with trans....putting it back in the car this week...hopefully fire it up next weekend.
My solution to the oil cooler, tapped and plugged the big hole with a #10 BSP and a bonded seal and tapped the small hole 1/4 NPT to #4 JIC for my oil pressure.
Old Jul 19, 2011 | 12:37 AM
  #165
D-mac's Avatar
Boom
Let me know when she fires up dude
Old Jul 19, 2011 | 10:45 AM
  #166
newt's Avatar
Got my CPS bracket and trigger wheel timed last night.
Motor goes back in the car tonight hopefully.
Old Jul 20, 2011 | 04:23 AM
  #167
09LAP's Avatar
dam newt keep it commin!!!
Old Jul 20, 2011 | 09:33 AM
  #168
newt's Avatar
Got the motor in last night....
Then ran into another snag (The LSJ head doesn't clear the Master, its touching the brake lines, not sure how I'm gonna fix this yet).
That where I left it for the night.
Old Jul 20, 2011 | 02:50 PM
  #169
Time to bust out the angle grinder.
Old Jul 20, 2011 | 03:01 PM
  #170
mrbelvedere's Avatar
omg just cut the line and reroute it
Old Jul 20, 2011 | 03:03 PM
  #171
How the hell are you going to do that? You cant make a bend that sharp in brake line, it will just kink. And you shouldnt make a bend that close to a connection either. Just grind 1/2 an inch off the head where its close.
Old Jul 20, 2011 | 03:20 PM
  #172
it isent hard to do man all you have to do is cut it in the long strait section loosen it up at the master cylnder move the line out of the way and then add a longer piece in and bend it to clear and reattach
Old Jul 20, 2011 | 03:22 PM
  #173
You dont quite see it. That plate for the cam pos sensor blockoff looks to be about a quarter inch from the face of the nut on the fitting on the MC. Which would mean newt would need to get a less than 1/4" radius bend in a 1/4" (or 3/16) piece of tubing and that is not physically possible.
Old Jul 20, 2011 | 03:39 PM
  #174
Quick92RS's Avatar
Or after the first 90 bend where it starts to bend down, put a larger radius bend in it to clear the head. Taking material out of the head on a drag car is the last thing i'd want to do.
Old Jul 20, 2011 | 03:40 PM
  #175
elecblue06's Avatar
is there any way you can do a rotated motor/ tranny mount setup ? it'll help your axles and help potentially with your issue
