The Motor is IN!!!!!!
Good luck, hope everything works, I did help my friend change the tranny on his 98 Z24 and that was a bitch..... getting it to line up.... How are you making out anyways?? Im too lazy to read all 12 pages....
Originally Posted by tcolli17
Well then, what is next to my motor that looks like a battery to with terminals on it?
bdwarr, good luck! Its always cool to see a motor come back to life!
Originally Posted by 2K5SS/SC?
****, I'd be running to the post office if it was within a 5 or so miles! I'm not joking either! I hope you get it!
its 20 or so miles away i called them every 15 minutes till the driver showed up and oh yea i waited in the lobby for an hour and a half
I GOT IT THOUGH
the more i think of some of the things i have done the sadder i think this is, oh well
im happy with my car even though its on jackstands, doesntrun, has a dent in the hood, and oh yea has a huge ***** drawn in the dust from my buddies, my trunk lid has SS spelled out inanimal crackers on it
Originally Posted by BlackyK
I gotta say I love you sig, Bdwarr6. You found that magical angel that just picks up every thing that is so ungodly gorgeous about the SS! GL getting the car rolling again!
if you want one just pm me your car color and w/e you want in it ill be happy to make you one
Originally Posted by Brian MP5T
What the ****.. Who takes a cable?
Half your problems you cause yourself.
It would have been in and runng a week ago if it wasn't for the shitty fuckups..
bd wanna inform me how much you have paid for pistons, head gasket, jsut overall build im just sorta curious, im hoping to get some stuff going for myself as well here soon, i foudn a guy whos gonna my head for a wicked price so
. btu i man as well do the bottom end while im at it
Originally Posted by bdwarr6
thanks brian... im sorry i share my toys and honestly who cares if i screwed up, bothing is broke i gave learned alot and im totally toasted
I was being a bit harsh. You did learn it's true..
But it sounds like you are rushing and not thinking.
Get a white board next time.
Get a digital camera next time.
Take pictures of every part of the engine. Every Connection and hose.
Put in order the steps you have to do to make it run..
Ie.
Clean Head and Block Surfaces
Install Head Studs
Place Head Gasket (Correct Face Up)
Initial Torque Head in Outward Pattern to 20 Ft/Lb
Install Head to 80 Ft/Lb In Outward Patten
Time Motor so that crank is TDC Intake Cam sits 90 Deg Ex Cam Sits 270 Deg
Tension Chain and rotate assembly (Crank) by hand Clockwise (Twice) to check timing.
Etc.. Etc..
You wasted so much time and money by being sloppy... If you worked in a garage and did this, you would be fired and blacklisted in your city.
